Profile a MobileNet model with Scenario Runner
Run the quantized MobileNet V1 0.25, 224 × 224 model on your neural accelerator (NX) device and inspect its measured cycles in MLIA. Scenario Runner executes the graph through the ML Extensions for Vulkan. The Neural Statistics layer captures accelerator counters for Arm ML Inference Advisor (MLIA) to analyze.
Use baseline.vgf from the baseline performance check and the supplied MobileNet scenario. The constant input exercises the graph but doesn’t test image-classification accuracy.
Verify adb and build Scenario Runner
Verify that Android Debug Bridge (adb) is available on your development host:
adb version
The output is similar to:
        Android Debug Bridge version 1.0.41
Version 36.0.2-14143358
On your device, enable Developer options and USB debugging, or Wireless debugging if you use a wireless connection. Authorize your development host when prompted, then verify the connection:
adb devices -l
The output is similar to this shortened example, with the serial number for your device:
        List of devices attached
<device-serial>  device
Your device should appear with the status device. If several devices are connected, set the ANDROID_SERIAL environment variable with export ANDROID_SERIAL="your-device-serial". Replace "your-device-serial" with the serial number for your device.
To build a debuggable Android arm64 APK, follow the Scenario Runner 0.11.0 Android build instructions . This experimental build needs the Android NDK, Android SDK, Gradle, and public SDK source dependencies. Use Scenario Runner and Vulkan Graph Format (VGF) Library release/v0.11.0 for this example.
Run the Android build command from mlia-demo and add --package-version 0.11.0. This ensures that the generated APK has the fixed filename used in subsequent commands.
Complete the following steps to configure the public Neural Statistics layer for the unmodified runner. You’ll turn on Enable GPU debug layers, select the runner application, and activate VK_LAYER_LGL_neural_statistics through adb.
Prepare the baseline scenario on the host
Run the remaining host commands from mlia-demo in the same Bash shell.
Create a separate environment for NumPy, copy the compiled model as baseline.vgf, and download the ready-made MobileNet scenario :
python3.12 -m venv nx-tools-venv
source nx-tools-venv/bin/activate
python -m pip install numpy==2.2.6
python -m pip check
mkdir -p nx-demo
cp runs/baseline/mlia-output/ml-sdk-model-converter/baseline.tosa.vgf nx-demo/baseline.vgf
curl -fL https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/mlia-nx-performance-estimator/mobilenet-scenario.json -o nx-demo/scenario.json
The scenario binds baseline.vgf to an unsigned eight-bit input with shape [1, 224, 224, 3] and an unsigned eight-bit output with shape [1, 1001]. It reads input.npy, executes one graph dispatch, and writes output.npy. These paths are relative to the scenario file, so keep the three workload files together.
Create the synthetic input tensor filled with the value 128:
python - <<'PY'
import numpy as np
input_data = np.full((1, 224, 224, 3), 128, dtype=np.uint8)
np.save("nx-demo/input.npy", input_data)
print(f"Input shape: {input_data.shape}; dtype: {input_data.dtype}")
PY
The expected output is:
        Input shape: (1, 224, 224, 3); dtype: uint8
Install the APK and transfer the workload
From mlia-demo, install the debug APK from the generated apk_package directory:
adb install -r apk_package/app/build/outputs/apk/debug/ai-ml-sdk-scenario-runner-0.11.0-debug.apk
        Success
Pack the three workload files into an archive, then stream it into application storage. run-as accesses the debuggable runner files without root:
PACKAGE=com.arm.ai_ml_sdk_scenario_runner
adb shell run-as "$PACKAGE" mkdir -p files/nx-demo
tar -cf nx-demo/workload.tar -C nx-demo baseline.vgf scenario.json input.npy
adb shell -T "run-as $PACKAGE tar -xf - -C files/nx-demo" < nx-demo/workload.tar
Download and install the capture layer
Download the public Android arm64 layer release:
curl -fL https://github.com/arm/vulkan-layer-neural-statistics/releases/download/v1.0.0/VkLayerNeuralStatistics-android-arm64-v8a.tar.gz -o nx-demo/neural-statistics-layer.tar.gz
tar -xzf nx-demo/neural-statistics-layer.tar.gz -C nx-demo
Copy the library into the runner application-owned data directory:
adb shell -T "run-as $PACKAGE sh -c 'cat > libVkLayerNeuralStatistics.so'" < nx-demo/VkLayerNeuralStatistics-android-arm64-v8a/libVkLayerNeuralStatistics.so
Android loads this library from the runner data directory.
