What neural graphics is
Neural graphics is an intersection of graphics and machine learning. Rather than relying purely on traditional GPU pipelines, neural graphics integrates learned models directly into the rendering stack.
These techniques are particularly powerful on mobile devices, where battery life and performance constraints limit traditional compute-heavy rendering approaches. When developing for mobile devices, your goal is to deliver high visual fidelity without increasing GPU cost. You can achieve this by training and deploying compact neural networks optimized for your device’s hardware.
How Arm supports neural graphics
Arm supports neural graphics through the Neural Graphics Development Kit : a set of open-source tools that you can use to train, evaluate, and deploy ML models for graphics workloads.
At its core are the ML Extensions for Vulkan, which bring native ML inference into the GPU pipeline using structured compute graphs. These extensions (VK_ARM_tensors and VK_ARM_data_graph) allow real-time upscaling and similar effects to run efficiently alongside rendering tasks.
You can develop neural graphics models using well-known ML frameworks such as PyTorch, then export them for deployment with Arm’s hardware-aware pipeline. The workflow converts your model to .vgf using the TOSA intermediate representation, making it possible to tailor model development for your game use case.
In the following sections, you’ll focus on Neural Frame Rate Upscaling (NFRU) as the primary example for training, evaluating, and deploying neural models using the Neural Graphics Model Gym . Arm has also developed a set of Vulkan Samples to help you get started. The postprocessing_with_vgf sample introduces the .vgf format.
For a broader overview of neural graphics developer resources, including the Vulkan Samples, see the introductory Learning Path Get started with neural graphics using ML Extensions for Vulkan .
Arm GPUs are adding dedicated neural accelerators, optimized for low-latency inference in graphics workloads. To help you get started early, Arm provides the ML Emulation Layers for Vulkan that simulate neural accelerator behavior, so you can build and test models now.
What the Neural Graphics Model Gym is
The Neural Graphics Model Gym is an open-source toolkit for fine-tuning and exporting neural graphics models. It’s designed to streamline the entire model lifecycle for graphics-focused use cases such as NFRU.
With Model Gym, you can:
  • Train and evaluate models using a PyTorch-based API
  • Export models to .vgf using ExecuTorch for real-time use in game development
  • Take advantage of quantization-aware training (QAT) and post-training quantization (PTQ) with ExecuTorch
  • Use an optional Docker setup for reproducibility
You can use Python notebooks for rapid experimentation or the command-line interface for automation. In this Learning Path, you’ll use notebooks to train, fine-tune, export, and inspect an NFRU model.
You’ve now learned about neural graphics and Arm’s tools such as the Neural Graphics Model Gym that support neural graphics.
Next, you’ll set up your environment and start working with neural graphics models.
