Follow these steps to implement Arm Accuracy Super Resolution (Arm ASR) in your custom engine.
Arm ASR is an optimized variant of Fidelity Super Resolution 2 (FSR2) that includes extensive mobile-specific optimizations, ensuring high performance on mobile devices.
You can integrate Arm ASR into your custom engine using one of two methods:
See the following sections to learn how to configure Arm ASR:
Get the Arm ASR package from GitHub:
git clone https://github.com/arm/accuracy-super-resolution-generic-library
cd accuracy-super-resolution-generic-library
Set a variable for the package location for easy reference.
You will use this path to refer to files in the repository:
export ARMASR_DIR=$(pwd)
To quickly integrate Arm ASR using the standalone backend, follow these steps below:
Copy the Arm_ASR directory into your project, and add Arm_ASR/src/backends/shared/blob_accessors/prebuilt_shaders to your include path to use prebuilt shaders.
Include the following header files in your code:
$ARMASR_DIR/include/host/ffxm_fsr2.h$ARMASR_DIR/include/host/backends/vk/ffxm_vk.hCreate a Vulkan backend by:
ffxmGetScratchMemorySizeVK (defined in $ARMASR_DIR/include/host/backends/vk/ffxm_vk.h).FfxmDevice using ffxmGetDeviceVK.FfxmInterface using ffxmGetInterfaceVK.Create a context by calling ffxmFsr2ContextCreate from $ARMASR_DIR/include/host/ffxm_fsr2.h. Ensure the parameters structure matches the configuration of your application.
Call ffxmFsr2ContextDispatch every frame to record and execute workloads. Again, the parameters structure should match the configuration of your application.
When your application is terminating (or you wish to destroy the context for another reason) you should call ffxmFsr2ContextDestroy accessed via $ARMASR_DIR/include/host/ffxm_fsr2.h. The GPU should be idle before calling this function.
Sub-pixel jittering should be applied to your application’s projection matrix. This should be done when performing the main rendering of your application. You should use the ffxmFsr2GetJitterOffset function accessed via $ARMASR_DIR/include/host/ffxm_fsr2.h to compute the precise jitter offsets.
A global Mip bias should be applied when texturing. Applying a negative Mipmap biasing will typically generate an upscaled image with better texture detail. We recommend applying the following formula to your Mipmap bias:
mipBias = log2(renderResolution/displayResolution) - 1.0;
For the best upscaling quality it is strongly advised that you populate the Reactive mask according to our guidelines. You can also use ffxmFsr2ContextGenerateReactiveMask accessed via $ARMASR_DIR/include/host/ffxm_fsr2.h as a starting point.
Finally, link the two built libraries (Arm_ASR_api and Arm_ASR_backend).
If you wish to use your own backend/renderer, a tight integration with your engine is required. For this, a similar process to the
Quick Integration
described above is required, but with the added requirement to fill the FfxmInterface accessed via $ARMASR_DIR/include/host/ffxm_interface.h with functions implemented on your end.
In this approach the shaders are expected to be built by the engine. Arm ASR’s shaders have been micro-optimized to use explicit 16-bit floating-point types. It is therefore advisable that the shaders are built using such types. For example, min16float is used in High-level shader language (HLSL) and float16_t in OpenGL Shading Language (GLSL). If you are using HLSL, define the following symbol with a value of 1:
#define FFXM_HLSL_6_2 1
The FFXM_HALF symbol is enabled by default in the provided shader sources.
Include the following header in your codebase:
$ARMASR_DIR/include/host/ffxm_interface.hImplement your own functions (assume the names are xxxGetInterfacexxx, xxxGetScratchMemorySizexxx) and callbacks in FfxmInterface in $ARMASR_DIR/include/host/ffxm_interface.h to link Arm ASR with the engine’s renderer.
Create your own backend by calling xxxGetInterfacexxx. A scratch buffer should be allocated of the size returned by calling xxxGetScratchMemorySizexxx and the pointer to that buffer passed to xxxGetInterfacexxx.
