Install the required tools and dependencies
To use Neural Frame Rate Upscaling (NFRU) in your Unreal Engine project, install the tools and plugin listed here. You’ll use them to build and test NFRU with ML extensions for Vulkan.
You will install the following:
  • Vulkan SDK 1.4.321.0 or later. The SDK includes Vulkan Configurator, which you use to activate the ML emulation layers on Windows.
  • Git and Git LFS. Use them to clone the plugin repository, its submodules, and large binary assets.
  • Python 3. The plugin’s emulation-layer download script requires Python 3 and internet access.
  • Arm Neural Graphics Plugin 1.1.1. The plugin is hosted in the neural-graphics-for-unreal repository . Its included DownloadEmulationLayer.bat script downloads the compatible ML Emulation Layer for Vulkan.
Install the Vulkan SDK
Go to the Vulkan SDK page and install Vulkan SDK version 1.4.321.0 or later for Windows.
The Vulkan SDK supplies development tools and headers. NFRU also needs a Vulkan implementation that exposes the plugin’s ML extensions for Vulkan. The optical-flow path needs VK_ARM_data_graph_optical_flow, alongside tensor and data graph support for neural inference.
If your Windows GPU driver doesn’t support these extensions, use the ML Emulation Layer for Vulkan downloaded by DownloadEmulationLayer.bat. NFRU needs VK_ARM_data_graph_optical_flow for its optical-flow stage.
Clone neural-graphics-for-unreal
Clone the neural-graphics-for-unreal repository :
git lfs install
git clone https://github.com/arm/neural-graphics-for-unreal.git
cd neural-graphics-for-unreal
Check out the revision for the specified plugin version. Then initialize its submodules and download the Git LFS assets:
git submodule sync --recursive
git submodule update --init --recursive
git lfs pull
git submodule foreach --recursive "git lfs pull"
Keep the cloned neural-graphics-for-unreal directory intact. You will copy this complete plugin folder into your Unreal project’s Plugins directory in the next section.
Download the ML Emulation Layer for Vulkan
In the cloned neural-graphics-for-unreal folder, double-click DownloadEmulationLayer.bat, or run it from a terminal in that folder:
.\DownloadEmulationLayer.bat
The script reads the compatible emulation-layer version from Source\NG-SDK\docs\compatibility_matrix.md. It installs the Windows x64 Graph and Tensor DLLs and Vulkan manifests in Binaries\ThirdParty\VulkanMLEmulation\Win64 inside the plugin folder. Activate the layers in Vulkan Configurator.
Configure the Vulkan ML emulation layers
Vulkan Configurator is installed with the Vulkan SDK. Use it to activate the emulation layers before you run Standalone Game or a packaged Windows build.
  1. Launch Vulkan Configurator from the Windows Start menu.
  2. Add a user-defined Vulkan layer path that points to the downloaded runtime directory inside the plugin:
    <plugin-root>\Binaries\ThirdParty\VulkanMLEmulation\Win64
    Image Alt Text:Add a user-defined Vulkan layer path in Vulkan ConfiguratorAdd the plugin's downloaded emulation layer directory
  3. Verify that these layers appear in the list:
    • VK_LAYER_ML_Graph_Emulation
    • VK_LAYER_ML_Tensor_Emulation
    Image Alt Text:Vulkan Configurator showing the loaded emulation layersConfirm that both Vulkan ML emulation layers are available
  4. Switch to the Vulkan Loader Management tab. Place the Graph layer before the Tensor layer, enable both, and apply the configuration.
    Image Alt Text:Vulkan Configurator showing the Graph layer above the Tensor layerVerify the emulation layer ordering
Before you move on
Keep Vulkan Configurator running with this configuration active whenever you launch NFRU in Standalone Game or a packaged Windows build.
With the Vulkan requirements in place, you can install the plugin in your Unreal Engine project.