Configure one measured dispatch
Mode 1 collects neural statistics, and filter 0 selects the first executed dispatch. Configure the layer for the runner application:
Note
Each capture needs a new directory. The timestamp supplies one. GPU debug-layer settings persist and can affect later app runs. Preserve any existing debug configuration that you need, and restore it or disable the layer when you’re finished.
CAPTURE_NAME="neural-statistics-capture-$(date +%Y%m%d-%H%M%S)"
cat > nx-demo/vk_layer_settings.txt <<EOF
lgl_neural_statistics.capture_folder = /data/data/$PACKAGE/files/$CAPTURE_NAME
lgl_neural_statistics.statistics_mode = 1
lgl_neural_statistics.dispatch_filter = 0
EOF
SETTINGS_PATH="/data/local/tmp/$CAPTURE_NAME-settings.txt"
adb push nx-demo/vk_layer_settings.txt "$SETTINGS_PATH"
adb shell chmod a+r "$SETTINGS_PATH"
adb shell settings put global enable_gpu_debug_layers 1
adb shell settings put global gpu_debug_app "$PACKAGE"
adb shell settings put global gpu_debug_layer_app "$PACKAGE"
adb shell settings put global gpu_debug_layers VK_LAYER_LGL_neural_statistics
adb shell setprop debug.vulkan.khronos_profiles.settings_path "$SETTINGS_PATH"
The layer writes the capture into the runner application-owned storage. For more information about the format of the generated files, see the public layer settings and capture format .
Run the graph with capture enabled
Start the runner foreground service:
DEVICE_DIR="/data/data/$PACKAGE/files/nx-demo"
RUN_ARGS="--scenario,$DEVICE_DIR/scenario.json,--profiling-dump-path,$DEVICE_DIR/profiling.json,--repeat,1"
adb shell am force-stop "$PACKAGE"
adb shell am start-foreground-service -n "$PACKAGE/.Main" --esa args "$RUN_ARGS"
adb logcat -s ScenarioService ScenarioRunner VkLayerNeuralStatistics vulkan AndroidRuntime
The Android --esa args option passes the comma-separated RUN_ARGS values as command-line arguments for the runner. The profiling file collects Vulkan timestamps separately from the neural statistics capture.
The successful run includes the following log message:
        native exit code=0
Stop adb logcat by pressing Ctrl+C after this message appears. A nonzero code or a runScenarioRunner failed message means that the run failed. Exit code 0 confirms runner completion. The capture checks that the layer collected neural statistics from the driver.
After the workload completes, retrieve its timestamp profiling and complete capture tree:
adb exec-out run-as "$PACKAGE" cat files/nx-demo/profiling.json > nx-demo/profiling.json
adb exec-out run-as "$PACKAGE" tar -C files -cf - "$CAPTURE_NAME" > nx-demo/neural-statistics-capture.tar
mkdir -p nx-demo/captures
tar -xf nx-demo/neural-statistics-capture.tar -C nx-demo/captures
Ordinary adb pull can’t traverse application-owned capture storage. Streaming a tar archive through run-as preserves the hierarchy and its metadata without root access.
Check capture completion
Inspect the capture metadata and locate the nonempty mode-1 statistics file:
python -m json.tool "nx-demo/captures/$CAPTURE_NAME/capture.json"
find "nx-demo/captures/$CAPTURE_NAME" -name statistics_mode1.bin -size +0c
In capture.json, check that schema_version is 2, status is complete, and capture.statistics_mode is 1. Review any warnings. For this single-dispatch scenario, the find command should print one path similar to:
        nx-demo/captures/<capture-name>/pipeline_000000/session_000000/dispatch_000000/statistics_mode1.bin
A completed capture with a nonempty statistics file shows that the layer intercepted the dispatch and the driver returned neural statistics. If the capture is missing, incomplete, or has no statistics payload, check the layer configuration and driver diagnostics before continuing.