Now, you can follow the same steps from the quick integration instructions above, starting from step 4, creating an Arm ASR context. In the final step it is only necessary to link the Arm_ASR_api library.
In the following section, additional details for integrating Arm ASR are listed.
The FfxmFsr2ContextDescription from $ARMASR_DIR/include/host/ffxm_fsr2.h is referenced multiple times throughout the Integration Guidelines. You should configure the flags field of this structure when modifying those bits, by setting the variables in FfxmFsr2InitializationFlagBits.
In an HLSL-based workflow using DirectX Shader Compiler to cross-compile to SPIR-V do the following:
Use the following flags when building:
-fspv-target-env=vulkan1.1spirv1.4 -enable-16bit-types
The extension VK_KHR_shader_float16_int8 should be used at runtime.
The Arm ASR API provides a set of shader quality presets, to select a version of the technique that balances quality and performance:
| Preset | Description |
| Quality | An optimized version of FSR2 that maintains the same image quality as the original technique. |
| Balanced | Provides significant bandwidth savings and performance uplift while maintaining image quality close to the Quality preset. |
| Performance | A more aggressive preset that offers the highest performance with some quality sacrifices. |
When creating a context, a FfxmFsr2ShaderQualityMode accessed via $ARMASR_DIR/include/host/ffxm_fsr2.h needs to be provided as part of the input settings in FfxmFsr2ContextDescription.
To enhance flexibility when using the technique, developers can specify both a shader quality preset and an upscaling ratio. They can select any combination of FfxmFsr2ShaderQualityMode and FfxmFsr2UpscalingRatio according to their requirements to adjust the balance between quality and performance of the application.
A couple of utilities are available to determine the source resolution the frame should use for rendering before upscaling. This calculation is based on the desired upscaling ratio, defined by FfxmFsr2UpscalingRatio. You can find this definition in $ARMASR_DIR/include/host/ffxm_fsr2.h.
float ffxmFsr2GetUpscaleRatioFactor(FfxmFsr2UpscalingRatio upscalingRatio)
FfxErrorCode ffxmFsr2GetRenderResolutionFromUpscalingRatio(
uint32_t* renderWidth,
uint32_t* renderHeight,
uint32_t displayWidth,
uint32_t displayHeight,
Unless you are using the prebuilt shaders with the standalone VK backend, be aware of the following definitions when integrating Arm ASR shaders:
The following table shows the list of the different shader mutators that you can use. All of these must be defined with a value of 0 or 1. The shader variant to use is determined internally by the getPipelinePermutationFlags(…) function, based on factors such as user-defined flags and shader quality settings.
| Define | Description |
| FFXM_FSR2_OPTION_HDR_COLOR_INPUT | If 1, assumes that the input color is in linear RGB. |
| FFXM_FSR2_OPTION_LOW_RESOLUTION_MOTION_VECTORS | If 1, assumes the input motion vectors texture is in low resolution |
| FFXM_FSR2_OPTION_JITTERED_MOTION_VECTORS | If 1, assumes jittered motion vectors using the same jitter offsets as the input color and depth. |
| FFXM_FSR2_OPTION_INVERTED_DEPTH | If 1, assumes the input depth containing reversed depth values (far == 0.0f) |
| FFXM_FSR2_OPTION_APPLY_SHARPENING | If 1, informs the shaders that RCAS (sharpening) pass will be used. |
| FFXM_FSR2_OPTION_SHADER_OPT_BALANCED | If 1, enables a batch of optimizations when the Balanced quality preset is selected. |
| FFXM_FSR2_OPTION_SHADER_OPT_PERFORMANCE | If 1, enables a batch of optimizations when the Performance quality preset is selected. When this is enabled, then FFXM_FSR2_OPTION_SHADER_OPT_BALANCED is enabled too. |
Lastly, when using an HLSL-based workflow, you also have the FFXM_HLSL_6_2 global define. If defined with a value of 1, this will enable the use of explicit 16-bit types instead of relying on half (RelaxedPrecision). The VK_KHR_shader_float16_int8 extension is required on Vulkan.
