Perform an environment check
Use an x86-64 Ubuntu 24.04 LTS development host with CPython 3.12. The mlia-neural-technology version 0.3.0 wheel is published for CPython 3.12 on x86-64 Linux with glibc version 2.39 or later. Ubuntu 22.04, other Python versions, native macOS, and native Linux on Arm aren’t supported by this wheel.
Check your architecture, Python version, and glibc version:
uname -m
python3.12 --version
getconf GNU_LIBC_VERSION
The expected architecture is x86_64, Python is 3.12.x, and glibc is at least 2.39.
You’ll also need permission to install Ubuntu packages and internet access to PyPI and TensorFlow public model downloads.
Install the public packages
Install the Ubuntu packages needed to create an environment and download the models:
sudo apt update
sudo apt install -y python3.12-venv curl ca-certificates
Create a working directory mlia-demo and a clean virtual environment. Run subsequent commands from mlia-demo unless stated otherwise:
mkdir -p mlia-demo
cd mlia-demo
python3.12 -m venv mlia-venv
source mlia-venv/bin/activate
python -m pip install --upgrade pip
python -m pip install mlia==0.13.0 mlia-neural-technology==0.3.0 mlia-converters-litert==0.1.3
python -m pip check
These are public PyPI packages. The Neural Technology plugin installs the following tools as dependencies:
  • A compatible Arm ML Inference Advisor (MLIA) core
  • The ML SDK Model Converter
  • Tensor Operator Set Architecture (TOSA) tools
The LiteRT converter plugin lets MLIA analyze .tflite files directly. You don’t need TensorFlow, a GPU driver, or a separate model-training environment for this example.
Neural Technology 0.3.0 requires MLIA core 0.13.x. LiteRT converter 0.1.3 supports this core version. Upgrade these packages together when reusing an existing environment.
The expected output is:
        No broken requirements found.
Discover profiles and backends
Verify the CLI and inspect the installed capabilities:
mlia --help
mlia target list
mlia backend list
Confirm that the target list includes neural-technology and both NX-peak-12SC-8NX-600MHz and NX-sustained-12SC-8NX-350MHz. The backend list includes nx-performance-estimator. Before backend installation, its installed status is no and its installable status is yes.
The estimator executable is bundled with the public wheel. MLIA offers to install it during your first check, so you don’t need a separate backend installation command.
Note
If pip reports that no matching distribution exists for mlia-neural-technology, check the three host requirements again and upgrade pip inside the environment. A virtual environment doesn’t change the host architecture or glibc version. Don’t substitute an older Python version or Ubuntu 22.04 for this release.
(Optional) Prepare Model Explorer visualizations
The MLIA Model Explorer plugin adds graph visualizations with performance overlays. Version 0.2.0 supports MLIA core 0.13.x. The vgf extra includes the adapter for the compiled model you’ll inspect later. The plugin generates a standalone HTML page that you can open directly in your browser. You don’t need to install Model Explorer separately or run additional services.
Install the plugin in the same environment:
python -m pip install "mlia-model-explorer[vgf]==0.2.0"
python -m pip check
The expected output from pip check is No broken requirements found. The ExecuTorch profiling steps install an additional extra for ETRecord and PTE adapters.
You’ve installed MLIA with the Neural Technology and LiteRT converter plugins.
Next, you’ll download a pretrained MobileNet baseline to analyze with MLIA.
