Set up your environment
Cross-Compile ExecuTorch for the AArch64 platform
Accelerate ExecuTorch operators with KleidiAI micro-kernels
Create and quantize linear layer benchmark model
Create and quantize convolution layer benchmark model
Create matrix multiply layer benchmark model
Run model and generate the ETDump
Analyze ETRecord and ETDump
In the previous section, you saw that that both INT8-quantized Conv2d and pointwise (1×1) Conv2d operators can be accelerated using KleidiAI’s matrix-multiplication micro-kernels.
| XNNPACK GEMM Variant | Input DataType | Filter DataType | Output DataType |
| pqs8_qc8w_gemm | Asymmetric INT8 quantization(NHWC) | Per-channel or per-tensor symmetric INT8 quantization | Asymmetric INT8 quantization(NHWC) |
| pf32_gemm | FP32 | FP32, pointwise (1×1) | FP32 |
To evaluate the performance of Conv2d operators across multiple hardware platforms, you will create a set of benchmark models that utilize different GEMM implementation variants within the convolution operators for systematic comparative analysis.
The following example defines a simple model to generate INT8-quantized Conv2d nodes that can be accelerated by KleidiAI.
By adjusting some of the model’s input parameters, you can also simulate the behavior of nodes that appear in real-world models.
import torch
import torch.nn as nn
class DemoQInt8Conv2dModel(torch.nn.Module):
def __init__(self):
super().__init__()
self.conv = torch.nn.Conv2d(3, 6, 3)
def forward(self,x):
x = self.conv(x)
return x
def get_example_inputs(self,dtype=torch.float32):
return (torch.randn(1, 3, 16, 16, dtype=dtype),)
The following code can be used to quantize and export the model:
from executorch.backends.xnnpack.partition.xnnpack_partitioner import XnnpackPartitioner
from executorch.backends.xnnpack.partition.config.xnnpack_config import ConfigPrecisionType
from executorch.exir import to_edge_transform_and_lower
from torchao.quantization.pt2e.quantize_pt2e import convert_pt2e, prepare_pt2e
from executorch.backends.xnnpack.quantizer.xnnpack_quantizer import (
get_symmetric_quantization_config,
XNNPACKQuantizer,
def export_int8_quantize_conv2d_model(model_name: str):
mode_file_name = "model/" + model_name
pte_file = mode_file_name + ".pte"
etr_file = mode_file_name + ".etrecord"
model = DemoQInt8Conv2dModel().eval().to(torch.float32)
example_inputs = model.get_example_inputs(torch.float32)
#Quantizer model
model = torch.export.export(model, example_inputs).module()
quantizer = XNNPACKQuantizer()
operator_config = get_symmetric_quantization_config(
is_per_channel=False,
is_dynamic=False
quantizer.set_global(operator_config)
quantize_model = prepare_pt2e(model, quantizer)
quantize_model(*example_inputs)
quantize_model = convert_pt2e(quantize_model)
#export model
exported_program = torch.export.export(quantize_model, example_inputs)
partitioner = XnnpackPartitioner()
edge_program = to_edge_transform_and_lower(
exported_program,
partitioner=[partitioner],
generate_etrecord=True
et_program = edge_program.to_executorch()
with open(pte_file, "wb") as f:
f.write(et_program.buffer)
# Get and save ETRecord
etrecord = et_program.get_etrecord()
etrecord.save(etr_file)
export_int8_quantize_conv2d_model("qint8_conv2d_pqs8_qc8w_gemm");
In the following example model, you will use simple model to generate pointwise Conv2d nodes that can be accelerated by Kleidiai.
As before, input parameters can be adjusted to simulate real-world model behavior.
import torch
class DemoConv2dModel(torch.nn.Module):
def __init__(self):
super().__init__()
self.pointwiseconv = torch.nn.Conv2d(3, 2, 1,groups=1)
x = self.pointwiseconv(x)
return x
The following code can be used to lower and export the model:
def export_pointwise_model(model_name: str):
model = DemoConv2dModel().eval().to(torch.float32)
exported_program = torch.export.export(model, example_inputs)
exported_program,
export_pointwise_model("pointwise_conv2d_pf32_gemm")
When exporting models, the generate_etrecord option is enabled to produce the .etrecord file alongside the .pte model file. These ETRecord files are essential for subsequent model analysis and performance evaluation.
Rather than executing each block by hand, download and run the full export script. It will generate both Conv2d variants, run quantization (INT8) where applicable, partition to XNNPACK, lower, and export to ExecuTorch .pte together with .etrecord metadata.
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/measure-kleidiai-kernel-performance-on-executorch/export-conv2d.py
chmod +x export-conv2d.py
python3 ./export-conv2d.py
After running this script, both the PTE model file and the etrecord file are generated.
$ ls model/ -1
qint8_conv2d_pqs8_qc8w_gemm.etrecord
qint8_conv2d_pqs8_qc8w_gemm.pte
pointwise_conv2d_pf32_gemm.etrecord
pointwise_conv2d_pf32_gemm.pte
