Set up your environment
Cross-Compile ExecuTorch for the AArch64 platform
Accelerate ExecuTorch operators with KleidiAI micro-kernels
Create and quantize linear layer benchmark model
Create and quantize convolution layer benchmark model
Create matrix multiply layer benchmark model
Run model and generate the ETDump
Analyze ETRecord and ETDump
In this section, you’ll cross-compile ExecuTorch for an Arm64 (AArch64) target with XNNPACK and KleidiAI support. Cross-compiling builds all binaries and libraries for your Arm device, even if your development system uses x86_64. This process lets you run and test ExecuTorch on Arm hardware, taking advantage of Arm-optimized performance features.
On your x86_64 Linux host, install the GNU Arm cross-compilation toolchain along with Ninja, which is a fast build backend commonly used by CMake:
sudo apt install gcc-aarch64-linux-gnu g++-aarch64-linux-gnu ninja-build -y
Use CMake to configure the ExecuTorch build for the AArch64 target.
The command below enables all key runtime extensions, developer tools, and optimized backends including XNNPACK and KleidiAI:
cd $WORKSPACE
mkdir -p build-arm64
cd build-arm64
cmake -GNinja \
-DCMAKE_BUILD_TYPE=Debug \
-DCMAKE_SYSTEM_NAME=Linux \
-DCMAKE_SYSTEM_PROCESSOR=aarch64 \
-DCMAKE_C_COMPILER=aarch64-linux-gnu-gcc \
-DCMAKE_CXX_COMPILER=aarch64-linux-gnu-g++ \
-DCMAKE_FIND_ROOT_PATH_MODE_PROGRAM=NEVER \
-DCMAKE_FIND_ROOT_PATH_MODE_LIBRARY=BOTH \
-DCMAKE_FIND_ROOT_PATH_MODE_INCLUDE=ONLY \
-DEXECUTORCH_BUILD_EXTENSION_DATA_LOADER=ON \
-DEXECUTORCH_BUILD_EXTENSION_FLAT_TENSOR=ON \
-DEXECUTORCH_BUILD_EXTENSION_MODULE=ON \
-DEXECUTORCH_BUILD_EXTENSION_NAMED_DATA_MAP=ON \
-DEXECUTORCH_BUILD_EXTENSION_TENSOR=ON \
-DEXECUTORCH_BUILD_KERNELS_OPTIMIZED=ON \
-DEXECUTORCH_BUILD_XNNPACK=ON \
-DEXECUTORCH_BUILD_DEVTOOLS=ON \
-DEXECUTORCH_ENABLE_EVENT_TRACER=ON \
-DEXECUTORCH_ENABLE_LOGGING=ON \
-DEXECUTORCH_LOG_LEVEL=debug \
-DEXECUTORCH_XNNPACK_ENABLE_KLEIDI=ON \
../executorch
| CMake Option | Description |
EXECUTORCH_BUILD_XNNPACK | Builds the XNNPACK backend, which provides highly optimized CPU operators (such as GEMM and convolution) for Arm64 platforms. |
EXECUTORCH_XNNPACK_ENABLE_KLEIDI | Enables Arm KleidiAI acceleration for XNNPACK kernels, providing further performance improvements on Armv8.2+ CPUs. |
EXECUTORCH_BUILD_DEVTOOLS | Builds developer tools such as the ExecuTorch Inspector and diagnostic utilities for profiling and debugging. |
EXECUTORCH_BUILD_EXTENSION_MODULE | Builds the Module API extension, which provides a high-level abstraction for model loading and execution using Module objects. |
EXECUTORCH_BUILD_EXTENSION_TENSOR | Builds the Tensor API extension, providing convenience functions for creating, manipulating, and managing tensors in C++ runtime. |
EXECUTORCH_BUILD_KERNELS_OPTIMIZED | Enables building optimized kernel implementations for better performance on supported architectures. |
EXECUTORCH_ENABLE_EVENT_TRACER | Enables the event tracing feature, which records performance and operator timing information for runtime analysis. |
Once CMake configuration completes successfully, compile the ExecuTorch runtime and its associated developer tools:
cmake --build . -j$(nproc)
CMake invokes Ninja to perform the actual build, generating both static libraries and executables for the AArch64 target.
If the build completes successfully, you should see the main benchmarking and profiling utility, executor_runner, under:
build-arm64/executor_runner
You’ll use `executor_runner` in later sections to execute and profile ExecuTorch models directly from the command line on your Arm64 target. This standalone binary lets you run models using the XNNPACK backend with KleidiAI acceleration, making it easy to benchmark and analyze performance on Arm devices.
