To harness the power of hardware ray tracing with Lumen in your application, follow these steps to configure your project settings:
Enable SM5 Shader Format:
- Lumen operates only when the SM5 shader format is active. Navigate to your project settings under Platforms - Android.
- Enable the option labeled Support Vulkan Desktop [Experimental] to activate SM5 shader format support, as shown below.
Select Deferred Shading Mode:
- Currently, Lumen exclusively supports deferred shading mode. Go to your project settings under Engine - Rendering.
- Uncheck Forward Shading under the Forward Renderer option, as shown below.
Enable Hardware Ray Tracing Support:
- Next, enable hardware ray tracing for the entire engine. In your project settings under Engine - Rendering, check the box for Support Hardware Ray Tracing, as shown below.
Use Hardware Ray Tracing When Available:
- As previously mentioned, Lumen can utilize both software and hardware ray tracing. To prioritize hardware acceleration, check Use Hardware Ray Tracing when available in the project settings under Engine - Rendering, as shown below.
- This setting ensures that your application leverages hardware ray tracing first, falling back to software ray tracing if necessary.
Configure Console Variables:
- Edit your engine configuration file to set up two essential console variables as per the following:
- Set
r.Android.DisableVulkanSM5Support=0 to remove any restrictions related to SM5 shader format usage. - Enable Ray Query shader support for Vulkan by setting
r.RayTracing.AllowInline=1.
Your Lumen-powered application is now ready to dazzle with hardware-accelerated ray tracing!
