Build and benchmark one XNNPACK variant
Create directories for the shared Bazel output and benchmark results:
cd $HOME/gemma4-prefill-bench
mkdir -p bazel-output-base bin results
Define a shell function that builds one XNNPACK tree and immediately runs the same three-iteration benchmark at one and four CPU threads:
set -o pipefail
run_variant() {
  local variant="$1"
  local xnnpack_dir="$2"
  local root="$HOME/gemma4-prefill-bench"
  local output_base="$root/bazel-output-base/ab"
  local model="$root/models/gemma-4-E2B-it-litert-lm/gemma-4-E2B-it.litertlm"
  local sdk_version
  local binary
  local threads
  local result
  sdk_version="$(xcrun --sdk macosx --show-sdk-version)"
  cd "$root/LiteRT-LM"
  bazelisk --output_base="$output_base" build \
    --config=macos_arm64 \
    --macos_sdk_version="$sdk_version" \
    --define=xnn_enable_arm_sme2=true \
    --define=xnn_enable_kleidiai=true \
    --override_repository=XNNPACK="$xnnpack_dir" \
    --override_repository=KleidiAI="$root/kleidiai" \
    //runtime/engine:litert_lm_advanced_main || return
  binary="$root/bin/litert_lm_advanced_main-${variant}-macos"
  cp -L bazel-bin/runtime/engine/litert_lm_advanced_main "$binary" || return
  for threads in 1 4; do
    result="${variant}-${threads}t"
    DYLD_LIBRARY_PATH="$root/LiteRT-LM/prebuilt/macos_arm64" "$binary" \
      --backend=cpu \
      --model_path="$model" \
      --benchmark \
      --benchmark_prefill_tokens=1024 \
      --benchmark_decode_tokens=256 \
      --max_num_tokens=4096 \
      --num_cpu_threads="$threads" \
      --disable_cache=true \
      --async=false \
      --num_iterations=3 \
      --report_peak_memory_footprint \
      --metric_proto_file_path="$root/results/${result}.pb" \
      2>&1 | tee "$root/results/${result}.log" || return
  done
The first build can take several minutes. DYLD_LIBRARY_PATH points each saved binary to LiteRT-LM’s matching Gemma constraint-provider library.
Run the baseline and optimized builds:
run_variant baseline "$HOME/gemma4-prefill-bench/xnnpack-baseline"
run_variant optimized "$HOME/gemma4-prefill-bench/xnnpack"
Each run writes its log and metrics to results/. Keep caches disabled and other applications idle when comparing the builds.
Compare prefill and decode
Read Prefill Speed and Decode Speed in tokens per second. Discard the first iteration as warm-up, then average the second and third iterations for each build and thread count.
Calculate the changes separately:
throughput change (%) = 100 * (optimized throughput / baseline throughput - 1)
A positive value means higher throughput, and a negative value is a regression. Prefill and decode scale differently, so compare both phases at both thread counts.
Note
If you see Failed to get prefill profile summary or its decode equivalent with profiling disabled, check that all three iterations finish. Also check that the command exits successfully. Collect operator profiles separately to avoid timing overhead.
Compare two device examples
The following examples use LiteRT-LM v0.16.1 and KleidiAI v1.31.0 with the same model and benchmark settings:
  • 1,024 prefill tokens
  • 256 decode tokens
  • Disabled caches and profiling
Values are the mean of the second and third iterations. Percentage changes compare the optimized build with the baseline.
DeviceCPU threadsPrefill tokens per secondPrefill changeDecode tokens per secondDecode change
Apple M4 Pro1137.79−3.4%17.40+53.6%
Apple M4 Pro4458.62+0.3%25.91+12.8%
Xiaomi 2608BPX34C175.35+16.3%10.10+44.5%
Xiaomi 2608BPX34C4240.86+2.0%17.54+4.2%
The Mac uses unrestricted CPU scheduling, while the Android uses CPUs 4–7. Frequencies aren’t fixed. The small Mac prefill changes and Android four-thread changes are within observed run variation, so results will vary by device and conditions.
In a separate Android comparison, enabling SME2 improves four-thread prefill by 53.7% and lowers decode by 9.1%.
That comparison includes all SME2 kernels. The table isolates the static INT2 addition.
Note
For Android, you also need an SME2-capable phone, the Android SDK, NDK r28b or newer, and an authorized adb connection. Follow the Android SME2 development setup . Set ANDROID_HOME and ANDROID_NDK_HOME, then use --config=android_arm64 with the same repository overrides. Copy the Android binary, model, and prebuilt/android_arm64/libGemmaModelConstraintProvider.so to the device. Run from that directory with LD_LIBRARY_PATH=. and choose a valid CPU mask with taskset.
Check the output and accelerated operator
After building a variant, use its generated binary for a short prompt:
binary="$root/bin/litert_lm_advanced_main-optimized-macos"
  --backend=cpu --model_path="$model" \
  --input_prompt="What is the capital of France?" \
  --max_output_tokens=16 --num_cpu_threads=4 \
  --disable_cache=true --async=false
Confirm that the answer identifies Paris.
Collect operator evidence with a separate short benchmark:
  --backend=cpu --model_path="$model" --benchmark \
  --benchmark_prefill_tokens=128 --benchmark_decode_tokens=8 \
  --max_num_tokens=4096 --num_cpu_threads=1 --num_iterations=1 \
  --disable_cache=true --async=false --enable_profiling=true
Look for Fully Connected (NC, PQS8, QC2W) in the summary to confirm that the static INT2 SME2 path ran. Keep profiling disabled for timed measurements.
What you’ve accomplished
You’ve benchmarked both builds on macOS, compared prefill and decode, and verified the accelerated operator.
You can use the same settings when testing another SME2 device.