Arm ASR is a temporal algorithm, and therefore requires access to data from both the current and previous frame. The following table enumerates all external inputs required by it, with most function names available in $ARMASR_DIR/include/host/ffxm_fsr2.h.
The resolution column indicates if the data should be at ‘rendered’ resolution or ‘presentation’ resolution. ‘Rendered’ resolution indicates that the resource should match the resolution at which the application is performing its rendering. Conversely, ‘presentation’ indicates that the resolution of the target should match that which is to be presented to the user. All resources are from the current rendered frame, for Vulkan applications all input resources should be transitioned to
VK_ACCESS_SHADER_READ_BIT
respectively before calling ffxmFsr2ContextDispatch.
| Name | Resolution | Format | Type | Notes |
| Color buffer | Render | APPLICATION SPECIFIED | Texture | The current frame’s color data. If HDR, enable FFXM_FSR2_ENABLE_HIGH_DYNAMIC_RANGE in FfxmFsr2ContextDescription. |
| Depth buffer | Render | APPLICATION SPECIFIED (1x FLOAT) | Texture | The depth buffer for the current frame. The data should be provided as a single floating point value, the precision of which is under the application’s control. Configure the depth through the FfxmFsr2ContextDescription when creating the FfxmFsr2Context. If the buffer is inverted, set FFXM_FSR2_ENABLE_DEPTH_INVERTED flag ([1..0] range). If the buffer has an infinite far plane, set the FFXM_FSR2_ENABLE_DEPTH_INFINITE. If the application provides the depth buffer in D32S8 format, then it will ignore the stencil component of the buffer, and create an R32_FLOAT resource to address the depth buffer. |
| Motion vectors | Render or presentation | APPLICATION SPECIFIED (2x FLOAT) | Texture | The 2D motion vectors for the current frame, in [<-width, -height> … <width, height>] range. If your application renders motion vectors with a different range, you may use the motionVectorScale field of the FfxmFsr2DispatchDescription structure to adjust them to match the expected range for Arm ASR. Internally, Arm ASR uses 16-bit quantities to represent motion vectors in many cases, which means that while motion vectors with greater precision can be provided, Arm ASR will not benefit from the increased precision. The resolution of the motion vector buffer should be equal to the render resolution, unless the FFXM_FSR2_ENABLE_DISPLAY_RESOLUTION_MOTION_VECTORS flag is set when creating the FfxmFsr2Context, in which case it should be equal to the presentation resolution. |
| Reactive mask | Render | R8_UNORM | Texture | As some areas of a rendered image do not leave a footprint in the depth buffer or include motion vectors, Arm ASR provides support for a reactive mask texture. This can be used to indicate to the technique where such areas are. Good examples of these are particles, or alpha-blended objects which do not write depth or motion vectors. If this resource is not set, then Arm ASR’s shading change detection logic will handle these cases as best it can, but for optimal results, this resource should be set. For more information on the reactive mask please refer to the Reactive mask section. |
| Exposure | 1x1 | R32_FLOAT/ R16_FLOAT | Texture | The exposure value computed for the current frame. This resource may be omitted if the FFXM_FSR2_ENABLE_AUTO_EXPOSURE flag in the FfxmFsr2ContextDescription structure when creating FfxmFsr2Context. |
All inputs that are provided at Render Resolution, except for motion vectors, should be rendered with jitter. By default, Motion vectors are expected to be unjittered unless the FFXM_FSR2_ENABLE_MOTION_VECTORS_JITTER_CANCELLATION flag is present.
A key part of a temporal algorithm (be it antialiasing or upscaling) is the provision of motion vectors. Arm ASR accepts motion vectors in 2D which encode the motion from a pixel in the current frame to the position of that same pixel in the previous frame. It expects that motion vectors are provided by the application in [<-width, -height>..<width, height>] range; this matches Screen-Space. For example, a motion vector for a pixel in the upper-left corner of the screen with a value of <width, height> would represent a motion that traversed the full width and height of the input surfaces, originating from the bottom-right corner.
