Compare KleidiCV Gaussian blur with Neon, SVE2, and SME on Android
Set up the Android build environment
Run the standalone SME Gaussian blur example
Build and customize the Gaussian blur performance explorer
Compare Neon, SVE2, and SME performance
Understand the performance explorer
The performance explorer is a standalone microbenchmark for comparing KleidiCV Gaussian blur implementations on an Arm-based Android device. The explorer invokes the Neon, SVE2, and SME fixed-stripe functions directly instead of using KleidiCV runtime dispatch.
For each implementation, the program processes deterministic single-channel images at 640x640, 1920x1080, and 3840x2160. It creates a Neon reference image and checks the SVE2 and SME results byte-for-byte against that reference before reporting performance.
The program performs 100 warm-up calls, then measures each Gaussian blur call
with CLOCK_MONOTONIC_RAW. It reports the mean and p50 median latency as CSV.
You can select a 3x3, 5x5, 7x7, 9x9, or 15x15 kernel and control the
measurement count from the command line. CPU affinity is set separately with
taskset so you can compare implementations on the same CPU.
This microbenchmark measures individual Gaussian blur calls. It doesn’t represent complete application performance, which can also include image decoding, memory transfers, rendering, and other processing stages.
Create the performance explorer
The 26.06 release that you used earlier doesn’t include the Gaussian
blur performance explorer. Add the following changes to the
examples/extract_one_operation project in your local KleidiCV checkout.
Update the build configuration
Append the following configuration to
examples/extract_one_operation/CMakeLists.txt. It builds the complete
KleidiCV library with the SVE2 and SME backends enabled, then adds and links
the standalone performance comparison target:
set(KLEIDICV_SOURCE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/../../kleidicv")
set(KLEIDICV_BINARY_DIR "${CMAKE_CURRENT_BINARY_DIR}/kleidicv")
set(KLEIDICV_ENABLE_SVE2 ON CACHE BOOL "" FORCE)
set(KLEIDICV_ENABLE_SME ON CACHE BOOL "" FORCE)
add_subdirectory(${KLEIDICV_SOURCE_DIR} ${KLEIDICV_BINARY_DIR})
add_executable(
gaussian_blur_benchmark
gaussian_blur_benchmark.cpp
target_include_directories(
PRIVATE
${KLEIDICV_SOURCE_DIR}/include
${KLEIDICV_BINARY_DIR}/include
target_link_libraries(
PRIVATE
kleidicv
Create the example source code
Create examples/extract_one_operation/gaussian_blur_benchmark.cpp with the
following source:
* SPDX-FileCopyrightText: 2026 Arm Limited and/or its affiliates <open-source-office@arm.com>
* SPDX-License-Identifier: Apache-2.0
#include <cerrno>
#include <cstdint>
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <ctime>
#include <limits>
#include "kleidicv/filters/gaussian_blur.h"
namespace {
constexpr size_t kChannels = 1;
constexpr size_t kDefaultKernelSize = 5;
constexpr size_t kWarmupIterations = 100;
constexpr size_t kMeasurementIterations = 1000;
using GaussianBlur = decltype(&kleidicv::neon::gaussian_blur_fixed_stripe_u8);
struct Backend {
const char *name;
GaussianBlur function;
struct TimingSummary {
double mean_ns;
uint64_t p50_ns;
struct ImageSize {
size_t width;
size_t height;
struct BenchmarkOptions {
size_t kernel_size = kDefaultKernelSize;
size_t measurement_iterations = kMeasurementIterations;
int compare_uint64(const void *left, const void *right) {
const auto left_value = *static_cast<const uint64_t *>(left);
const auto right_value = *static_cast<const uint64_t *>(right);
return left_value < right_value ? -1 : left_value > right_value;
uint64_t monotonic_time_ns() {
timespec timestamp;
clock_gettime(CLOCK_MONOTONIC_RAW, ×tamp);
return static_cast<uint64_t>(timestamp.tv_sec) * 1000000000ULL +
static_cast<uint64_t>(timestamp.tv_nsec);
kleidicv_error_t call_backend(const Backend &backend, const uint8_t *source,
uint8_t *destination, ImageSize image_size,
size_t kernel_size) {
return backend.function(source, image_size.width * kChannels, destination,
image_size.width * kChannels, image_size.width,
image_size.height, 0, image_size.height, kChannels,
kernel_size, kernel_size, 0.0F, 0.0F,
kleidicv::FixedBorderType::REFLECT);
bool create_reference(const Backend &backend, const uint8_t *source,
uint8_t *reference, ImageSize image_size,
const kleidicv_error_t error =
call_backend(backend, source, reference, image_size, kernel_size);
if (error != KLEIDICV_OK) {
fprintf(stderr, "%s reference call failed: %d\n", backend.name, error);
return false;
return true;
bool benchmark_backend(const Backend &backend, const uint8_t *source,
const uint8_t *reference, uint8_t *destination,
