Give feedback
AI-assisted
Close
What should I check before I run the notebooks on Ubuntu?
Use Ubuntu 22.04 with a CUDA-capable NVIDIA GPU, CUDA Toolkit 11.8 or later, and Python later than 3.10. Then, install the required dependency packages.
Where do I start the training after cloning the examples repository?
From neural-graphics-model-gym-examples, run jupyter lab. Open tutorials/nfru/nfru_training_example.ipynb and step through the notebook for training.
How do I know the initial training produced usable artifacts?
Create and inspect PyTorch checkpoints in the training and evaluation notebooks. In the evaluation notebook, you can measure accuracy, compare checkpoints, and see a visual comparison of the generated NFRU frame with the ground truth frame.
Should I use QAT or Post-training quantization (PTQ) for deployment?
Start with PTQ if you want a faster trial because it calibrates an already-trained model without another training phase. Use QAT when PTQ causes unacceptable accuracy or visual-quality regressions. QAT simulates lower-precision inference during fine-tuning and helps preserve accuracy when you quantize the model to INT8.
How do I export and inspect the deployable model?
Use the QAT notebook from the dedicated NFRU examples tag. The notebook includes the export step to produce a .vgf file. Then, open the .vgf file in Model Explorer with the VGF adapter to inspect architecture, tensor shapes, and graph connectivity.
Return to Mobile, Graphics, and Gaming
