There are two options outlined in this Learning Path to install the dependencies. Click on the option of your choice:
Install docker engine on your machine.
Use a file editor of your choice and save the following lines in a file named Dockerfile:
FROM amd64/ubuntu:22.04
ENV USER=ubuntu
RUN echo 'debconf debconf/frontend select Noninteractive' | debconf-set-selections
RUN apt-get update
RUN apt-get install -y --no-install-recommends apt-utils
RUN apt-get -y upgrade
RUN apt-get -y --no-install-recommends install sudo vim wget curl jq git bzip2 make cmake automake autoconf libtool pkg-config clang-format
RUN useradd --create-home -s /bin/bash -m $USER && echo "$USER:$USER" | chpasswd && adduser $USER sudo
RUN echo '%sudo ALL=(ALL) NOPASSWD:ALL' >> /etc/sudoers
WORKDIR /home/$USER
USER ubuntu
RUN sudo apt-get install unzip python3-pip -y
RUN sudo apt-get install openjdk-11-jdk -y
ENV JAVA_HOME "/usr/lib/jvm/java-11-openjdk-amd64"
ENV PATH "$PATH:$JAVA_HOME"
RUN wget https://github.com/bazelbuild/bazel/releases/download/6.1.1/bazel-6.1.1-installer-linux-x86_64.sh
RUN sudo bash bazel-6.1.1-installer-linux-x86_64.sh
RUN git clone --depth 1 https://github.com/google/mediapipe.git
WORKDIR /home/$USER/mediapipe
RUN pip3 install -r requirements.txt
RUN bash setup_android_sdk_and_ndk.sh $HOME/Android/Sdk $HOME/Android/Sdk/ndk-bundle r26d --accept-licenses
ENV PATH "$PATH:$HOME/Android/Sdk/ndk-bundle/android-ndk-r26d/toolchains/llvm/prebuilt/linux-x86_64/bin"
ENV GLOG_logtostderr=1
Build the Docker image:
docker build -t ubuntu-x86 -f Dockerfile . --platform=linux/amd64
Run a shell on the Docker container:
docker run -it --rm ubuntu-x86 /bin/bash
You can now jump to testing your setup .
In order to cross-compile the inference engine, you will need the following packages installed or downloaded on your Ubuntu development machine:
sudo apt update
sudo apt install unzip python3-pip -y
export JAVA_HOME=/usr/lib/jvm/java-11-openjdk-amd64
export PATH=$PATH:$JAVA_HOME
If you would like these environment variables to persist the next time you open a shell, add them to your .bashrc file.
To build MediaPipe, you will use Bazel version 6.1.1.
cd mediapipe
These steps have been tested with MediaPipe commit 7c625938d8074b77e6cefcc29beabd995c613e2b.
Use the script included in MediaPipe to install the Android NDK and SDK:
Add the NDK bin folder to your PATH variable:
export PATH=$PATH:$HOME/Android/Sdk/ndk-bundle/android-ndk-r26d/toolchains/llvm/prebuilt/linux-x86_64/bin/
Verify your setup by running a simple “hello world” example in MediaPipe:
export GLOG_logtostderr=1
bazel run --define MEDIAPIPE_DISABLE_GPU=1 mediapipe/examples/desktop/hello_world:hello_world
The bazel flag MEDIAPIPE_DISABLE_GPU=1 disables the desktop GPU as it is not required.
The output from this test run is Hello World! printed ten times, like this:
INFO: Build completed successfully, 371 total actions
INFO: Running command line: bazel-bin/mediapipe/examples/desktop/hello_world/hello_world
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
I0000 00:00:1715712039.171598 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171651 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171667 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171679 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171719 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171754 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171773 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171804 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171829 59236 hello_world.cc:58] Hello World!
I0000 00:00:1715712039.171859 59236 hello_world.cc:58] Hello World!