Analyze measured data with MLIA
Return to the MLIA environment and pass the same VGF file with the complete capture directory:
source mlia-venv/bin/activate
mlia check nx-demo/baseline.vgf \
  --target-profile neural-technology \
  --performance \
  --profiling-data "nx-demo/captures/$CAPTURE_NAME" \
  --output-dir runs/baseline-measured
The following abbreviated output comes from a device capture of this MobileNet scenario:
        Result 1: Performance
Status   ok
Producer neural-technology-profiling-data
Mode     measured
Metrics:
│ Metric         │ Value  │ Unit   │
│ total_cycles   │ 951154 │ cycles │
│ compute_cycles │ 951154 │ cycles │
Your cycle counts will depend on your device and its configuration.
Status ok confirms that MLIA analyzed the capture. The full results are saved in runs/baseline-measured/mlia-output/mlia-output.json.
To inspect measured NX performance in Model Explorer and trace costs to Python source, follow Capture and analyze NX profiling data with MLIA for VS Code .
(Optional) Explore measured performance and TOSA operations
After installing the compatible Model Explorer plugin in Set up your MLIA environment , rerun the measured analysis with the same VGF and complete capture directory:
  --performance \
  --output-dir runs/baseline-measured-visualized \
  --model-explorer open
View measured cycle counts
The command opens Model Explorer with the capture’s results already loaded. In the generated MLIA hierarchy, select a cycle metric using the node-data controls. Expand the hierarchy and select an entity to inspect its reported cycle count. Follow the source mapping, where available, to see related operations in Source Model.
A source mapping associates operations with measured execution groups. It doesn’t necessarily provide an independent cycle measurement for each operation. Several operations can share the same group measurement, so don’t sum their displayed cycle counts as separate costs.
These overlays show the capture’s measurements. Only entities with reported metrics have values; a missing value doesn’t mean zero cycles. The 951,154 cycles in the reference CLI output describe the whole-model result, rather than the selected convolution.
MLIA saves the visualization in runs/baseline-measured-visualized/mlia-output/model-explorer/bundle/index.html. Open this self-contained file to revisit or share the results without rerunning the capture or starting a server.
Inspect a TOSA convolution
In Source Model, inspect nx-demo/baseline.vgf. The reference graph contains 103 nodes. Expand graph_segment_0 and select the first CONV2D node, between two RESCALE nodes. Your graph can differ with compiler or package changes.
This view exposes the TOSA operations in the VGF graph. You can see how the original MobileNet layer is represented after MLIA’s LiteRT-to-TOSA conversion and VGF generation. The screenshot shows the operation’s attributes.
Image Alt Text:Model Explorer shows a TOSA CONV2D operation between two RESCALE nodes in baseline.vgf. The Attributes panel links to the TOSA CONV2D specification and shows the MobileNet source location, connecting the converted operation to its definition and original model.Inspect a TOSA convolution in the VGF graph
In ATTRIBUTES, opcode identifies the TOSA operation as CONV2D. Select TOSA spec: CONV2D in the spec field to open the operator definition. Compare it with the values shown for this node:
FieldValue in the reference graphWhat it tells you
result typeuint32[1, 112, 112, 8]The intermediate tensor has a batch size of one, 112 × 112 spatial dimensions, and eight channels.
arg1 strideint32[2, 2]A stride of two reduces the 224 × 224 input to 112 × 112.
debug infoMobilenetV1/MobilenetV1/Conv2d_0/Relu6Relates the TOSA operation to its source location in MobileNet. Expand the field to read the full name.
Select the following RESCALE node to inspect how TOSA scales the convolution’s intermediate integer result into the output’s quantized range. Search for DEPTHWISE_CONV2D and follow its specification link to compare the two convolution operators.
Use the measurements
mlia-output.json shows accelerator cycles and benchmark.json shows graph execution times. Use both measurements when comparing your next model version on the same device.
Check the predictions on real images as well. A faster model isn’t useful if it misses your accuracy target.
What you’ve accomplished
You’ve run the VGF file on an NX-capable device, checked that Scenario Runner completed, and confirmed that the neural statistics capture contains data. You’ve also returned the capture to MLIA for measured analysis.
Use this evidence alongside model accuracy tests and end-to-end application profiling before making deployment decisions for your own use cases.
If your deployment uses ExecuTorch, continue with Analyze ExecuTorch ETRecord and ETDump profiling using artifacts from that deployed program.
