Set up your environment
Cross-Compile ExecuTorch for the AArch64 platform
Accelerate ExecuTorch operators with KleidiAI micro-kernels
Create and quantize linear layer benchmark model
Create and quantize convolution layer benchmark model
Create matrix multiply layer benchmark model
Run model and generate the ETDump
Analyze ETRecord and ETDump
The batch matrix multiply operator (torch.bmm) is commonly used for efficient matrix operations in deep learning models. When running on Arm systems with XNNPACK, this operator is lowered to a general matrix multiplication (GEMM) implementation. If your input shapes and data types match supported patterns, XNNPACK can automatically dispatch these operations to KleidiAI micro-kernels, which are optimized for Arm hardware.
To compare the performance of different GEMM variants on various Arm platforms, you’ll build a set of benchmark models. These models use the batch matrix multiply operator and allow you to evaluate how each GEMM implementation performs, helping you identify the best configuration for your workload.
The following example defines a simple model to generate nodes that can be accelerated by KleidiAI.
By adjusting the input parameters, this model can also simulate the behavior of nodes commonly found in real-world models:
class DemoBatchMatMulModel(nn.Module):
def forward(self, x,y):
return torch.bmm(x, y)
def get_example_inputs(self,dtype=torch.float32):
return (torch.randn(1, 256, 256, dtype=dtype),torch.randn(1, 256, 256, dtype=dtype))
| XNNPACK GEMM Variant | Input A DataType | Input B DataType | Output DataType |
| pf32_gemm | FP32 | FP32 | FP32 |
| pf16_gemm | FP16 | FP16 | FP16 |
The following code snippet demonstrates how to lower the model that leverages the pf16_gemm and pf32_gemm variant to accelerate computation:
from executorch.backends.xnnpack.partition.xnnpack_partitioner import XnnpackPartitioner
from executorch.backends.xnnpack.partition.config.xnnpack_config import ConfigPrecisionType
from executorch.exir import to_edge_transform_and_lower
def export_mutrix_mul_model(dtype: torch.dtype, model_name: str):
mode_file_name = "model/" + model_name
pte_file = mode_file_name + ".pte"
etr_file = mode_file_name + ".etrecord"
model = DemoBatchMatMulModel().eval().to(dtype)
example_inputs = model.get_example_inputs(dtype)
exported_program = torch.export.export(model, example_inputs)
partitioner = XnnpackPartitioner()
edge_program = to_edge_transform_and_lower(
exported_program,
partitioner=[partitioner],
generate_etrecord=True
et_program = edge_program.to_executorch()
with open(pte_file, "wb") as f:
f.write(et_program.buffer)
# Get and save ETRecord
etrecord = et_program.get_etrecord()
etrecord.save(etr_file)
export_mutrix_mul_model(torch.float16,"matrix_mul_pf16_gemm")
export_mutrix_mul_model(torch.float32,"matrix_mul_pf32_gemm")
When exporting models, the generate_etrecord option is enabled to produce the .etrecord file alongside the .pte model file. These ETRecord files are essential for subsequent model analysis and performance evaluation.
Instead of executing each export block manually, you can download and run the full matrix-multiply benchmark script. This script automatically builds and exports both FP16 and FP32 models, performing all necessary partitioning, lowering, and ETRecord generation:
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/measure-kleidiai-kernel-performance-on-executorch/export-matrix-mul.py
chmod +x export-matrix-mul.py
python3 ./export-matrix-mul.py
After running this script, both the PTE model file and the etrecord file are generated.
$ ls model/ -1
model/matrix_mul_pf16_gemm.etrecord
model/matrix_mul_pf16_gemm.pte
model/matrix_mul_pf32_gemm.etrecord
model/matrix_mul_pf32_gemm.pte
These files are the inputs for upcoming executor_runner benchmarks, where you’ll measure and compare KleidiAI micro-kernel performance.
The complete source code is available.
