SME and SME2 architectural features
Arm Scalable Matrix Extension (SME) extends the Armv9-A architecture and accelerates matrix-heavy computations, such as outer products and matrix multiplication.
SME introduces Streaming Scalable Vector Extension (SVE) mode and the scalable ZA matrix-storage array. ZA accumulates matrix outer products and multi-vector dot products.
SME2 builds on SME and adds multi-vector instructions and the fixed 512-bit ZT0 lookup-table register.
Lookup-table instructions (LUTIs) use packed low-bit codes from Z source registers. They read the corresponding lookup table entries from ZT0, and write expanded operands into Z destination registers.
The expanded operands can then be consumed by SME2 matrix instructions such as SDOT or SMOPA, with results accumulated in the ZA array.
SME2 provides a fixed 512-bit architectural register named ZT0. It contains 64 bytes, arranged as sixteen 32-bit table entries.
Image Alt Text:Diagram showing ZT0 as sixteen 32-bit entries. LUTI2 selects entries 0–3 using 2-bit indices, and LUTI4 selects entries 0–15 using 4-bit indices.ZT0 lookup-table organization used by LUTI2
LUTI4 works the same way but uses 4-bit indices, giving access to all sixteen entries and producing wider output elements.
Image Alt Text:Diagram showing ZT0 as sixteen 32-bit entries. LUTI4 selects entries 0–15 using 4-bit indices, and the destination element size determines whether the low 8, 16, or 32 bits of each entry are copied.ZT0 lookup-table organization used by LUTI4
LUTIs use packed low-bit indices from a source Z register (Zn) to select the corresponding ZT0 register entry.
The relevant ZT0 entries are expanded to the chosen destination element width and written to output Z registers (Zd).
LUTI2 and LUTI4 can populate one, two, or four destination Z registers. The number of destination registers and the expanded element width (.B, .H, or .S) determine how many packed source bits fill the destinations.
The element suffix specifies the expanded destination width:
  • .B produces 8-bit elements.
  • .H produces 16-bit elements.
  • .S produces 32-bit elements.
Streaming mode
ZT0-based SME2 LUTIs need both streaming mode and ZA enabled. SMSTART enables the required state, and SMSTOP disables it.
Streaming mode changes the execution context in three ways:
  • Vector and predicate lengths use the streaming vector length (SVL), which can differ from the non-streaming vector length.
  • Streaming instructions, including the multi-register LUTI2, SDOT, and SMOPA forms, become available.
  • PSTATE.ZA controls access to both the ZA matrix-storage array and ZT0.
Efficient kernels enter streaming mode before repeated loops and exit afterwards. Streaming mode doesn’t automatically stream matrix data from memory. The kernel still loads only the current computation tile.
Follow the SME2 LUTI data path
A simplified SME2 LUTI sequence is:
SMSTART
* load ZT0 once
* perform LUTI2
SMSTOP
A detailed LUTI SME2 flow is:
  1. Enter SME streaming mode with SMSTART and load the LUT into the sixteen 32-bit ZT0 register.
  2. Load left-hand side (LHS) activations and packed right-hand side (RHS) data for the current computation tile.
  3. Use LUTI2 or LUTI4 to expand the packed RHS indices from ZT0 into Z registers.
  4. Feed the expanded RHS elements and LHS activations to SME2 instructions, such as SDOT or SMOPA.
  5. Accumulate partial matrix products in the SME2 ZA array.
  6. Convert, clamp, and store the completed output tile as required by the kernel.
  7. Exit SME streaming mode with SMSTOP. This disables the ZA and ZT0 state after the kernel completes.
LUTI replaces the explicit unpack and decode portion of the data path. It doesn’t replace the matrix multiply instruction that consumes the expanded values.
Example kernel with LUTI2
The following example kernel shows how LUTI2 expands packed 2-bit RHS weights. It simplifies register allocation, predication, addressing, and loop control to focus on the LUTI data flow.
Note The example uses a 512-bit SVL. The SVL is a CPU-specific property.
Define and pass the lookup table
ZT0 contains sixteen 32-bit entries. LUTI2 uses entries 0 to 3:
static const int32_t lut_i8_i2[16] = {-2, -1, 0, 1,};
Entries 4 to 15 are unused and contain zero.
For a .B LUTI result, the low 8 bits of the selected 32-bit entry form the destination element.
Load the lookup table into ZT0
Enter streaming mode, initialize ZA, and load ZT0. The lookup table doesn’t change across the inner matrix loop, so load it once before the loop:
smstart                   // Enable Streaming SVE mode and ZA/ZT0 state
zero    {za}              // Zero initialize accumulators for this output tile
ldr     zt0, [lut_i8_i2]      // load LUT into fixed 512-bit ZT0 table
Load LHS and packed RHS
Load the LHS activations and packed RHS 2-bit indices for the current computation tile, not the entire matrix:
ld1rqb  {z0.b}, ... , [x_lhs]               // load LHS
ld1b    {z16.b-z19.b}, ... , [x_packed_rhs] // load RHS packed 2-bit indices
  • The z0.b register receives the LHS activations.
  • The z16.b–z19.b registers receive the packed RHS 2-bit indices.
ld1rqb is the SVE load-and-replicate-quadword operation. For a 512-bit SVL, you can view z0 as four 128-bit regions. ld1rqb replicates the 16-byte LHS block across those regions.
LUTI2 expands the packed indices
Each LUTI2 instruction reads packed 2-bit indices from one source Z register (z16 to z19) and expands them into four .B destination registers for a 512-bit SVL:
luti2   { z24.b - z27.b }, zt0, z16[0]     // unpack 2-bit indices
luti2   { z4.b  - z7.b  }, zt0, z17[0]
luti2   { z8.b  - z11.b }, zt0, z18[0]
luti2   { z12.b - z15.b }, zt0, z19[0]
Feed the expanded vectors directly to SDOT
The expanded vectors can now feed SME2 matrix instructions such as SDOT or SMOPA, which accumulate the results in ZA.
You’ve learned how LUTI operates within SME2. A micro-kernel loads the lookup table into ZT0. It uses packed low-bit indices in Z registers to expand the RHS values, and feeds those expanded values into SME2 instructions.
Next, you’ll select and prepare a macOS or Android SME2 environment for the SME2 LUTI examples.
