The four-step LUTI recipe
The examples in example_2_luti_programming.c show a recipe-based approach to programming with lookup-table instructions (LUTIs).
The examples cover the following combinations and are based on KleidiAI matrix multiplication micro-kernels:
ExampleDecodeArithmeticMain concept
FP16 LUTI4 + FMOPALUTI4 to float16GEMM using FMOPAUse LUTI and source segments
LUTI4 -> LUTI2 -> SDOTLUTI4, then LUTI2 to int8GEMV using SDOTUse multiple lookup tables and source segments
For every LUTI call, answer the following questions:
StepDecisionResult
1What are the packed-index and table-element widths?Choose the LUTI form and ZT0 register table-entry width.
2What element type does the destination Z register require?Select .B, .H, or .S.
3How many destination Z registers do you need the lookup to fill?Choose x1, x2, or x4 to match the target operation.
4How much of the source Z register fills the destination register group?Select the correct source-register segment.
A source segment is the portion of one packed source Z register that fills the chosen destination group.
Its selector is relative to the destination-group size.
The examples use several source-segment cases to help you develop intuition for selecting the correct segment.
LUTI4 for FP16 GEMM using FMOPA
This example is a focused extraction from KleidiAI’s FP16 LUTI4 FMOPA micro-kernel . It uses 4-bit codes as indices that map to float16 values, and shows how the source-index segment is interpreted relative to the destination-group size using generic SVL terminology.
Open example_2_luti_programming.c and find arm_lp_gemm_luti4 to follow along:
__arm_new("za", "zt0") __arm_locally_streaming void arm_lp_gemm_luti4(
    const float16_t* lhs, const uint8_t* rhs_indices, float32_t* out, const uint32_t* zt0_lut) {
    uint32_t m = svcntw();  // Number of FP32 rows/columns in one ZA tile.
    /*                         LUTI4 decode
     * | Step | Decision                  | Choice                                 |
     * | 1    | Index and table width     | 4-bit index                            |
     * |      |                           | 16-bit ZT0 LUT register element        |
     * | 2    | Destination element type  | .H, because FMOPA consumes FP16        |
     * | 3    | Destination group         | x1 for rhs_0/rhs_1, then x2 for rhs_23 |
    // There are more than one ways to reason about the number of input segment.
    // Here, we go about it from the source register as the reference point.
    // Load the LUT
    svldr_zt(0, zt0_lut);
    svzero_za();
    // Load the LHS
    svbool_t pg = svptrue_b16();
    svfloat16_t lhs_ip = svld1_f16(pg, lhs);
    // Load one source register of indices
    svuint8_t s4_indices = svld1_u8(svptrue_b8(), rhs_indices);
    // Case 1: a single-register destination group uses one of four segments.
    //  Step 4 : Number of input segments for x1
    //   One byte of index produces two half words after the look up.
    //   VL_b bytes of indices from a source register produces 2 * VL_h half-word elements or 4 * VL_b bytes.
    //   In other words, to fill VL_b bytes of destination, VL_b / 4 bytes
    //   is needed => 4 input segments with values 0, 1, 2 and 3
    //                source z register: Packed indices
    //   | segment [3] | segment [2] | segment [1] | segment [0] |
    //                                                         | LUTI4 .H, segment [0]
    //                                                         v
    //                       destination z register with F16 elements
    //              |                  VL_h elements                     |
    // Unpredicated LUTI read.
    svfloat16_t rhs_0 = svluti4_lane_zt_f16(0, s4_indices, /* segment */ 0);
    svfloat16_t rhs_1 = svluti4_lane_zt_f16(0, s4_indices, /* segment */ 1);
    // Case 2: a two-register destination group using one of two segments.
    //  Step 4 : Number of input segments for x2
    //                                                          4 * VL_b bytes.
    //   In other words, to fill 2 * VL_b bytes of destination, VL_b / 2 bytes
    //   is needed =>  2 segments with values 0 and 1
    //               source z register: packed indices
    //   |        segment [1]        |        segment [0]        |
    //                      | LUTI4 .H, segment [1]
    //                      v
    //               two-register destination z register group
    //              |  destination 1      |   destination 0     |
    //              |    VL_h elements    |   VL_h elements     |
    svfloat16x2_t rhs_23 = svluti4_lane_zt_f16_x2(0, s4_indices, /* Segment */ 1);
    svmopa_za32_f16_m(0, pg, pg, lhs_ip, rhs_0);
    svmopa_za32_f16_m(1, pg, pg, lhs_ip, rhs_1);
    svmopa_za32_f16_m(2, pg, pg, lhs_ip, svget2_f16(rhs_23, 0));
    svmopa_za32_f16_m(3, pg, pg, lhs_ip, svget2_f16(rhs_23, 1));
    // Extract out the data from ZA tiles and store
    for (uint32_t i_m = 0; i_m < m; i_m += 1) {
        svfloat32x4_t out_row = svread_hor_za32_f32_vg4(0, 4 * i_m);
        svst1_f32_x4(svptrue_c32(), out + ((size_t)4 * i_m * m), out_row);
Two-stage LUTI4 and LUTI2 for GEMV using SDOT
The SDOT micro-kernel and block size are similar to KleidiAI’s SDOT micro-kernel , with two LUTs added to implement a two-stage decode of vector-quantized weights.
In this context, vector quantization uses a 4-bit code as an index to select an 8-bit codeword that represents a four-weight pattern. The sixteen ZT0 entries represent sixteen unique patterns.
