Preserve QD8 quantization
The selected KleidiAI left-hand side (LHS) format is qai8dxp: asymmetric int8 with dynamic per-row parameters. This matches the XNNPACK QD8 input.
Preserving QD8 quantization corresponds to the third patch 0003-pack-qd8-lhs-for-kai-sme2.patch . The patch adds the static pack_lhs and lhs_packed_size helpers in src/qd8-f16-qc4w-gemm/qd8-f16-qc4w-gemm-minmax-16x64c4-neonsme2.c. The fourth patch 0004-dispatch-qd8-f16-qc4w-through-kai-sme2.patch queries the kernel parameters and calls these helpers from the completed wrapper.
Convert the XNNPACK LHS to the KleidiAI LHS
Before packing, XNNPACK provides two related inputs:
input[M, K]                    signed int8 activation values
quantization_params[M]         one { zero_point, inv_scale } pair per row
input is row-major. Row m starts at input + m * input_stride. Its quantization parameters are stored separately at quantization_params[m].
The KleidiAI Scalable Matrix Extension 2 (SME2) microkernel can’t consume these two arrays directly. It expects one packed qai8dxp LHS buffer. For each group of mr rows, that buffer contains:
| KleidiAI-interleaved int8 values for mr rows |
| int32 negative zero point for each row  |
| float scale for each row                |
The conversion changes the memory layout, but not the quantization meaning:
XNNPACK input[M, K] + quantization_params[M]
  -> KleidiAI qai8dxp packed LHS
The int8 values are copied and interleaved for the KleidiAI inner loop. The separate XNNPACK metadata is appended after the values as KleidiAI metadata.
For each XNNPACK row:
real_value = (q - zero_point) * inv_scale
The KleidiAI packed row stores:
int32 negative_zero_point
float scale
The correct mapping is therefore:
KleidiAI int8 values       = XNNPACK qd8 values
KleidiAI negative zero pt  = -XNNPACK zero_point
KleidiAI scale             = XNNPACK inv_scale
No floating-point dequantization is required. No new int8 quantization is required.
Interleave values for the microkernel
The selected KleidiAI microkernel uses:
kr = 4
sr = 1
For a packed group of mr rows, values are interleaved in groups of four K values:
K[0..3] for row 0
K[0..3] for row 1
K[0..3] for row mr-1
K[4..7] for row 0
The mr value is vector-length dependent, so obtain it from the KleidiAI kernel query function. For a tail M tile, duplicate the last valid row in the packed buffer. The microkernel writes only the requested M rows.
Pad K with the quantized zero
KleidiAI rounds K up to a multiple of 32. For a QD8 row, the quantized representation of real zero is its row’s zero point:
q_zero = zero_point
The following illustrative expression shows how the row zero point supplies padding:
packed_value = k_index < k ? input[k_index] : quantization.zero_point;
This guarantees that padded elements contribute zero to the dot product:
(q_zero - zero_point) * inv_scale = 0
How the packing loop works
The packing helper processes the activation matrix in groups of mr rows. Each group has three adjacent regions in the destination buffer:
| interleaved int8 values | int32 negative zero points | float scales |
For every group, the helper performs the following work:
  1. Selects up to mr source rows starting at m_start
  2. Reuses the last valid source row for the unused packed slots if the final group has fewer than mr rows
  3. Copies values in K blocks of kr, interleaving the same K block from every row
  4. Pads any K values beyond the original K dimension with that row’s quantized zero
  5. Stores -zero_point and inv_scale for every packed row
The completed wrapper obtains kr from the selected KleidiAI microkernel instead of relying on a hard-coded value. The current SME2 kernel reports kr = 4, but querying it keeps the pack layout coupled to the actual kernel contract. This illustrative excerpt from the logic in the fourth patch 0004-dispatch-qd8-f16-qc4w-through-kai-sme2.patch abbreviates the query function names with ellipses:
const size_t kr = kai_get_kr_matmul_clamp_f16_qai8dxp...();
const size_t sr = kai_get_sr_matmul_clamp_f16_qai8dxp...();
assert(sr == 1);
For example, if mr = 4, the values are stored in the following order:
K[0..kr-1] for row 0, row 1, row 2, row 3
K[kr..2*kr-1] for row 0, row 1, row 2, row 3
For an M tail, suppose the final group contains only two valid rows. The packer uses the following source rows:
packed slots:  0  1  2  3
source rows:   8  9  9  9
The matmul call still receives m = 2, so it writes results only for rows 8 and 9. Duplicating row 9 gives the kernel safe data only for the complete packed group.
You’ve traced how the adapter interleaves QD8 values, carries over each row’s quantization parameters, and handles incomplete tiles. The packed LHS preserves the original quantization while supplying the layout KleidiAI expects.
Next, you’ll inspect how the adapter connects to XNNPACK runtime dispatch.