If your application computes motion vectors in another space - for example normalized device coordinate space - then you may use the motionVectorScale ($ARMASR_DIR/include/host/ffxm_fsr2.h) field of the FfxmFsr2DispatchDescription structure to instruct the technique to adjust them to match the expected range. The code examples below illustrate how motion vectors may be scaled to screen space. The example HLSL and C++ code below illustrates how NDC-space motion vectors can be scaled using the Arm ASR host API.
GPU: Example of application NDC motion vector computation
float2 motionVector = (previousPosition.xy / previousPosition.w) \
- (currentPosition.xy / currentPosition.w);
CPU: Matching Arm ASR motionVectorScale configuration
dispatchParameters.motionVectorScale.x = (float)renderWidth;
dispatchParameters.motionVectorScale.y = (float)renderHeight;
Internally, Arm ASR uses 16-bit quantities to represent motion vectors in many cases, which means that while motion vectors with greater precision can be provided, it will not currently benefit from the increased precision. The resolution of the motion vector buffer should be equal to the render resolution. If the FFXM_FSR2_ENABLE_DISPLAY_RESOLUTION_MOTION_VECTORS flag is set in FfxmFsr2ContextDescription when creating the FfxmFsr2Context, it should be equal to the presentation resolution.
Arm ASR will perform better quality upscaling when more objects provide their motion vectors. It is therefore advised that all opaque, alpha-tested and alpha-blended objects should write their motion vectors for all covered pixels. If vertex shader effects are applied, such as scrolling UVs, these calculations should also be factored into the calculation of motion for the best results. For alpha-blended objects it is also strongly advised that the alpha value of each covered pixel is stored to the corresponding pixel in the reactive mask . This will allow the technique to perform better handling of alpha-blended objects during upscaling. The reactive mask is especially important for alpha-blended objects where writing motion vectors might be prohibitive, such as particles.
In the context of Arm ASR, the term “reactivity” means how much influence the samples rendered for the current frame have over the production of the final upscaled image. Typically, samples rendered for the current frame contribute a relatively modest amount to the result computed by the algorithm; however, there are exceptions. As there is no good way to determine from either color, depth or motion vectors which pixels have been rendered using alpha blending, Arm ASR performs best when applications explicitly mark such areas.
Therefore, it is strongly encouraged that applications provide a reactive mask as an input. The reactive mask guides Arm ASR on where it should reduce its reliance on historical information when compositing the current pixel, and instead allow the current frame’s samples to contribute more to the final result. The reactive mask allows the application to provide a value from [0.0..1.0] where 0.0 indicates that the pixel is not at all reactive (and should use the default composition strategy), and a value of 1.0 indicates the pixel should be fully reactive. This is a floating point range and can be tailored to different situations.
While there are other applications for the reactive mask, the primary application for the reactive mask is producing better results of upscaling images which include alpha-blended objects. A good proxy for reactiveness is the alpha value used when compositing an alpha-blended object into the scene. Therefore, applications should write alpha to the reactive mask. It should be noted that it is unlikely that a reactive value of close to 1 will ever produce good results. Therefore, you should clamp the maximum reactive value to around 0.9.
Provide a reactive mask by setting the reactive field of FfxmFsr2DispatchDescription to NULL.
If a reactive mask is not provided then an internally generated 1x1 texture with a cleared reactive value will be used.
To help applications generate the reactive mask, there is an optional utility pass. Under the hood, the API launches a fragment shader which computes these values for each pixel using a luminance-based heuristic.
To do this, the applications can call the ffxmFsr2ContextGenerateReactiveMask ($ARMASR_DIR/include/host/ffxm_fsr2.h) function and should pass two versions of the color buffer: one containing opaque only geometry, and the other containing both opaque and alpha-blended objects.
