Set up your environment
Cross-Compile ExecuTorch for the AArch64 platform
Accelerate ExecuTorch operators with KleidiAI micro-kernels
Create and quantize linear layer benchmark model
Create and quantize convolution layer benchmark model
Create matrix multiply layer benchmark model
Run model and generate the ETDump
Analyze ETRecord and ETDump
In the previous section, you saw that the Fully Connected operator supports multiple GEMM (General Matrix Multiplication) variants.
To evaluate the performance of these variants across different hardware platforms, you will construct a series of benchmark models that utilize the Fully Connected operator with different GEMM implementations for comparative analysis.
These models will be used later with executor_runner to measure throughput, latency, and ETDump traces for various KleidiAI micro-kernels.
This step can be confusing at first, but building a minimal model helps you focus on the core operator performance. You’ll be able to quickly test different GEMM implementations and see how each one performs on Arm-based hardware. If you run into errors, check that your PyTorch and ExecuTorch versions are up to date and that you’re using the correct data types for your target GEMM variant. By adjusting some of the model’s input parameters, we can also simulate the behavior of nodes that appear in real-world models.
import torch
import torch.nn as nn
class DemoLinearModel(torch.nn.Module):
def __init__(self):
super().__init__()
self.linear = torch.nn.Linear(256,256)
def forward(self, x):
y = self.linear(x)
return y
def get_example_inputs(self,dtype=torch.float32):
return (torch.randn(1, 256, dtype=dtype),)
This model creates a single 256×256 linear layer, which can easily be exported in different data types (FP32, FP16, INT8, INT4) to match KleidiAI’s GEMM variants.
| XNNPACK GEMM Variant | Activations DataType | Weights DataType | Output DataType |
| pf16_gemm | FP16 | FP16 | FP16 |
| pf32_gemm | FP32 | FP32 | FP32 |
The following code demonstrates how to lower and export a model that leverages the pf16_gemm variant to accelerate computation:
from executorch.backends.xnnpack.partition.xnnpack_partitioner import XnnpackPartitioner
from executorch.backends.xnnpack.partition.config.xnnpack_config import ConfigPrecisionType
from executorch.exir import to_edge_transform_and_lower
def export_executorch_model(dtype: torch.dtype, model_name: str):
mode_file_name = "model/" + model_name
pte_file = mode_file_name + ".pte"
etr_file = mode_file_name + ".etrecord"
model = DemoLinearModel().eval().to(dtype)
example_inputs = model.get_example_inputs(dtype)
exported_program = torch.export.export(model, example_inputs)
partitioner = XnnpackPartitioner()
edge_program = to_edge_transform_and_lower(
exported_program,
partitioner=[partitioner],
generate_etrecord=True
et_program = edge_program.to_executorch()
with open(pte_file, "wb") as f:
f.write(et_program.buffer)
# Get and save ETRecord
etrecord = et_program.get_etrecord()
etrecord.save(etr_file)
export_executorch_model(torch.float16,"linear_model_pf16_gemm")
To generate a model that uses the pf32_gemm variant, simply change the dtype in the previous code to torch.float32, as shown below:
export_executorch_model(torch.float32,"linear_model_pf32_gemm")
INT8 quantized GEMMs are designed to reduce memory footprint and improve performance while maintaining acceptable accuracy.
| qp8_f32_qc8w_gemm | Asymmetric INT8 per-row quantization | Per-channel symmetric INT8 quantization | FP32 |
| pqs8_qc8w_gemm | Asymmetric INT8 quantization | Per-channel symmetric INT8 quantization | Asymmetric INT8 quantization |
The following code demonstrates how to quantized a model that leverages the pqs8_qc8w_gemm/qp8_f32_qc8w_gemm variants to accelerate computation:
from torchao.quantization.pt2e.quantize_pt2e import convert_pt2e, prepare_pt2e
from executorch.backends.xnnpack.quantizer.xnnpack_quantizer import (
get_symmetric_quantization_config,
XNNPACKQuantizer,
def export_int8_quantize_model(dynamic: bool, model_name: str):
model = DemoLinearModel().eval().to(torch.float32)
example_inputs = model.get_example_inputs(torch.float32)
#Quantizer model
model = torch.export.export(model, example_inputs).module()
quantizer = XNNPACKQuantizer()
operator_config = get_symmetric_quantization_config(
is_per_channel=True,
is_dynamic=dynamic
quantizer.set_global(operator_config)
quantize_model = prepare_pt2e(model, quantizer)
quantize_model(*example_inputs)
quantize_model = convert_pt2e(quantize_model)
#lower and export model
exported_program = torch.export.export(quantize_model, example_inputs)
exported_program,
export_int8_quantize_model(False,"linear_model_pqs8_qc8w_gemm");
export_int8_quantize_model(True,"linear_model_qp8_f32_qc8w_gemm");
This final variant represents KleidiAI’s INT4 path, accelerated by SME2 micro-kernels.
| qp8_f32_qb4w_gemm | Asymmetric INT8 per-row quantization | INT4 (signed), shared blockwise quantization | FP32 |
The following code demonstrates how to quantized a model that leverages the qp8_f32_qb4w_gemm variant to accelerate computation:
from torchao.quantization.granularity import PerGroup, PerAxis
from torchao.quantization.quant_api import (
IntxWeightOnlyConfig,
Int8DynamicActivationIntxWeightConfig,
quantize_,
def export_int4_quantize_model(dynamic: bool, model_name: str):
#Quantizer model
linear_config = Int8DynamicActivationIntxWeightConfig(
weight_dtype=torch.int4,
weight_granularity=PerGroup(32),
quantize_(model, linear_config)
exported_program,
export_int4_quantize_model(False,"linear_model_qp8_f32_qb4w_gemm");
When exporting models, the generate_etrecord option is enabled to produce the .etrecord file alongside the .pte model file. These ETRecord files are essential for subsequent model inspection and performance analysis using the ExecuTorch Inspector API.
Instead of manually executing each code block explained above, you can download and run the full example script that builds and exports all linear-layer benchmark models (FP16, FP32, INT8, and INT4). This script automatically performs quantization, partitioning, lowering, and export to ExecuTorch format.
wget https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/refs/heads/main/content/learning-paths/mobile-graphics-and-gaming/measure-kleidiai-kernel-performance-on-executorch/export-linear-model.py
chmod +x export-linear-model.py
python3 ./export-linear-model.py
After successful execution, you should see both .pte (ExecuTorch model) and .etrecord (profiling metadata) files in the model/ directory:
$ ls model/ -1
linear_model_pf16_gemm.etrecord
linear_model_pf16_gemm.pte
linear_model_pf32_gemm.etrecord
linear_model_pf32_gemm.pte
linear_model_pqs8_qc8w_gemm.etrecord
linear_model_pqs8_qc8w_gemm.pte
linear_model_qp8_f32_qb4w_gemm.etrecord
linear_model_qp8_f32_qb4w_gemm.pte
linear_model_qp8_f32_qc8w_gemm.etrecord
linear_model_qp8_f32_qc8w_gemm.pte
Great job! You now have a complete set of benchmark models exported for multiple GEMM variants and quantization levels. You’re ready to move on and measure performance using ExecuTorch and KleidiAI micro-kernels on Arm-based hardware.
