While NSS is a powerful demonstration of neural graphics, Model Gym is designed to support custom models for various use cases. You can add your own model architecture, register it with the toolkit, and run the same training, evaluation, and export workflows you used for NSS.
This section walks you through the process of integrating a custom model into Model Gym, using the Python API you used in previous sections.
To add a custom model to the Model Gym, you need to:
BaseNGModel@register_model() decoratorparams as a constructor argumentThe resulting structure looks like this:
from ng_model_gym.core.model.base_ng_model import BaseNGModel
from ng_model_gym.core.model.model_registry import register_model
from ng_model_gym.core.utils.config_model import ConfigModel
@register_model(name="custom_model", version="1")
class CustomModel(BaseNGModel):
def __init__(self, params: ConfigModel):
super().__init__(params)
# Define your model architecture here
def forward(self, x):
# Implement forward pass
pass
The @register_model() decorator makes your model discoverable by Model Gym. The name and version parameters will be used later in your configuration file.
For your model to be available in Model Gym, the file defining it must be imported. This triggers the registration process.
Place your model file in the src/ng_model_gym/usecases/ directory within the Model Gym installation. To find the installed location, make sure the virtual environment you used with the example notebooks is activated. Then, run the following:
whereis ng_model_gym
This should point to your nb-env virtual environment. The Model Gym source code in this case will sit in the following directory:
<path-to>/nb-env/lib/python3.12/site-packages/ng_model_gym/usecases
Each use case directory must contain an __init__.py file. To understand how the configuration files work, revisit the example notebooks for NSS in previous sections.
Verify registration succeeded by listing registered models:
from ng_model_gym.core.model.model_registry import MODEL_REGISTRY
MODEL_REGISTRY.list_registered()
You’ve already worked with the configuration file in the training and evaluation notebooks. To use your custom model, update the same JSON configuration file to reference the model name and version you used when registering. You can generate a new config template with ng-model-gym init, or modify an existing one.
Update the model section:
"model": {
"name": "custom_model",
"version": "1"
If you’re working in Python, set these values programmatically:
import ng_model_gym as ngmg
from pathlib import Path
config = ngmg.load_config_file(Path("config.json"))
config.model.name = "custom_model"
config.model.version = "1"
Once your model is registered and your config is updated, you can use all the standard Model Gym workflows that were covered in previous sections. For example training:
trained_model_path = ngmg.do_training(config, training_mode=TrainEvalMode.FP32)
Your custom model will go through the same pipeline as NSS: training, quantization, evaluation, and export to .vgf format.
Similar to models, you can register custom datasets by marking your dataset class with the @register_dataset() decorator:
from torch.utils.data import Dataset
from ng_model_gym.core.data.dataset_registry import register_dataset
@register_dataset(name="custom_dataset", version="1")
class CustomDataset(Dataset):
def __init__(self, config):
# Initialize your dataset
pass
def __len__(self):
# Return dataset size
pass
def __getitem__(self, idx):
# Return a single sample
pass
Place the dataset implementation in the same usecases directory as your model. Then, update your configuration to use the custom dataset:
"dataset": {
"name": "custom_dataset",
"version": "1"
You can group related models, datasets, and configurations into custom use cases. This is useful when working on a specific neural graphics application. To understand what the final structure should look like, use the NSS use case as a reference implementation. Your use case logic executes when you specify its model and dataset in your configuration file.
The neural-graphics-model-gym-examples repository includes a walkthrough notebook called custom_model_example.ipynb. This notebook demonstrates:
To work through the example, follow the same process as before:
cd neural-graphics-model-gym-examples
source nb-env/bin/activate
jupyter lab
Navigate to tutorials/nss/custom_model_example.ipynb and step through the cells.
You’ve now learned how to extend Model Gym beyond NSS with your own models and datasets. This opens up possibilities for experimenting with different neural graphics techniques: denoising, frame interpolation, or custom upscaling approaches tailored to your content.
For more information on model registration, dataset integration, and use case development, see the Model Gym GitHub repository .
Through this Learning Path, you’ve learned what neural graphics is and why it matters for game performance. You’ve stepped through the process of training and evaluating a model using PyTorch and the Model Gym, and seen how to export that model into VGF (.vgf) for real-time deployment. You’ve also explored how to visualize and inspect the model’s structure using Model Explorer. You can now explore the Model Training Gym repository for deeper integration and to keep building your skills.
