Check the baseline operators
Pass models/baseline.tflite to Arm ML Inference Advisor (MLIA). It converts the model automatically and selects the backend for the neural-technology target profile.
License
On your first check, MLIA offers to install the bundled neural acceleration (NX) Performance Estimator. Confirm installation when prompted, then read its Arm license and continue only if you agree. If the backend is already installed, MLIA skips this setup.
Run the compatibility check:
mlia check models/baseline.tflite --target-profile neural-technology --compatibility --output-dir runs/baseline-compatibility
Each check writes to its own directory under runs, created during the model download.
The standardized report is written to runs/baseline-compatibility/mlia-output/mlia-output.json. Read the compatibility result and validate its status:
python - <<'PY'
import json
from pathlib import Path
report = json.loads(Path("runs/baseline-compatibility/mlia-output/mlia-output.json").read_text())
result = next(result for result in report["results"] if result["kind"] == "compatibility")
failed_checks = [check for check in result.get("checks", []) if check["status"] != "pass"]
print(f"Compatibility status: {result['status']}")
print(f"Non-passing checks: {len(failed_checks)}")
assert result["status"] == "ok", "Review the compatibility report before estimating performance."
assert not failed_checks, "Review the non-passing operator checks."
PY
The reference output for the baseline is:
        Compatibility status: ok
Non-passing checks: 0
Interpret the compatibility result
The compatibility result includes checks, source-operator entities, and metrics. For this model, accelerator_operator_percentage is 100.0. MLIA reports ml-sdk-model-converter as the compatibility producer because operator support is checked during conversion.
A passing result means that this graph can proceed through the supported conversion flow. It doesn’t establish classification accuracy, guarantee a deployable application, or measure device performance.
If a check fails, inspect the non-passing checks and linked entities of the report. Verify that you’re analyzing models/baseline.tflite and that both plugins from the environment setup are installed.
You’ve checked the operator compatibility of the baseline without a manual conversion step.
Next, you’ll collect performance estimates and inspect their breakdowns.
