Choose a model change to investigate
The baseline report shows that memory traffic contributes substantially to estimated cycles. A smaller input reduces intermediate activation sizes and convolution work, so it’s a useful candidate to evaluate.
Use the public mobilenet_v1_0.25_128_quant.tflite variant. It keeps the MobileNet V1 family and 0.25 width multiplier but uses [1, 128, 128, 3] input instead of [1, 224, 224, 3]. Both variants use batch size one and quantized eight-bit tensors.
Download the smaller variant
From the same mlia-demo directory, download the versioned model archive and verify the extracted file:
curl -fL https://storage.googleapis.com/download.tensorflow.org/models/mobilenet_v1_2018_08_02/mobilenet_v1_0.25_128_quant.tgz -o models/smaller.tgz
tar -xzf models/smaller.tgz -C models ./mobilenet_v1_0.25_128_quant.tflite
mv models/mobilenet_v1_0.25_128_quant.tflite models/smaller.tflite
echo "3799e7cdb3ec44beacaf47ef5c884111c919e51bb50b34ac836244b08d4b953b  models/smaller.tflite" | sha256sum --check
The checksum check reports models/smaller.tflite: OK. Pass this file directly to Arm ML Inference Advisor (MLIA), as you did for the baseline.
Recheck compatibility and performance
Keep the neural-technology target profile for both checks. MLIA selects the same backend automatically:
mlia check models/smaller.tflite --target-profile neural-technology --compatibility --output-dir runs/smaller-compatibility
mlia check models/smaller.tflite --target-profile neural-technology --performance --output-dir runs/smaller
Compare standardized metrics
Validate the compatibility and performance status of both variants, then calculate the changes from your own reports:
python - <<'PY'
import json
from pathlib import Path
def load_result(run, kind):
    path = Path("runs") / run / "mlia-output" / "mlia-output.json"
    report = json.loads(path.read_text())
    result = next(result for result in report["results"] if result["kind"] == kind)
    assert result["status"] == "ok", f"Review the {run} report."
    if kind == "compatibility":
        assert all(check["status"] == "pass" for check in result["checks"]), f"Review the {run} checks."
    return {metric["name"]: metric["value"] for metric in result["metrics"] if "value" in metric}
for run in ("baseline-compatibility", "smaller-compatibility"):
    load_result(run, "compatibility")
baseline = load_result("baseline", "performance")
smaller = load_result("smaller", "performance")
for name in ("total_cycles", "inference_time", "inferences_per_second", "dram_cycles"):
    before, after = baseline[name], smaller[name]
    change = (after / before - 1) * 100
    print(f"{name}: {before:.5f} -> {after:.5f} ({change:+.2f}%)")
PY
The following table contains reference results recorded with Neural Technology 0.2.0 and LiteRT converter 0.1.2. Compare your own reports after installing the updated packages:
MetricBaseline, 224 × 224Smaller, 128 × 128Change
Total cycles136,96279,824-41.72%
Inference time (ms)0.091310.05322-41.72%
Inferences per second10,951.9418,791.34+71.58%
DRAM cycles94,39645,981-51.29%
Fewer cycles, shorter inference times, and higher throughput indicate better performance. However, these are separately trained public model variants. Their weights and quantization parameters differ.
The TensorFlow model catalog reports lower ImageNet accuracy for the smaller variant, so don’t choose a model on performance alone. Validate task accuracy, preprocessing, and runtime behavior on representative data before deployment to confirm that the model meets your requirements.
You’ve analyzed two public LiteRT models directly with MLIA and compared their neural acceleration (NX) performance estimates under the same target profile. For your own model, keep the target profile fixed while checking each change. Validate the accuracy and runtime behavior of the model before deployment.
If you have compatible hardware, continue to (Optional) Run and profile the model on an NX device . Otherwise, you’ve completed the estimator workflow and can extend it to models and profiles of your choice.