ImageSize image_size, const BenchmarkOptions &options,
TimingSummary *summary) {
const size_t bytes = image_size.width * image_size.height * kChannels;
for (size_t iteration = 0; iteration < kWarmupIterations; ++iteration) {
if (call_backend(backend, source, destination, image_size,
options.kernel_size) != KLEIDICV_OK) {
fprintf(stderr, "%s warmup call failed\n", backend.name);
return false;
if (memcmp(reference, destination, bytes) != 0) {
fprintf(stderr, "%s output differs from NEON reference\n", backend.name);
return false;
auto *samples = static_cast<uint64_t *>(
malloc(options.measurement_iterations * sizeof(uint64_t)));
if (samples == nullptr) {
fprintf(stderr, "Could not allocate timing samples\n");
return false;
uint64_t total_ns = 0;
for (size_t iteration = 0; iteration < options.measurement_iterations;
++iteration) {
const uint64_t start = monotonic_time_ns();
const kleidicv_error_t error = call_backend(
backend, source, destination, image_size, options.kernel_size);
const uint64_t elapsed = monotonic_time_ns() - start;
fprintf(stderr, "%s measured call failed\n", backend.name);
free(samples);
return false;
samples[iteration] = elapsed;
total_ns += elapsed;
qsort(samples, options.measurement_iterations, sizeof(*samples),
compare_uint64);
summary->mean_ns =
static_cast<double>(total_ns) / options.measurement_iterations;
summary->p50_ns = samples[(options.measurement_iterations - 1) / 2];
free(samples);
return true;
bool parse_positive_size(const char *value, size_t *parsed_value) {
errno = 0;
char *end = nullptr;
const unsigned long long parsed = strtoull(value, &end, 10);
if (errno == ERANGE || end == value || *end != '\0' || parsed == 0 ||
parsed > std::numeric_limits<size_t>::max() ||
parsed > std::numeric_limits<size_t>::max() / sizeof(uint64_t)) {
return false;
*parsed_value = static_cast<size_t>(parsed);
return true;
bool is_supported_kernel_size(size_t kernel_size) {
return kernel_size == 3 || kernel_size == 5 || kernel_size == 7 ||
kernel_size == 9 || kernel_size == 15;
bool parse_options(int argc, char *argv[], BenchmarkOptions *options) {
if ((argc - 1) % 2 != 0) {
fprintf(stderr,
"Usage: %s [--iterations <count>] [--kernel <3|5|7|9|15>]\n",
argv[0]);
return false;
for (int index = 1; index < argc; index += 2) {
size_t value;
if (!parse_positive_size(argv[index + 1], &value)) {
fprintf(stderr, "Invalid value for %s: %s\n", argv[index],
argv[index + 1]);
return false;
if (strcmp(argv[index], "--iterations") == 0) {
options->measurement_iterations = value;
} else if (strcmp(argv[index], "--kernel") == 0 &&
is_supported_kernel_size(value)) {
options->kernel_size = value;
} else {
fprintf(stderr,
argv[0]);
return false;
return true;
} // namespace
int main(int argc, char *argv[]) {
BenchmarkOptions options;
if (!parse_options(argc, argv, &options)) {
return EXIT_FAILURE;
const Backend backends[] = {
{"neon", kleidicv::neon::gaussian_blur_fixed_stripe_u8},
{"sve2", kleidicv::sve2::gaussian_blur_fixed_stripe_u8},
{"sme", kleidicv::sme::gaussian_blur_fixed_stripe_u8},
const ImageSize image_sizes[] = {
{640, 640},
{1920, 1080},
{3840, 2160},
printf(
"backend,width,height,channels,kernel,warmup,iterations,mean_ns,"
"p50_ns\n");
for (const ImageSize image_size : image_sizes) {
auto *source = static_cast<uint8_t *>(malloc(bytes));
auto *reference = static_cast<uint8_t *>(malloc(bytes));
auto *destination = static_cast<uint8_t *>(malloc(bytes));
if (source == nullptr || reference == nullptr || destination == nullptr) {
fprintf(stderr, "Could not allocate benchmark images\n");
free(source);
free(reference);
free(destination);
uint32_t random_state = 0x12345678;
for (size_t index = 0; index < bytes; ++index) {
random_state = random_state * 1664525 + 1013904223;
source[index] = static_cast<uint8_t>(random_state >> 24);
if (!create_reference(backends[0], source, reference, image_size,
options.kernel_size)) {
free(source);
free(reference);
free(destination);
for (const Backend &backend : backends) {
TimingSummary summary;
if (!benchmark_backend(backend, source, reference, destination,
image_size, options, &summary)) {
free(source);
free(reference);
free(destination);
printf("%s,%zu,%zu,%zu,%zu,%zu,%zu,%.3f,%llu\n", backend.name,
image_size.width, image_size.height, kChannels,
options.kernel_size, kWarmupIterations,
options.measurement_iterations, summary.mean_ns,
static_cast<unsigned long long>(summary.p50_ns));
free(source);
free(reference);
free(destination);
return EXIT_SUCCESS;
Configure a separate build directory and build the performance explorer:
cmake -S examples/extract_one_operation \
