Match quantization contracts first
Don’t select a microkernel only because it produces FP16 output and uses int8 and int4 inputs. The kernel’s quantization contract must also match the framework operator.
For example, matmul_clamp_f16_qsi8d32p_qai4c32p might appear to be a suitable KleidiAI kernel.
That kernel isn’t a correct match for XNNPACK qd8_f16_qc4w for the following reasons:
  • qsi8d32p requires symmetric int8 quantization for each block of 32 K values.
  • XNNPACK QD8 uses asymmetric int8 quantization for each row.
Using that kernel requires dequantizing and then requantizing the left-hand side per 32-value block. These steps add quantization error and can violate the numerical contract of the existing XNNPACK operator.
Select qai8dxp/qsi4cxp
Use the KleidiAI Scalable Matrix Extension 2 (SME2) matrix outer product accumulate (MOPA) microkernel kai_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa instead.
Its formats match the operator:
OperandXNNPACK formatKleidiAI formatResult
Left-hand side (LHS)QD8, asymmetric per rowqai8dxp, asymmetric per rowDirect metadata adaptation
Right-hand side (RHS)QC4W, int4 per output channelqsi4cxp, signed int4 per channelPack once during create
OutputFP16 with min/max clampFP16 with min/max clampDirect match
qai8dxp means quantized asymmetric int8 with dynamic, per-row parameters. It’s the key reason this kernel is suitable: the original qd8 activation values don’t need to be requantized.
Why SME2 MOPA
The sme2_mopa suffix means the microkernel uses SME2 matrix outer product accumulate instructions. SME2 provides a matrix accumulator, called ZA, that’s designed for matrix workloads.
The kernel tile dimensions are expressed in vector lengths:
1VL x 4VL
The actual mr and nr values depend on the device’s streaming vector length. The wrapper queries the kernel instead of hard-coding them:
size_t mr = kai_get_mr_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa();
size_t nr = kai_get_nr_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa();
The same kernel reports kr = 4 and sr = 1. These values define the K interleave used by the packed LHS and RHS buffers.
Prepare the XNNPACK SME2 wrapper
The wrapper is introduced by the already-applied first patch 0001-prepare-qd8-f16-qc4w-sme2-kernel.patch .
The patch adds an XNNPACK wrapper at:
src/qd8-f16-qc4w-gemm/
  qd8-f16-qc4w-gemm-minmax-16x64c4-neonsme2.c
The 16x64c4 part follows the existing XNNPACK SME2 wrapper naming convention. It’s a name used by XNNPACK tooling, rather than a claim that the KleidiAI kernel always uses a fixed 16 by 64 tile. The actual tile dimensions come from the KleidiAI get_mr and get_nr functions at runtime.
Tip
Select a kernel from its complete operand contract. Compare quantization granularity, signedness, and zero-point behavior. After comparing these factors, check the output type, clamp behavior, and packing requirements before implementing any adapter.
You’ve matched the operator’s quantization contract to the selected KleidiAI microkernel and traced how the wrapper queries its tile dimensions. The integration preserves the existing QD8 activation values while adapting the operands to the kernel’s packed layouts.
Next, inspect how the integration packs the static RHS weights.
