Why pack the RHS once
The right-hand side (RHS) is the fully connected weight matrix. Its int4 values, per-channel scales, and bias values are static after the operator is created. This data should be packed once during xnn_create_fully_connected_nc_qd8_f16_qc4w, rather than during every inference run.
Original QC4W model weights
  -> XNNPACK create
  -> KleidiAI packed RHS
  -> XNNPACK operator memory or weights cache
  -> repeated inference runs
The RHS is different from the QD8 left-hand side (LHS), which changes for every inference run and must be packed at runtime.
RHS packing corresponds to the second patch 0002-support-transposed-kai-qc4w-weights.patch . In src/reference/packing.cc, xnn_pack_kai_qs4_weights_and_biases_sme handles the source-layout conversion before calling the KleidiAI packer.
Raw XNNPACK QC4W source layout
The logical RHS matrix is:
B[N, K]
Each row represents one output channel. The source data contains:
packed int4 weights[N, K]
float kernel_scale[N]
float bias[N]
uint8 kernel_zero_point
Two consecutive K values occupy one byte:
bits [3:0] = weight[n][k]
bits [7:4] = weight[n][k + 1]
For example, eight int4 values for one output channel are stored as four bytes:
logical values:
K0 K1 K2 K3 K4 K5 K6 K7
packed bytes:
[K1|K0] [K3|K2] [K5|K4] [K7|K6]
The scale and bias are separate arrays. They aren’t embedded in the raw packed-int4 bytes.
Signedness and kernel zero point
XNNPACK accepts two QC4W encodings:
kernel_zero_point = 0
  each nibble is a signed int4 value in [-8, 7]
kernel_zero_point = 8
  each nibble is an unsigned value in [0, 15]
  its signed weight value is nibble - 8
The selected KleidiAI microkernel uses signed int4 weight semantics. The KleidiAI RHS packer handles the required zero-point conversion and also pads the K dimension with signed zero.
Why raw QC4W can’t feed the KleidiAI kernel directly
Raw XNNPACK QC4W data is organized as one K-contiguous row per output channel, with scales and bias stored separately. This is convenient for a model format. However, it’s not the layout consumed by the Scalable Matrix Extension 2 (SME2) matrix outer product accumulate (MOPA) inner loop.
The KleidiAI microkernel computes several output channels together. It needs K blocks from an N tile arranged for sequential vector and matrix loads, followed by metadata at KleidiAI-defined offsets.
Raw XNNPACK QC4W
  channel-major int4 rows
  separate scale and bias arrays
KleidiAI packed qsi4cxp RHS
  K blocks interleaved for an N tile
  weight sums, scales, and bias embedded with the tile
The formats represent the same mathematical weights, but their byte layouts are different.
KleidiAI qsi4cxp packed RHS layout
The applied integration calls the KleidiAI packer:
kai_run_rhs_pack_nxk_qsi4cxps1s0_qsu4cxs1s0_neon
The packer produces the qsi4cxp packed RHS format used by kai_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa.
The packer receives the following:
  • Logical N x K source
  • Bias
  • Scale
  • nr
  • kr
  • sr
For the selected SME2 microkernel:
kr = 4
sr = 1
K_padded = round_up(K, 32)
nr = queried from the KleidiAI microkernel at runtime
Conceptually, one packed N tile contains:
| packed int4 data for K block 0 across nr channels |
| packed int4 data for K block 1 across nr channels |
| int32 weight sums[nr]                              |
| float scales[nr]                                   |
| float bias[nr]                                     |
The exact byte interleave is owned by the KleidiAI packer. Framework code should call the packer rather than reproduce this microkernel-specific layout by hand.
The weight sums are used to compensate for the asymmetric QD8 LHS zero point during matrix multiplication.
Why the packed RHS stores weight sums
The QD8 activation is asymmetric. For one activation row, its real values are:
a_real[k] = (a_q[k] - a_zero_point) * a_scale
For one output channel, let w_q[n,k] be the signed int4 weight values. Ignoring the final scale and bias, the integer part of the dot product is:
sum_k ((a_q[k] - a_zero_point) * w_q[n,k])
Expanding the expression gives:
sum_k (a_q[k] * w_q[n,k])
  - a_zero_point * sum_k(w_q[n,k])
The first term is the normal integer dot product. The second term is the asymmetric activation correction. The RHS packer calculates and stores this per-output-channel value:
weight_sum[n] = sum_k(w_q[n,k])
At runtime, the KleidiAI packed LHS stores:
negative_zero_point = -a_zero_point
The KleidiAI microkernel can then compute:
dot(a_q, w_q) + negative_zero_point * weight_sum[n]
This is equivalent to subtracting a_zero_point * weight_sum[n], which restores the original asymmetric QD8 equation.
weight_sum[n] depends only on static weights and K padding, so the RHS packer calculates it once. The dynamic QD8 zero point can change for every activation row and inference run, but it’s supplied through the packed LHS metadata. It doesn’t require the RHS to be packed again.
Worked packing example
Assume one N tile contains four output channels, K = 8, and kr = 4.
The raw N x K source is conceptually:
channel 0: K0 K1 K2 K3 | K4 K5 K6 K7
channel 1: K0 K1 K2 K3 | K4 K5 K6 K7
channel 2: K0 K1 K2 K3 | K4 K5 K6 K7
channel 3: K0 K1 K2 K3 | K4 K5 K6 K7
The KleidiAI packed tile is conceptually ordered as:
K0..K3 for channels 0..3
K4..K7 for channels 0..3
weight_sum[0..3]
scale[0..3]
bias[0..3]
This diagram explains the data grouping. It doesn’t explain every byte position. The KleidiAI packer defines the exact byte layout required by the SME2 microkernel.
Handle XNN_FLAG_TRANSPOSE_WEIGHTS
Normally, XNNPACK receives packed nibbles in N x K order. With XNN_FLAG_TRANSPOSE_WEIGHTS, the source is instead K x N.
The KleidiAI RHS packer accepts only N x K, so the XNNPACK adapter first creates a temporary N x K packed-nibble buffer:
XNNPACK source:   K x N packed int4
temporary source:  N x K packed int4
KleidiAI RHS packer:   N x K -> qsi4cxp packed RHS
The conversion must move individual nibbles, rather than whole bytes, because the source and destination pack along different matrix dimensions:
const uint8_t source = rhs[k * source_stride + n / 2];
const uint8_t value = (source >> ((n & 1) * 4)) & 0x0F;
transposed_rhs[n * destination_stride + k / 2] |= value << ((k & 1) * 4);
n / 2 and k / 2 select the packed byte. The low or high nibble is selected with & 1. The temporary buffer starts as zeroed bytes, so the |= operation safely writes one nibble at a time.
Use the original model QC4W tensor as the input to the packer selected for the active backend:
  -> XNNPACK native packer -> XNNPACK native microkernel
  -> KleidiAI RHS packer -> KleidiAI SME2 microkernel
The following path is incorrect:
The KleidiAI microkernel would interpret the XNNPACK-native packed bytes using the wrong interleave and metadata offsets. Keep each packed representation private to the microkernel family that created it.
You’ve learned how RHS packing starts with the original QC4W model weights, scales, and bias. A transposed K x N source is converted to N x K. The KleidiAI packer then creates the qsi4cxp layout once during operator creation and reuses the result through the weights cache.
Next, you’ll adapt the dynamic QD8 LHS without requantizing it.
