Integrate a KleidiAI SME2 kernel into XNNPACK
Prepare the XNNPACK baseline
Understand XNNPACK QD8 and QC4W operand formats
Select a compatible KleidiAI microkernel
Inspect QC4W weight packing for the KleidiAI SME2 kernel
Inspect QD8 activation packing without requantizing for KleidiAI
Inspect SME2 kernel configuration and dispatch
Build and validate the integration
Select the KleidiAI SME2 backend
Selection of the KleidiAI SME2 backend corresponds to the fourth patch
0004-dispatch-qd8-f16-qc4w-through-kai-sme2.patch
, which you applied during preparation. Its configuration and registration changes are in init_qd8_f16_qc4w_gemm_config in src/configs/gemm-config.c.
The configuration keeps the existing XNNPACK microkernels as the fallback and selects the KleidiAI path only when XNNPACK detects SME2:
if (hardware_config->arch_flags & xnn_arch_arm_sme2) {
// Configure KleidiAI RHS packing, LHS packing, and the DQGEMM adapter.
} else {
// Continue with the existing native XNNPACK configuration.
The selected backend has two different packing lifetimes:
- Right-hand side (RHS): Pack static weights once during operator creation.
- Left-hand side (LHS): Pack dynamic QD8 activation tiles at runtime.
Both sides must use the layouts expected by the same KleidiAI SME2 matmul microkernel.
Configure the KleidiAI RHS packer
XNNPACK already has an adapter around the KleidiAI qsi4cxp RHS packer:
xnn_pack_kai_qs4_weights_and_biases_sme
xnn_packed_stride_kai_qs4_weights_and_biases_sme
When SME2 is selected, the patch sets the following functions in the GEMM configuration:
qd8_f16_qc4w_gemm_config.pack_weights_and_biases =
xnn_pack_kai_qs4_weights_and_biases_sme;
qd8_f16_qc4w_gemm_config.packed_stride_weights_and_biases =
xnn_packed_stride_kai_qs4_weights_and_biases_sme;
XNNPACK uses this configuration during operator creation. It passes the original QC4W weights, scales, and bias to the KleidiAI RHS packer. The resulting packed RHS, including weight_sum[n], is stored in operator memory or the XNNPACK weights cache.
Configure the KleidiAI LHS packer
There’s no persistent LHS buffer at operator creation because QD8 activations and their quantization parameters change for every invocation.
Instead, the XNNPACK dynamically quantized general matrix multiplication (DQGEMM) adapter packs each activation tile immediately before calling KleidiAI:
raw qd8 int8 values + qd8 parameters
-> KleidiAI qai8dxp packed LHS
-> KleidiAI SME2 MOPA matmul
The adapter uses the private pack_lhs helper in the SME2 wrapper file. It performs the following mapping for each activation row:
KleidiAI int8 values = XNNPACK qd8 values
KleidiAI negative zero pt = -XNNPACK zero_point
KleidiAI scale = XNNPACK inv_scale
The adapter also queries KleidiAI kr and sr and checks that sr == 1. It interleaves the values in kr-sized blocks, and pads the K tail with the row zero point. For the packed-LHS layout, see
Pack the QD8 activation without requantizing
Register the DQGEMM adapter
The configuration queries the KleidiAI tile sizes and registers the adapter for both the single-row and full-MR cases:
const size_t mr =
xnn_qd8_f16_qc4w_gemm_minmax_ukernel_16x64c4__neonsme2_get_mr();
const size_t nr =
xnn_qd8_f16_qc4w_gemm_minmax_ukernel_16x64c4__neonsme2_get_nr();
qd8_f16_qc4w_gemm_config.minmax.dqgemm[XNN_MR_TO_INDEX(1)] =
XNN_INIT_HMP_DQGEMM_UKERNEL(
xnn_qd8_f16_qc4w_gemm_minmax_ukernel_16x64c4__neonsme2);
qd8_f16_qc4w_gemm_config.minmax.dqgemm[XNN_MR_TO_INDEX(mr)] =
The integration uses the following KleidiAI packing parameters:
kr = 4
sr = 1
The adapter in src/qd8-f16-qc4w-gemm/qd8-f16-qc4w-gemm-minmax-16x64c4-neonsme2.c calls:
kai_run_matmul_clamp_f16_qai8dxp1vlx8_qsi4cxp4vlx8_1vlx4vl_sme2_mopa
It passes the output row stride, an FP16 column stride of two bytes, and XNNPACK’s FP16 clamp range as inputs.
This step corresponds to the fourth patch
The patch also changes the generated SME2 source lists. Run the generator after adding or renaming a file that ends in -neonsme2.c:
python3 tools/update-microkernels.py
Depending on your Python version, the generator might report DeprecationWarning: codecs.open() is deprecated. Use open() instead. This warning alone doesn’t indicate a failure. Check that the script completes successfully.
Before this dispatch is registered, the new wrapper is listed as a non-production SME2 source. After gemm-config.c registers the wrapper, the generator finds it in the configuration and moves it to the production SME2 source list. Don’t edit the generated list files manually.
Understand the adapter
The adapter has the standard XNNPACK DQGEMM application binary interface (ABI). XNNPACK calls it with the following:
- An int8 activation tile
- A pointer to packed weights
- The FP16 output tile
- Clamp parameters
- The QD8 parameters for the activation rows
The adapter performs three operations:
raw QD8 tile + per-row parameters
-> pack_lhs() into KleidiAI qai8dxp layout
-> kai_run_matmul_clamp_f16_qai8dxp...sme2_mopa()
-> FP16 output tile
The wrapper filename uses the XNNPACK-style label 16x64c4__neonsme2. It’s not a fixed runtime tile size. The actual M and N tile sizes are queried from KleidiAI because they depend on the SME streaming vector length.
The adapter currently allocates a temporary packed-LHS buffer for each DQGEMM call. This keeps the first integration simple and correct. The next optimization is to allocate and reuse a workspace buffer so that the same LHS isn’t repacked for every N tile.
You’ve followed the applied configuration from SME2 detection through packing and adapter registration to the KleidiAI call.
Next, you’ll build the patched checkout and run the correctness and fallback-build checks.
