Install dependencies on Ubuntu
Install a few machine learning and system dependencies on your Ubuntu environment.
Start by making sure Python is installed and the version is later than 3.10:
python3 --version
Next, install dependency packages:
sudo apt update
sudo apt install python3-venv python-is-python3 gcc make python3-dev -y
Set up the examples repository
The example notebooks are open-sourced in a GitHub repository.
Start by cloning the repository:
git clone https://github.com/arm/neural-graphics-model-gym-examples.git
cd neural-graphics-model-gym-examples
From inside the neural-graphics-model-gym-examples/ folder, run the environment creation script:
python create_env.py
The script does the following:
  • Creates a Python virtual environment called nb-env
  • Installs the ng-model-gym package and required dependencies
  • Downloads the datasets and weights needed to run the notebooks
Activate the virtual environment:
source nb-env/bin/activate
Run the following in a Python shell to confirm that the script was successful:
import torch
import ng_model_gym
print("Torch version:", torch.__version__)
print("Model Gym version:", ng_model_gym.__version__)
You’ve now completed your environment setup by installing dependencies and setting up the example NFRU notebooks repository.
Next, you’ll train the neural graphics model.
