Explore related resources
Give feedback
AI-assisted
Close
How do I know if I installed Android Build Support correctly?
Open the Build Settings window and check that Android appears as a selectable platform. If you can switch the project’s active platform to Android, the support is installed.
What should I see in the sample scene before building?
The scene contains a Main Camera, a Directional Light, and a Cube with a Spin.cs script attached. When you run the scene, the cube rotates.
Which platform should I make active before I build the project?
Set Android as the active platform in the Build Settings window. Building with the correct active platform ensures the output targets your Android device.
How do I confirm the Profiler is collecting data?
Open the Profiler on Unity and watch for the timeline to populate with frame samples. CPU, Rendering, and Memory charts should update as the app runs.
Should I profile in the editor or on my device first?
Start profiling in the Unity Editor for quick checks, then profile on your Android device to observe behavior on target hardware. Use both views to compare results across environments.
Return to Mobile, Graphics, and Gaming
