Build and validate the example
You’ve inspected how code/example_1_luti_decoding.c implements the same calculation in plain C and with SME2 LUTI2. Now build the complete example and verify that both implementations produce the same output.
Run the following commands from the code directory.
Build and run on macOS
Build and run the executable on an SME2-supported device:
make example_1_luti_decoding
./example_1_luti_decoding
Cross-compile and run on Android
On macOS or Linux, use LLVM 22 and the NDK r29 installation selected by ANDROID_NDK_HOME. The build host doesn’t need SME2 support.
Build the standalone Android executable:
make example_1_luti_decoding_android
With an Android device connected through adb, push the executable to the device:
adb push example_1_luti_decoding_android /data/local/tmp/example_1_luti_decoding_android
Open an adb shell, make the file executable, and run it:
adb shell
cd /data/local/tmp
chmod 755 example_1_luti_decoding_android
./example_1_luti_decoding_android
After running the file, enter exit to return to the build host’s shell.
Check the result
On an SME2-capable device, the program prints the matrix shape, lookup table, decoded right-hand side (RHS) samples, and a matrix preview.
For a 512-bit SVL, the output begins with:
        SVL = 512 bits; matrix shape M=16, K=4, N=64
2-bit LUT mapping:
bits  idx  signed  raw byte
 00   0      -3    0xFD
 01   1      -1    0xFF
 10   2       1    0x01
 11   3       3    0x03
The RHS decoding preview and C matrix preview follow. The final validation line is similar to:
        PASS: LUTI2 SME2 matches plain C matmul.
If SME2 is unavailable, the runner exits without performing the calculations:
        SKIP: No support for SME2 on this device.
A SKIP result doesn’t validate the calculation. You can still inspect the generated instructions on the build host.
Inspect the generated SME2 instructions
For the native macOS executable, run:
make disassemble-example-1
For the Android executable, run the following command on the macOS or Linux build host:
make disassemble-example-1-android
The Makefile selects the host’s LLVM disassembler and displays only LUTI2 and SMOPA instructions. Disassembly doesn’t require SME2 hardware.
The output is similar to:
        100000cec: c08c8024     luti2 { z4.b - z7.b }, zt0, z1[0]
100000cf0: a0840000     smopa za0.s, p0/m, p0/m, z0.b, z4.b
100000cf4: a0850001     smopa za1.s, p0/m, p0/m, z0.b, z5.b
100000cf8: a0860002     smopa za2.s, p0/m, p0/m, z0.b, z6.b
100000cfc: a0870003     smopa za3.s, p0/m, p0/m, z0.b, z7.b
Addresses vary by build. Confirm that one LUTI2 is followed by four SMOPA instructions targeting ZA0 through ZA3.
You’ve built the first example, compared the plain C and SME2 results, and confirmed that the generated code contains LUTI2 followed by four SMOPA instructions.
Next, you’ll learn to program LUTIs through practical SME2 examples.
