Check that
python3 reports a supported version (3.10, 3.11, or 3.12). Then install the listed system packages before setting up the examples.Use the
model_qat_example.ipynb notebook. It is the only example notebook that includes the export step to produce a .vgf file.Post-training quantization (PTQ) is faster to try because it calibrates an already-trained model. Quantization-aware training (QAT) simulates lower precision during fine-tuning to help preserve accuracy when exporting an INT8 model.
Expect a
.vgf model produced by the export pipeline. Open it in Model Explorer with the VGF adapter; a valid graph with layers, tensor shapes, and connectivity indicates a successful export.No. Model Explorer visualizes the network structure and execution graph, not rendered output quality. Use the evaluation notebook to compare model output with the ground truth.