Arm ASR provides two values which control the exposure used when performing upscaling:
Pre-exposure: a value by which you can divide the input signal to get back to the original signal produced by the game before any packing into lower precision render targets.
Exposure: a value which is multiplied against the result of the pre-exposed color value.
The exposure value should match that which the application uses during any subsequent tonemapping passes performed by the application. This means Arm ASR will operate consistently with what is likely to be visible in the final tonemapped image.
In various stages of the algorithm, the technique will compute its own exposure value for internal use. It is worth noting that all outputs will have this internal tonemapping reversed before the final output is written. Meaning that Arm ASR returns results in the same domain as the original input signal.
Poorly selected exposure values can have a drastic impact on the final quality of Arm ASR’s upscaling. Therefore, it is recommended that FFXM_FSR2_ENABLE_AUTO_EXPOSURE is used by the application, unless there is a particular reason not to. When FFXM_FSR2_ENABLE_AUTO_EXPOSURE is set in the FfxmFsr2ContextDescription structure, the exposure calculation in ComputeAutoExposureFromLavg ($ARMASR_DIR/include/gpu/fsr2/ffxm_fsr2_common.h) is used to compute the exposure value, which matches the exposure response of ISO 100 film stock.
The design of the Arm ASR API means that the core implementation of the algorithm is unaware of which rendering API it sits upon. Instead, it calls functions provided to it through an interface, allowing different backends to be used with the technique. Applications which have their own rendering abstractions can implement their own backend, taking control of all aspects of Arm ASR’s underlying function. This includes memory management, resource creation, shader compilation, shader resource bindings, and the submission of the workloads to the graphics device.
Out of the box, the API will compile into multiple libraries following the separation already outlined between the core API and the backends. This means if you wish to use the backends provided, you should link both the core API lib Arm_ASR_api as well the backend Arm_ASR_backend matching your requirements.
Arm ASR only provides a built-in Vulkan backend as it targets Vulkan mobile apps.
Arm ASR relies on the application to apply sub-pixel jittering while rendering - this is typically included in the projection matrix of the camera. To make the application of camera jitter simple, the API provides a small set of utility function which computes the sub-pixel jitter offset for a particular frame within a sequence of separate jitter offsets.
int32_t ffxmFsr2GetJitterPhaseCount(int32_t renderWidth, int32_t displayWidth);
FfxErrorCode ffxmFsr2GetJitterOffset(float* outX, float* outY, int32_t jitterPhase, int32_t sequenceLength);
Internally, these functions implement a Halton[2,3] sequence. The goal of the Halton sequence is to provide spatially separated points, which cover the available space.
It is important to understand that the values returned from the ffxmFsr2GetJitterOffset ($ARMASR_DIR/include/host/ffxm_fsr2.h) are in unit pixel space, and in order to composite this correctly into a projection matrix you have to convert them into projection offsets. The code below shows how to correctly composite the sub-pixel jitter offset value into a projection matrix.
const int32_t jitterPhaseCount = ffxmFsr2GetJitterPhaseCount(renderWidth, displayWidth);
float jitterX = 0;
float jitterY = 0;
ffxmFsr2GetJitterOffset(&jitterX, &jitterY, index, jitterPhaseCount);
// Calculate the jittered projection matrix.
const float jitterX = 2.0f * jitterX / (float)renderWidth;
const float jitterY = -2.0f * jitterY / (float)renderHeight;
const Matrix4 jitterTranslationMatrix = translateMatrix(Matrix3::identity, Vector3(jitterX, jitterY, 0));
const Matrix4 jitteredProjectionMatrix = jitterTranslationMatrix * projectionMatrix;
Jitter should be applied to all rendering. This includes opaque, alpha transparent, and raytraced objects. For rasterized objects, the sub-pixel jittering values calculated by the ffxmFsr2GetJitterOffset ($ARMASR_DIR/include/host/ffxm_fsr2.h) function can be applied to the camera projection matrix which is ultimately used to perform transformations during vertex shading. For raytraced rendering, the sub-pixel jitter should be applied to the ray’s origin - often the camera’s position.