The two-stage decode uses LUTI4 to select an 8-bit codeword, then LUTI2 to map the codeword to four 8-bit numerical values:
                packed 4-bit pattern ID
             |          index[3:0]          |
                           | LUTI4: select one 8-bit codeword from ZT0
                           v
                packed 8-bit data with 2-bit symbols
             | sym[3] | sym[2] | sym[1] | sym[0] |
             |  2 bits|  2 bits|  2 bits|  2 bits|
                           | LUTI2: expand each 2-bit symbol from ZT0
                           v
             | weight3| weight2| weight1| weight0|
             |  int8  |  int8  |  int8  |  int8  |
This encoding reduces the bytes required to store weights.
The arm_lp_gemv_luti2_luti4 function in example_2_luti_programming.c implements this two-stage decode:
__arm_new("za", "zt0") __arm_locally_streaming void arm_lp_gemv_luti2_luti4(
    const int8_t* lhs, const uint8_t* rhs_indices, int32_t* out,
    const uint32_t* zt0_luti4, const uint32_t* zt0_luti2) {
    const size_t vl_b = svcntb();
    const size_t lhs_blocks = vl_b / 16;
    const svbool_t pg8 = svptrue_b8();
    const svcount_t pn8 = svptrue_c8();
    assert(lhs != NULL);
    assert(rhs_indices != NULL);
    assert(out != NULL);
    assert(zt0_luti4 != NULL);
    assert(zt0_luti2 != NULL);
    assert(vl_b % 16 == 0);
    svzero_za();
    for (size_t i_k = 0; i_k < lhs_blocks; i_k++) {
        // For a SVL of 512 bits: SVL_b = 64 bytes and SVL_s = 16 words.
        // Replicated read of one 16-byte LHS block for SDOT lanes.
        svint8_t lhs_ip = svld1rq_s8(pg8, lhs);
        lhs += 16;
        /*                      LUTI4 decode (first stage)
         * |      |                           | 8-bit ZT0 LUT register element         |
         * | 2    | Destination element type  | NA. Second decode stage addresses this |
         * | 3    | Destination group         | x2 for patterns_01 and patterns_23     |
        // Two source registers provide the four packed 2-bit vectors needed for the second stage.
        svuint8x2_t rhs_packed = svld1_u8_x2(pn8, rhs_indices);
        rhs_indices += 2 * vl_b;
        // Load LUT 1
        svldr_zt(0, zt0_luti4);
        //   One packed byte contains two 4-bit indices and produces two bytes
        //   after the lookup. SVL_b bytes of indices from one source register
        //   therefore produce 2 * SVL_b bytes, filling the x2 destination
        //   group. This uses one input segment with value 0.
        svuint8x2_t patterns_01 = svluti4_lane_zt_u8_x2(0, svget2_u8(rhs_packed, 0), 0);
        svuint8x2_t patterns_23 = svluti4_lane_zt_u8_x2(0, svget2_u8(rhs_packed, 1), 0);
        /*                      LUTI2 decode (second stage)
         * | 1    | Index and table width     | 2-bit index                            |
         * | 2    | Destination element type  | .B, SDOT consumes int8                 |
         * | 3    | Destination group         | x4 for rhs_unpacked                    |
        // Load LUT 2
        svldr_zt(0, zt0_luti2);
        //  Step 4 : Number of input segments for x4
        //   One packed byte contains four 2-bit indices and produces four
        //   bytes after the lookup. SVL_b bytes of indices from one source
        //   register therefore produce 4 * SVL_b bytes, filling the x4
        //   destination group. This uses one input segment with value 0.
        svint8x4_t rhs_unpacked = svreinterpret_s8_u8_x4(svluti2_lane_zt_u8_x4(0, svget2_u8(patterns_01, 0), 0));
        // Process k index of 0 to 3.
        // Process 1VL_s of N
        svdot_lane_za32_s8_vg1x4(0, rhs_unpacked, lhs_ip, /* Lane */ 0);
        rhs_unpacked = svreinterpret_s8_u8_x4(svluti2_lane_zt_u8_x4(0, svget2_u8(patterns_01, 1), 0));
        // Process k index of 4 to 7
        // process next 1VL_s of N
        svdot_lane_za32_s8_vg1x4(0, rhs_unpacked, lhs_ip, /* Lane */ 1);
        rhs_unpacked = svreinterpret_s8_u8_x4(svluti2_lane_zt_u8_x4(0, svget2_u8(patterns_23, 0), 0));
        // Process k index of 8 to 11
        // Process next 1VL_s of N
        svdot_lane_za32_s8_vg1x4(0, rhs_unpacked, lhs_ip, /* Lane */ 2);
        rhs_unpacked = svreinterpret_s8_u8_x4(svluti2_lane_zt_u8_x4(0, svget2_u8(patterns_23, 1), 0));
        // Process k index of 12 to 15
        // Process next 1VL_s or N
        svdot_lane_za32_s8_vg1x4(0, rhs_unpacked, lhs_ip, /* Lane */ 3);
        // Total processed: 16 K-values, 4VL_s N values
    svint32x4_t result = svread_za32_s32_vg1x4(0);
    svst1_s32_x4(svptrue_c32(), out, result);
You’ve seen how destination-group size determines the meaning of a source segment. You’ve also learned how the same four-step method applies once or repeatedly in a multi-stage decode.
Next, you’ll build and validate both programming examples.
