What you’ll build
You’ll benchmark Gemma 4 CPU inference with LiteRT-LM and KleidiAI on macOS. You’ll compare baseline and optimized XNNPACK builds to measure prefill and decode throughput.
The optimized build improves one-thread decode by 53.6% on Apple M4 Pro and 44.5% on the Android example. Prefill and thread scaling vary by device, so compare both phases using the same model and settings.
Confirm SME2 support on your device
Use an SME2-capable Mac, such as an M4-family Mac. For Mac and Android examples, see the devices with native SME2 support .
A macOS device is used as an example in this Learning Path.
Confirm the host architecture and SME feature flags:
uname -m
sysctl hw.optional.arm.FEAT_SME
sysctl hw.optional.arm.FEAT_SME2
The expected output on a supported Apple M4 system is:
        arm64
hw.optional.arm.FEAT_SME: 1
hw.optional.arm.FEAT_SME2: 1
If either feature reports 0, XNNPACK can’t dispatch the SME2 kernels and the macOS performance comparison isn’t valid.
Create the workspace
Create a working directory outside the Learning Paths repository:
mkdir -p $HOME/gemma4-prefill-bench
cd $HOME/gemma4-prefill-bench
Clone the sources
Note
The commands check out specific revisions so that you can reproduce the benchmark results.
Clone LiteRT-LM, KleidiAI, and XNNPACK:
git clone https://github.com/google-ai-edge/LiteRT-LM.git LiteRT-LM
git -C LiteRT-LM checkout 924e79c91542761242244e4f1651851f822e4cbb
git clone https://github.com/ARM-software/kleidiai.git kleidiai
git -C kleidiai checkout 02f7b3df98c39df1884eead7461c3269feca4ddc
git clone https://github.com/google/XNNPACK.git xnnpack
git -C xnnpack fetch origin 27199f7c0b5d0178a67f666d2ba85db56ec9858e
git -C xnnpack checkout --detach 27199f7c0b5d0178a67f666d2ba85db56ec9858e
Create the baseline
Create a separate XNNPACK worktree for the baseline. It already includes earlier SME2 support; the optimized build adds the static INT2 SME2 kernels.
git -C xnnpack worktree add --detach ../xnnpack-baseline \
  c6b52536d3f614793f21ab4a17ae1cde73cc0333
You’ve prepared the sources and baseline.
Next, you’ll install the build tools and download the Gemma 4 model.
