Compare KleidiCV Gaussian blur with Neon, SVE2, and SME on Android
Set up the Android build environment
Run the standalone SME Gaussian blur example
Build and customize the Gaussian blur performance explorer
Compare Neon, SVE2, and SME performance
What you’ll build
KleidiCV is Arm’s high-performance image-processing library for AArch64. It provides a C API for operations such as color conversion, filtering, morphology, resizing, and geometric transforms. Optimized implementations target Neon, SVE2, SME, and SME2.
You’ll explore KleidiCV’s Gaussian blur filter by building a standalone SME example and a performance explorer that calls the Neon, SVE2, and SME implementations directly. You can verify their output and compare performance under controlled conditions.
Clone KleidiCV
Clone KleidiCV and check out the 26.06 release:
git clone https://gitlab.arm.com/kleidi/kleidicv.git
cd kleidicv
git checkout --detach refs/tags/26.06
You’ll use the standalone Gaussian blur example in
examples/extract_one_operation from the 26.06 release, then use
a performance explorer for comparing the implementations.
Configure the Android SDK and NDK
Use an x86_64 (Intel or AMD) Ubuntu or Debian host. Google distributes the Android SDK command-line tools and NDK only as x86_64 Linux builds, so they don’t run on an Arm-based Linux machine.
Install the host packages that are needed to build the examples:
sudo apt update
sudo apt install openjdk-17-jdk openjdk-17-jre cmake ninja-build unzip
Download the Linux command line tools package and install Android SDK Platform-Tools and Build Tools. The following commands query the current package name from the Android Studio downloads page, so they keep working as Google publishes new command-line tools:
export ANDROID_HOME="$HOME/android-sdk"
# Find the current Linux command-line tools package name, then download it
CLT_ZIP=$(curl -s https://developer.android.com/studio \
| grep -oE 'commandlinetools-linux-[0-9]+_latest.zip' | head -1)
wget "https://dl.google.com/android/repository/$CLT_ZIP"
# Extract, then move the archive's cmdline-tools directory into place as "latest"
mkdir -p "$ANDROID_HOME/cmdline-tools"
unzip -q "$CLT_ZIP" -d "$ANDROID_HOME/cmdline-tools"
mv "$ANDROID_HOME/cmdline-tools/cmdline-tools" "$ANDROID_HOME/cmdline-tools/latest"
$ANDROID_HOME/cmdline-tools/latest/bin/sdkmanager \
--sdk_root=$ANDROID_HOME --licenses
--sdk_root=$ANDROID_HOME \
"platform-tools" "build-tools;36.0.0"
The archive contains a top-level cmdline-tools directory. Extract the directory into
$ANDROID_HOME/cmdline-tools and rename it to latest so that sdkmanager
resolves to $ANDROID_HOME/cmdline-tools/latest/bin/sdkmanager, the path the
following commands expect.
If you prefer to choose a version manually, you can instead download the
command line tools package from the
page in a
browser and extract the package with the same mkdir, unzip, and mv steps.
Accept the SDK license prompts. Next, install Android NDK r29, which is the
first NDK release with SME support. Installing the NDK with sdkmanager places
it under $ANDROID_HOME/ndk/<version> and avoids a separate manual download.
List the available ndk; packages, then install an r29 (or later) build:
$ANDROID_HOME/cmdline-tools/latest/bin/sdkmanager --sdk_root=$ANDROID_HOME --list \
| grep 'ndk;'
--sdk_root=$ANDROID_HOME "ndk;29.0.14206865"
The installed platform-tools package provides adb. Set
ANDROID_NDK_HOME to the installed NDK directory and add adb to your path:
export ANDROID_NDK_HOME="$(ls -d "$ANDROID_HOME"/ndk/* | sort -V | tail -1)"
export PATH="$ANDROID_HOME/platform-tools:$PATH"
echo "Using NDK: $ANDROID_NDK_HOME"
adb version
Resolving the directory with a glob avoids hard-coding the exact build number.
If you prefer a standalone archive, you can instead download and unzip an NDK
at r29 or later from
Android NDK downloads
and point
ANDROID_NDK_HOME at the extracted android-ndk-<version> directory.
The output is similar to:
Using NDK: /home/ubuntu/android-sdk/ndk/29.0.14206865
Android Debug Bridge version 1.0.41
Version 37.0.1-15733141
Installed as /home/ubuntu/android-sdk/platform-tools/adb
Running on Linux 6.8.0-137-generic (x86_64)
The ADB version, installation path, and host architecture vary with your Linux distribution and installation method.
Confirm that ADB can see the target device:
adb devices
Verify support for SVE2 and SME2
The test performance results in this Learning Path were collected on a vivo X300 powered by the MediaTek Dimensity 9500 .
This Armv9.3 processor supports SVE2, SME, and SME2. You can use another Arm-based Android device if it supports SVE2 and SME.
Confirm that the target device reports both SVE2 and SME:
adb shell 'grep -m1 "^Features" /proc/cpuinfo'
Features : fp asimd aes pmull sha1 sha2 crc32 atomics sve sve2 sme
Feature lists differ between devices, but this line must include both sve2
and sme. The performance explorer selects implementations explicitly, so
it doesn’t use KleidiCV runtime dispatch. Run the SME binary only on a CPU
that supports SME.
Build the Android targets
Configure CMake for 64-bit Arm Android and build the example target:
cmake -S examples/extract_one_operation \
-B build/extract-android \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_TOOLCHAIN_FILE="$ANDROID_NDK_HOME/build/cmake/android.toolchain.cmake" \
-DANDROID_ABI=arm64-v8a \
-DANDROID_PLATFORM=android-21 \
-DANDROID_STL=c++_static
cmake --build build/extract-android --target example_usage -j"$(nproc)"
The output is build/extract-android/example_usage.
You’ve created the Android environment and built a KleidiCV Gaussian blur example.
Next, you’ll run the minimal Gaussian blur example on the device.