-B build/extract-android-benchmark \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_TOOLCHAIN_FILE="$ANDROID_NDK_HOME/build/cmake/android.toolchain.cmake" \
-DANDROID_ABI=arm64-v8a \
-DANDROID_PLATFORM=android-21 \
-DANDROID_STL=c++_static
cmake --build build/extract-android-benchmark \
--target gaussian_blur_benchmark -j"$(nproc)"
Use the command-line parameters
The default run measures a 5x5 binomial kernel over 1000 calls. Use tee to
display the results and save them to a CSV file on the development
machine:
adb push build/extract-android-benchmark/gaussian_blur_benchmark /data/local/tmp/
adb shell chmod 755 /data/local/tmp/gaussian_blur_benchmark
adb shell 'taskset 80 /data/local/tmp/gaussian_blur_benchmark' \
| tee gaussian_blur_cpu7_kernel5.csv
Use --iterations to change the number of measured calls and --kernel to
select a supported fixed kernel size. Give each configuration a descriptive
file name so that you can identify it during analysis:
adb shell 'taskset 80 /data/local/tmp/gaussian_blur_benchmark \
--kernel 15 --iterations 3000' \
| tee gaussian_blur_cpu7_kernel15.csv
Supported kernel sizes are 3, 5, 7, 9, and 15. The 3x3 through 9x9 kernels use the fixed binomial variants. The 15x15 kernel uses the fixed Gaussian variant and matches the kernel size in the standalone SME example. Keeping the CPU affinity fixed is important to prevent the operating system from migrating a process between cores with different performance characteristics.
Interpret the CSV output
Each run writes one header row followed by nine result rows: three implementations for each of the three image resolutions. Inspect the saved file:
head gaussian_blur_cpu7_kernel15.csv
For readability, the following table summarizes the 15x15 CSV results from CPU 7. Each row uses one image channel, 100 warm-up calls, and 3000 measured calls:
| Backend | Image resolution | Kernel | Iterations | Mean latency (ns) | p50 latency (ns) |
| Neon | 640x640 | 15x15 | 3000 | 1,006,594.304 | 986,112 |
| SVE2 | 640x640 | 15x15 | 3000 | 838,039.808 | 819,840 |
| SME | 640x640 | 15x15 | 3000 | 695,746.901 | 679,424 |
| Neon | 1920x1080 | 15x15 | 3000 | 4,284,394.496 | 4,226,560 |
| SVE2 | 1920x1080 | 15x15 | 3000 | 3,421,537.920 | 3,384,320 |
| SME | 1920x1080 | 15x15 | 3000 | 2,464,050.517 | 2,424,064 |
| Neon | 3840x2160 | 15x15 | 3000 | 16,678,738.261 | 16,471,040 |
| SVE2 | 3840x2160 | 15x15 | 3000 | 13,267,384.789 | 13,089,920 |
| SME | 3840x2160 | 15x15 | 3000 | 8,382,547.243 | 8,199,552 |
These values were collected from an SME-capable Android device with the process pinned to CPU 7. Your results will differ depending on the following factors:
- The processor
- CPU affinity
- Vector length
- Frequency
- Thermal state
- Background activity
The CSV contains the following fields:
| Field | Meaning |
backend | KleidiCV implementation: neon, sve2, or sme |
width | Input image width in pixels |
height | Input image height in pixels |
channels | Number of image channels; this explorer uses one channel |
kernel | Selected Gaussian kernel width and height |
warmup | Calls completed before measurement begins |
iterations | Timed calls used to calculate the results |
mean_ns | Mean latency per Gaussian blur call in nanoseconds |
p50_ns | Median latency per Gaussian blur call in nanoseconds |
Use p50_ns as the primary comparison metric because it’s less sensitive to
occasional interruptions than the mean. A lower value indicates a faster
implementation. Compare rows with the same image dimensions, kernel size,
CPU affinity, and iteration count.
In this 15x15 example, SME has the lowest p50 latency at all three resolutions. Compared with Neon, SME is 1.45x faster at 640x640, 1.74x faster at 1920x1080, and 2.01x faster at 3840x2160. You’ll compare multiple kernel sizes and identify how workload size can change the performance behavior.
How the command-line options work
The performance explorer stores its settings in BenchmarkOptions. The
default values are a 5x5 kernel and 1000 measured calls. The
gaussian_blur_benchmark.cpp source includes the complete option parser, which
accepts --iterations <count> and --kernel <3|5|7|9|15>. The selected kernel
size is passed as both the kernel width and height to every backend. This makes
it possible to compare implementations without recompiling the program.
The program intentionally doesn’t choose a CPU or read CPU capacity. CPU
selection belongs outside the performance explorer and is controlled with
taskset.
You’ve now built a performance explorer for KleidiCV Gaussian blur implementations.
Next, you’ll run a controlled comparison and interpret the results.
