Benchmark Gemma 4 CPU inference with KleidiAI and SME2
Set up the Gemma 4 benchmark workspace
Install prerequisites on macOS and download Gemma 4
Build and compare benchmarks on macOS
Install Xcode Command Line Tools if they’re not already available:
xcode-select --install
Install Bazelisk:
brew install bazelisk
Install the Hugging Face Hub CLI in a virtual environment:
python3 -m venv "$HOME/gemma4-prefill-bench/.venv"
source "$HOME/gemma4-prefill-bench/.venv/bin/activate"
python3 -m pip install -U huggingface_hub
Download Gemma 4 from Hugging Face
Create a shared model directory in the workspace:
mkdir -p $HOME/gemma4-prefill-bench/models
cd $HOME/gemma4-prefill-bench
Download the CPU-compatible Gemma 4 E2B LiteRT-LM artifact:
hf download litert-community/gemma-4-E2B-it-litert-lm \
gemma-4-E2B-it.litertlm \
--revision 6b78abd019e61a1ca4cbe3b212d2c9ce8ff38a94 \
--local-dir models/gemma-4-E2B-it-litert-lm
If Hugging Face asks for credentials, run hf auth login and repeat the download.
Verify the downloaded file:
shasum -a 256 \
models/gemma-4-E2B-it-litert-lm/gemma-4-E2B-it.litertlm
The expected SHA-256 checksum is:
181938105e0eefd105961417e8da75903eacda102c4fce9ce90f50b97139a63c models/gemma-4-E2B-it-litert-lm/gemma-4-E2B-it.litertlm
Download the .litertlm artifact used by LiteRT-LM. The size of the file is about 2.6 GB.
You’ve installed the build tools and verified the shared model artifact. Next, you’ll build each XNNPACK variant and run the benchmark.
