What is the Neural Graphics Development Kit?
The Neural Graphics Development Kit empowers game developers to build immersive mobile gaming experiences using a neural accelerator for post-processing effects like upscaling. By combining Unreal Engine and the ML extensions for Vulkan, these tools allow you to integrate and evaluate AI-based upscaling technologies like Neural Super Sampling (NSS). This Learning Path walks you through the setup and execution of NSS for Unreal Engine.
What is Neural Super Sampling?
NSS is an upscaling technology from Arm, purpose-built for real-time performance and power efficiency on mobile and embedded platforms.
It uses a compact neural network to:
  • Upscale low-resolution frames into high-resolution visuals
  • Incorporate temporal data such as motion vectors, depth, and feedback
  • Reduce bandwidth usage and GPU load
Powered by the ML extensions for Vulkan, this new technology delivers smooth, crisp image quality, optimized for mobile-class hardware with a Neural Accelerator (NX). You’ll be able to render frames at a lower resolution and then upscale them using the technology, which helps you achieve higher frame rates without compromising the visual experience. This is especially useful on mobile, handheld, or thermally limited platforms, where battery life and thermal headroom are critical. It can also deliver improved image quality compared to other upsampling techniques, like spatio-temporal implementations.
Under the hood, Neural Super Sampling for Unreal Engine (NSS for UE) runs its neural inference through Vulkan using ML extensions for Vulkan, which bring machine learning workloads into the graphics pipeline. The Development Kit includes emulation layers that simulate the behavior of the extensions on Vulkan compute capable GPUs. These layers allow you to test and iterate without requiring access to NX hardware.
Neural Upscaling in Unreal Engine
With these resources, you can seamlessly integrate NSS into any Unreal Engine project. The setup is designed to work with Vulkan as your rendering backend, and you don’t need to overhaul your workflow - just plug it in and start leveraging ML-powered upscaling right away. The technology is available as a source-code implementation that you will build with Visual Studio.
Proceed to the next section to set up your development environment and enable the NSS plugin.
