Estimate baseline performance
Run a performance check with the same model and target profile:
mlia check models/baseline.tflite --target-profile neural-technology --performance --output-dir runs/baseline
The reference run with Neural Technology 0.2.0, LiteRT converter 0.1.2, and the neural-technology profile produced an estimated 136,962 total cycles and about 0.09131 ms per inference. The setup now uses Neural Technology 0.3.0 and LiteRT converter 0.1.3; use your generated report for the current result. These figures are compiler estimates, rather than timings measured on a device.
Locate and read the reports
With --output-dir runs/baseline, the following files are important:
Path under runs/baseline/mlia-output/Purpose
mlia-output.jsonStandardized Arm ML Inference Advisor (MLIA) result, including model metadata, metrics, entities, breakdowns, and advice
nx_performance_statistics.jsonDetailed chain and cascade performance statistics
nx-performance-estimator/Estimator summaries and raw performance, timing, and debug databases
ml-sdk-model-converter/Tensor Operator Set Architecture (TOSA) intermediates and baseline.tosa.vgf, produced automatically from the LiteRT model
logs/mlia.logAnalysis and diagnostic log
By default, MLIA writes to mlia-output in the current directory, with the report in mlia-output.json.
Read the main cycle and inference estimates:
python - <<'PY'
import json
from pathlib import Path
report = json.loads(Path("runs/baseline/mlia-output/mlia-output.json").read_text())
result = next(result for result in report["results"] if result["kind"] == "performance")
assert result["status"] == "ok", "Review the performance report for errors."
metrics = {metric["name"]: metric for metric in result["metrics"]}
for name in ("total_cycles", "compute_cycles", "dram_cycles", "inference_time", "inferences_per_second"):
    metric = metrics[name]
    print(f"{name}: {metric['value']:.6g} {metric['unit']}")
PY
The reference output is:
        total_cycles: 136962 cycles
compute_cycles: 34976 cycles
dram_cycles: 94396 cycles
inference_time: 0.091308 ms
inferences_per_second: 10951.9 inferences/s
The full report also includes target_utilization, memory traffic, and compiled size.
For the baseline, dram_cycles is 94,396, compared with 34,976 compute cycles. This gives you a reason to investigate memory traffic.
Use results[].breakdowns and their entity_id links to results[].entities to inspect individual chains and cascades. These are compiler scheduling groups. They’re not necessarily one framework layer each. Source-operator provenance helps you relate those groups to the original graph. Some metrics overlap or use non-additive aggregation policies, so don’t sum every breakdown to recreate the model total.
(Optional) Explore results in Model Explorer
After installing the compatible Model Explorer plugin in Set up your MLIA environment , rerun the check into a separate directory with visualization enabled:
mlia check models/baseline.tflite \
  --target-profile neural-technology \
  --performance \
  --output-dir runs/baseline-visualized \
  --model-explorer open
--model-explorer open creates a self-contained HTML visualization and opens it in your browser. Use --model-explorer files to generate the files without opening a browser. If the browser doesn’t open, open runs/baseline-visualized/mlia-output/model-explorer/bundle/index.html manually.
Inspect the generated MLIA hierarchy alongside Source Model:
  1. Select a cycle metric in the node-data controls to color the hierarchy by cost.
  2. Expand the hierarchy and select a chain or cascade to read its reported values.
  3. Follow its mapping to Source Model, where available, to find the related model operations.
Use these overlays to find scheduling groups worth investigating. A group can contain several operations, so its cost isn’t a separate measurement for each operation. Keep using the model-level report for whole-model totals.
For the editor workflow, follow the Ethos-U VS Code and Model Explorer walkthrough . Its example uses Ethos-U and Vela; use the NX metrics from this analysis when exploring your results.
(Optional) Compare a different built-in profile
Keep the model unchanged when exploring a different target configuration. For example, run the peak profile into its own directory:
mlia check models/baseline.tflite --target-profile NX-peak-12SC-8NX-600MHz --performance --output-dir runs/baseline-peak
Differences in performance reflect the system and compiler assumptions of the profile. The performance differences don’t reflect a model optimization.
You’ve collected baseline estimates and distinguished model metrics from scheduling breakdowns.
Next, you’ll evaluate a smaller public model under the neural-technology profile and compare the results.
