Build and validate the examples
You’ve inspected how the examples apply the four-step LUTI method to FP16 FMOPA and two-stage SDOT kernels. Now build both examples and validate their results against the reference implementations.
Build and run on macOS
Build and run the executable on an SME2-supported device:
make example_2_luti_programming
./example_2_luti_programming
Cross-compile the examples and run on Android
On macOS or Linux, build the AArch64 Android executable with LLVM 22 and the NDK r29 installation selected by ANDROID_NDK_HOME:
make example_2_luti_programming_android
With an Android device connected through adb, push the executable to the device:
adb push example_2_luti_programming_android /data/local/tmp/example_2_luti_programming_android
Open an adb shell, make the file executable, and run it:
adb shell
cd /data/local/tmp
chmod 755 example_2_luti_programming_android
./example_2_luti_programming_android
After it finishes, enter exit to return to the build host’s shell.
The executable performs the definitive runtime check. If SME2 isn’t available, it prints SKIP: No support for SME2 on this device. The program exits successfully without running either set of examples. You can still disassemble the executable on the build host.
Check the result
In the output, SVL is the streaming vector length in bits. VL_b is the number of byte elements (SVL / 8), VL_h is the number of half-word elements (SVL / 16), and VL_s is the number of 32-bit word elements (SVL / 32).
The expected output is:
        FP16 LUTI4 + FMOPA test (M = VL_s, K = 2, N = 4 * VL_s)
PASS
LUTI4 -> LUTI2 -> SDOT test (M = 1, K = N = VL_b)
PASS
Each PASS confirms that the kernel matches the reference result.
You’ve built the LUTI4 and two-stage LUTI examples and confirmed that both kernels match their reference results.
Next, you’ll compare the ZT0-based LUTI path with Z-register table forms and SME2.1 strided destination groups.
