What you’ll build
You’ll integrate a KleidiAI matrix multiplication microkernel into the existing XNNPACK qd8_f16_qc4w fully connected operator.
The completed path uses a KleidiAI microkernel for Scalable Matrix Extension 2 (SME2) matrix outer product accumulate (MOPA) instructions:
kai_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa
The name identifies the output, operand formats, and instruction family:
  • f16: The output is FP16.
  • qai8dxp: The left-hand side (LHS) is asymmetric int8 quantized per row.
  • qsi4cxp: The right-hand side (RHS) is signed int4 quantized per output channel.
  • sme2_mopa: It uses SME2 matrix outer product accumulate instructions.
This is a framework-integration example. You won’t write a new assembly microkernel. Instead, you’ll learn how to select an existing kernel, adapt framework-owned tensors to its packed layouts, dispatch it safely, and verify correctness.
Clone the tested XNNPACK revision
The patch series that you’ll use was created and tested from the XNNPACK commit 119bb329762be10e63688256bb989a0007445b49.
Other XNNPACK revisions can have different microkernel lists, packing helpers, or operator code. Use this exact revision when you clone and check out XNNPACK:
git clone https://github.com/google/XNNPACK.git
cd XNNPACK
git checkout 119bb329762be10e63688256bb989a0007445b49
Download the patch series
The four patches supply the complete implementation. Download the patches into the XNNPACK checkout directory:
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/integrate-kleidiai-kernel-xnnpack-qd8-f16-qc4w/0001-prepare-qd8-f16-qc4w-sme2-kernel.patch
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/integrate-kleidiai-kernel-xnnpack-qd8-f16-qc4w/0002-support-transposed-kai-qc4w-weights.patch
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/integrate-kleidiai-kernel-xnnpack-qd8-f16-qc4w/0003-pack-qd8-lhs-for-kai-sme2.patch
wget https://raw.githubusercontent.com/pareenaverma/arm-learning-paths/refs/heads/content_review/content/learning-paths/mobile-graphics-and-gaming/integrate-kleidiai-kernel-xnnpack-qd8-f16-qc4w/0004-dispatch-qd8-f16-qc4w-through-kai-sme2.patch
The patch files are named in numeric order. From the XNNPACK directory, apply the patches in order:
git am 0001-prepare-qd8-f16-qc4w-sme2-kernel.patch
git am 0002-support-transposed-kai-qc4w-weights.patch
git am 0003-pack-qd8-lhs-for-kai-sme2.patch
git am 0004-dispatch-qd8-f16-qc4w-through-kai-sme2.patch
You’ll learn about the changes these patches have already applied. Use the snippets in the Learning Path to understand the implementation in your checkout. You don’t need to add them again. After inspecting the patch snippets, you’ll build and validate the integration.
The complete data flow
XNNPACK owns the operator lifecycle. KleidiAI supplies optimized packing and matrix multiplication components:
Create operator
  Raw QC4W weights and FP32 bias
      -> pack RHS once for KleidiAI
      -> optionally store packed RHS in the XNNPACK weights cache
Run operator
  QD8 activation values and per-row quantization parameters
      -> pack LHS for KleidiAI without requantizing
      -> run the SME2 MOPA microkernel
      -> write FP16 output
On a CPU without SME2 support, XNNPACK continues to use its existing native microkernels. This fallback is essential for portability and correctness.
You’ve checked out the tested XNNPACK revision and applied the four integration patches. The checkout is ready for you to inspect the implementation and then build.
Next, you’ll examine the operator inputs before reviewing the kernel selection.
