MTE_test.apk is an application that implements the most common types of memory bugs. By pressing any button on the application shown below, you can execute code containing a memory bug. If MTE is enabled on your device, MTE will detect the memory violation and make the application crash. You can then retrieve a bug report. This report contains useful information to identify the cause of the crash and where it happened.
 MTE test application implementing most common memory bugs.
Follow the steps below to install MTE_test.apk on your Google Pixel 8:
Navigate to this repository . Open the “apk” folder and click on “MTE_test.apk” file. Use the download icon on the right to download the apk to your desktop machine.
Connect your Pixel 8 to the USB port.
Open a console and change the directory cd to where you downloaded the apk.
Execute the command adb devices. The console should display the list of attached devices.
Execute the command adb install MTE_test.apk. The console should display that the apk has been installed successfully.
You should now see the Android icon of the app with the name MTE_test on your phone.
