Prepare artifacts from your ExecuTorch deployment
Use this workflow when your application runs an ExecuTorch program and you’ve already captured its profiling data in an ETDump file. MLIA reads the captured data and reports measured performance. The earlier LiteRT conversion and Scenario Runner steps don’t generate these artifacts.
Collect the following files from the same deployed program and model build:
ArtifactContents
model.etrecord or model.binRecorded model graphs and debug mappings generated during export
run.etdump or run.etdpOne matching runtime capture, including VGF profiling when enabled
model.pte (optional)The deployed program containing a VGF delegate, for companion graph associations
For artifact generation, see the ExecuTorch 1.5 profiling tutorial . For VGF-specific guidance, see VGF neural accelerator statistics in ETDump to enable statistics collection. The ExecuTorch 1.0 Arm VGF backend tutorial demonstrates building and running a VGF-delegated model with executor_runner. Use the compatible toolchain version specified in the installation steps when generating your artifacts.
VGF cycle analysis additionally requires VGF profiling data in the ETDump. An ordinary runtime-only capture can provide source timings, but it can’t provide VGF counters or companion VGF associations.
Run the remaining commands from mlia-demo. Copy your artifacts into a new et-profile directory and use the example filenames above, or substitute their paths in the commands. Keep the original files together so that you can confirm which export and execution produced them.
Install the ExecuTorch analysis support
Activate the environment from the setup page and install the Neural Technology executorch extra:
source mlia-venv/bin/activate
python -m pip install "mlia-neural-technology[executorch]==0.3.0" mlia-converters-pytorch==0.1.4
python -m pip check
This extra installs the shared ExecuTorch artifact readers from mlia-converters-pytorch. Neural Technology provides the runtime analysis, VGF decoding, and NX metrics. The converter package requires ExecuTorch 1.5.1; use compatible artifacts from that toolchain.
The expected output from pip check is No broken requirements found. Model Explorer is optional for the analysis itself.
Analyze the matching ETRecord and ETDump
Run a measured performance check:
mlia check et-profile/model.etrecord \
  --target-profile neural-technology \
  --performance \
  --profiling-data et-profile/run.etdump \
  --output-dir runs/executorch-measured
--profiling-data selects the measured backend automatically. Use performance analysis for this workflow; compatibility analysis belongs to the earlier model-based checks.
For an ETRecord with several methods, select the method that produced the dump. For example, append the following option for a method named decode:
--neural-technology-profiling-data.etrecord-method decode
Single-method selection is automatic. If method selection or graph mapping fails, check that the artifacts come from the same deployed program and selected method.
Inspect the saved results and warnings:
python - <<'PY'
import json
from pathlib import Path
report_path = Path("runs/executorch-measured/mlia-output/mlia-output.json")
report = json.loads(report_path.read_text())
results = [result for result in report["results"] if result["kind"] == "performance"]
assert results, "No performance results found. Review the MLIA log."
for result in results:
    assert result["status"] == "ok", "Review the performance result for errors."
    assert result.get("mode") == "measured", "Expected measured profiling data."
    print(json.dumps(result, indent=2))
PY
The check confirms that MLIA produced successful measured performance results and prints their metrics, breakdowns, and any warnings. Values depend on your capture. Check the reported execution coverage and decoder assumptions before treating cycle summaries as full-inference costs.
(Optional) Open the profiling views in Model Explorer
Use MLIA Model Explorer 0.2.0, which supports MLIA core 0.13.x. Install its executorch extra in the same environment, even if you installed the vgf extra during setup:
python -m pip install "mlia-model-explorer[executorch]==0.2.0"
python -m pip check
The extra includes ETRecord, PTE, and VGF adapters. After pip check succeeds, rerun the analysis into a separate directory and request a visualization:
  --performance \
  --output-dir runs/executorch-visualized \
  --model-explorer open
If you also have the matching deployed VGF-backed PTE and VGF profiling in the dump, append --companion-model et-profile/model.pte to add its compiler graph. Supplying a companion alone doesn’t enable visualization. Runtime-only captures support visualization without a companion.
Use --model-explorer files to generate the files without opening a browser. The standalone page is runs/executorch-visualized/mlia-output/model-explorer/bundle/index.html.
In Model Explorer, inspect the views available for your capture:
ViewWhat to inspect
Source ModelSource operators and available runtime timings
segment_cascade_chainCaptured NX hierarchy and cycle measurements
ETRecord Chain MappingChains associated with source operators; the initial detailed view when available
ETDump Backend TraceCompiler operations and their measured chain groups
PTE - VGF Backend HierarchyCompanion compiler graph and associated chain groups, when supplied
Select a mapped operator or group to navigate between related views. Compiler transformations can rename, insert, combine, or reorder operations, so some source links can be incomplete or absent. Unmatched compiler operations remain visible. A missing link doesn’t establish that an operation wasn’t executed or that its chain has no profiling data.
Interpret runtime timings and NX counters
Ordinary runtime timings use milliseconds. VGF counters use cycles and describe recorded accelerator activity. Cycle counters don’t reconstruct idle gaps or establish elapsed latency.
For older captures missing decoder metadata, MLIA assumes statistics mode 1 and the Mali-G2 device layout. Check the reported assumptions against your capture settings.
Repeated executions provide averages, minimum, maximum, P50, and execution counts where supported. Independent observations are combined within each recorded execution before summaries are calculated. Don’t add minimum, maximum, P50, or execution counts across operators. Averages can be combined only when their measurements are independent and cover the same executions.
A runtime event can cover several source operators. Each associated operator can display the same shared timing; that value isn’t an independent cost for each operator. VGF chain or cascade measurements can also cover several compiler operations. Use the authoritative hierarchy measurements and model-level results instead of summing every overlay or hierarchy level.
Mixed-backend dumps keep ordinary runtime timings separate from VGF counters. Instructions with VGF profiling are excluded from ordinary runtime aggregation to avoid counting the same work twice. Runtime event counts describe contributing event records, rather than the number of complete inferences.
MLIA doesn’t estimate missing measurements. If instructions or segments cover different executions, model cycle summaries can be unavailable with a warning while individual measurements remain available. Even matching coverage doesn’t prove every expected stripe was captured. Review warnings and, for older captures, any assumed statistics mode or device layout.
Companion matching checks structural compatibility and assumes you supplied the matching PTE. It doesn’t prove that the PTE produced the capture. Model Explorer checks that the companion file hasn’t changed since analysis; rerun analysis if it has.
What you’ve accomplished
You’ve analyzed an ExecuTorch ETRecord/ETDump pair and checked its measured results. With a compatible Model Explorer installation, you can also inspect runtime timings, NX hierarchy measurements, and optional companion graph associations.
Use the measured costs to select a model change to investigate. Repeat the capture under the same conditions and validate accuracy before drawing deployment conclusions.
