At a high level, a KleidiAI matmul microkernel computes the output matrix C in tiles. Instead of producing the full matrix C in one pass, it produces small submatrices (tiles) of C one by one.
Microkernels typically expose a small set of constants that define the tile shape and the inner-loop step sizes:
C (and A) computed per output tileC (and B) computed per output tileK dimension processed per blockK dimension processed per inner stepThe video below demonstrates how matrix multiplication is carried out using this method.
Tile-Based matrix multiplication with KleidiAI
This process can be described with the following pseudocode:
// RHS N LOOP
for(n_idx = 0; n_idx < n; n_idx+=nr){
// LHS M LOOP
for(m_idx = 0; m_idx < m; m_idx+=mr){
// K LOOP, break K into blocks first
blocks_in_K= K/bl; // bl is the block length
//Block Loop
for(bl_idx = 0; bl_idx< blocks_in_K; bl_idx += 1) {
//Loop inside a block
krs_in_block= bl/kr; //kr is the number of elements in K dimension per inner loop
for(k_idx = 0; k_idx < krs_in_block; k_idx +=1) {
// Perform the matrix multiplication with source submatrices of size [mr, kr] and [kr, nr]
// Accumulate the matrix multiplication result above into per block level result.
// Accumulate per block level results along K dimension. When iteration on K dimension is completed,a submatrix of size [mr, nr] of the output matrix is ready
//Continue computing a submatrix of size [mr, nr] of the output matrix along M dimension
//Continue computing a submatrix of size [mr, nr] of the output matrix along N dimension
In practice, KleidiAI matmul microkernels follow this pattern, but use tight loops, explicit packing, and architecture-specific instructions.
KleidiAI also provides corresponding packing microkernels for the matmul microkernels, in order to make efficient contiguous memory access to the input of the matrix multiplication, reducing cache misses.
KleidiAI supports quantized matrix multiplication to speed up AI inference on Arm CPUs. Instead of multiplying full precision (FP32) matrices A and B directly, it quantizes:
It then packs those quantized values into memory layouts that match the CPU’s preferred access patterns and instruction shapes (for example, DotProd, I8MM, and SME2).
The matmul microkernel runs on the packed quantized data, accumulates into a wider type (typically INT32), and then scales back to FP32.
This process can be illustrated in the following diagram,
Quantized matrix multiplication with KleidiAI kernel
Validate that mr/nr/kr-style constants exist and are exposed via small helper functions.
Run the following commands from the KleidiAI repo root:
grep -R "kai_get_mr_matmul" -n kai | head
grep -R "kai_get_nr_matmul" -n kai | head
grep -R "kai_get_kr_matmul" -n kai | head
The output is similar to:
kai/ukernels/matmul/matmul_clamp_f32_qai8dxp_qsi4cxp/kai_matmul_clamp_f32_qai8dxp1x4_qsi4cxp4vlx4_1x4vl_sme2_sdot.h:52:size_t kai_get_kr_matmul_clamp_f32_qai8dxp1x4_qsi4cxp4vlx4_1x4vl_sme2_sdot(void);
You’ll use these values later when you connect the packing steps to the inner loop of the SME2 microkernel.
For more background on KleidiAI, see Accelerate Generative AI workloads using KleidiAI .
You’ve learned how KleidiAI matmul microkernels break matrix multiplication into tiles defined by mr, nr, and kr parameters. You understand why packing matters for cache efficiency and how quantization flows through the kernel.
Next, you’ll explore how SME2 INT8 MOPA instructions accelerate the core matmul computation.