Whether you decide whether to use the recommended ffxmFsr2GetJitterOffset function or your own sequence generator, you must set the jitterOffset field of the FfxmFsr2DispatchDescription structure to inform the algorithm of the jitter offset that has been applied in order to render each frame. Moreover, if not using the recommended ffxmFsr2GetJitterOffset function, care should be taken that your jitter sequence never generates a null vector; that is value of 0 in both the X and Y dimensions.
Most applications with real-time rendering have a large degree of temporal consistency between any two consecutive frames. However, there are cases where a change to a camera’s transformation might cause an abrupt change in what is rendered. In such cases, Arm ASR is unlikely to be able to reuse any data it has accumulated from previous frames, and should clear this data in order to exclude it from consideration in the compositing process. In order to indicate that a jump cut has occurred with the camera you should set the reset field of the FfxmFsr2DispatchDescription structure to true for the first frame of the discontinuous camera transformation.
Rendering performance may be slightly less than typical frame-to-frame operation when using the reset flag, as Arm ASR will clear some additional internal resources.
Applying a negative mipmap biasing will typically generate an upscaled image with better texture detail. It is recommended that you apply the following formula to your Mipmap bias:
The API requires frameTimeDelta be provided by the application through the FfxmFsr2DispatchDescription structure. This value is in milliseconds. If running at 60fps, the value passed should be around 16.6f.
The value is used within the temporal component of the auto-exposure feature. This allows for tuning of the history accumulation for quality purposes.
High dynamic range images are supported. To enable this, you should set the FFXM_FSR2_ENABLE_HIGH_DYNAMIC_RANGE flag in the FfxmFsr2ContextDescription structure. Provide the input color image in linear RGB color space.
The context description structure can be provided with a callback function for passing textual warnings from the runtime to the underlying application. The fpMessage member of the description is of type FfxmFsr2Message which is a function pointer for passing string messages of various types. Assigning this variable to a suitable function, and passing the FFXM_FSR2_ENABLE_DEBUG_CHECKING flag within FfxmFsr2ContextDescription will enable the feature. It is recommended this is enabled only in debug development builds.
Most of the workloads in the upscalers have been converted to fragment shaders. Since the workflow using the standalone VK backend relies on reflection data generated with
AMD's Shader Compiler
, it becomes necessary to do an improvised extension of the tool to provide reflection data for the RenderTargets so resources could be resolved automatically in the backend. Users might want to evolve the algorithm potentially changing the RenderTargets in the process. Thus, a diff file is provided with the changes that were applied locally ffx_shader_compiler ($ARMASR_DIR/tools/ffx_shader_compiler.diff) for the latest version of the technique.
There is a helper script provided to generate prebuilt shaders which are used for standalone backend. Make sure python is installed, and run it with the following command:
python $ARMASR_DIR/tools/generate_prebuilt_shaders.py
You will find the output from the script in $ARMASR_DIR/src/backends/shared/blob_accessors/prebuilt_shaders.
Running Arm ASR on GLES is possible when using the Tight Integration approach. In this scenario, you have to apply two changes:
When creating the context, the user has to specify the flag FFXM_FSR2_OPENGL_ES_3_2 in the FfxmFsr2ContextDescription. This triggers changes internally so that Arm ASR adapts to a GLES- friendly approach.
The permutationOptions ($ARMASR_DIR/include/host/ffxm_interface.h) provided when creating the pipelines now includes the new permutation option FSR2_SHADER_PERMUTATION_PLATFORM_GLES_3_2 ($ARMASR_DIR/src/components/fsr2/ffxm_fsr2_private.h). This is a hint that you need to use the shader variants for the technique with the following symbol defined:
#define FFXM_SHADER_PLATFORM_GLES_3_2 1
You are now ready to use Arm ASR in your game engine projects. Go to the next section to explore further resources on Arm ASR.
