Enable Neural Frame Rate Upscaling in Unreal Engine
Understand neural graphics and NFRU
Set up the development environment
Set up the Unreal project with NFRU enabled
Validate NFRU in Unreal Engine
Understand console variables for NFRU
Set up a debug view in Unreal Engine
Use RenderDoc for Arm GPUs with NFRU for debugging and analysis
Create a Third Person template project using the C++ option. You need a C++ project to build the Arm Neural Graphics plugin.
NFRU isn’t supported in the standard viewport. Use Standalone Game mode or create a packaged build to run and validate NFRU.
Create a
Plugins directory in your project root, then copy the complete neural-graphics-for-unreal folder into it. Keep the downloaded emulation-layer files inside the plugin folder.Install Vulkan SDK version
1.4.321.0 or newer. Use Vulkan Configurator to enable the emulation layers for running ML workloads through Vulkan ML extensions.In Standalone Game or a packaged Development build, use
r.NFRU.Enable, r.NFRU.ShowDebugView, and r.NFRU.PaceAdjuster to enable NFRU, view intermediate buffers, and tune frame pacing.
