KleidiAI includes highly optimized matrix multiplication (matmul) microkernels that accelerate quantized operators on Arm CPUs. On SME2-capable systems, these microkernels use SME2 INT8 MOPA (outer product accumulate) instructions to increase throughput for the compute-heavy parts of inference.
This Learning Path focuses on one concrete microkernel and walks through:
This Learning Path mentions llama.cpp as a concrete reference point in two ways:
It does not ask you to build or run llama.cpp end-to-end. If you want to build and profile llama.cpp with KleidiAI on-device, use the llama.cpp performance Learning Path .
You’ll do a few lightweight, practical checks as you go:
smopa, luti4, and zero {za})If you already have llama.cpp built with KleidiAI (for example from the llama.cpp performance Learning Path ), you can also use that build to validate call stacks and confirm where the kernel runs.
If you want to follow the microkernel implementation directly, start by cloning KleidiAI and locating the SME2 matmul microkernel assembly file.
git clone https://github.com/ARM-software/kleidiai.git
cd kleidiai
KERNEL_FILE="kai/ukernels/matmul/matmul_clamp_f32_qsi8d32p_qai4c32p/kai_matmul_clamp_f32_qsi8d32p1vlx4_qai4c32p4vlx4_1vlx4vl_sme2_mopa_asm.S"
ls -la "$KERNEL_FILE"
grep -n "smopa" "$KERNEL_FILE" | head
grep -n "luti" "$KERNEL_FILE" | head
grep -n "zero {za}" "$KERNEL_FILE" | head
The output is similar to:
90: KAI_ASM_INST(0xa0840100) // smopa za0.s, p0/m, p0/m, z8.b, z4.b
88: KAI_ASM_INST(0xc08a4044) // luti4 {z4.b - z5.b}, zt0, z2[0]
81: KAI_ASM_INST(0xc00800ff) // zero {za}
If you don’t see matches, your local checkout might be on a different revision. In that case, search for the function name used in this Learning Path:
grep -R "kai_matmul_clamp_f32_qsi8d32p1vlx4" -n kai | head
You can complete the “source inspection” parts of this Learning Path without SME2 hardware. To run SME2 code on-device, your CPU and OS need to expose SME2.
uname -m
grep -m1 -E '^Features' /proc/cpuinfo | tr ' ' '\n' | grep -E '^sme$|^sme2$' || true
uname -m
sysctl -a | rg -i 'sme2|sme'
If neither sme nor sme2 appears, you can still follow the explanation, but you should treat any “run” steps as not applicable on your device.
You’ve confirmed where to find the SME2 matmul microkernel source in KleidiAI and verified whether SME2 is available on your device. You understand the scope of this Learning Path and know which parts are hands-on versus conceptual.
Next, you’ll explore how KleidiAI matmul microkernels use tiling and packing to structure matrix multiplication work.
