Install the Vulkan SDK on the Linux host
The Android Vulkan build needs a host glslc to compile GLSL shaders to SPIR-V.
Install a recent LunarG Vulkan SDK on the Linux host:
sudo apt update
sudo apt install -y curl xz-utils
mkdir -p "$HOME/vulkan"
cd "$HOME/vulkan"
SDK_VERSION=$(curl -fsSL https://vulkan.lunarg.com/sdk/latest/linux.txt)
curl -fL -o vulkan_sdk.tar.xz \
  "https://sdk.lunarg.com/sdk/download/${SDK_VERSION}/linux/vulkan_sdk.tar.xz"
tar xf vulkan_sdk.tar.xz
source "$HOME/vulkan/$SDK_VERSION/setup-env.sh"
Validate that the host SDK is active:
which glslc
glslc --version
echo "$VULKAN_SDK"
Ensure that which glslc resolves to the host SDK, not to an incompatible Android NDK copy.
Configure and build ExecuTorch for Android plus Vulkan
From the ExecuTorch checkout, run the following commands:
cd $HOME/executorch
rm -rf cmake-out-android-so
cmake . \
  -DCMAKE_INSTALL_PREFIX=cmake-out-android-so \
  -DCMAKE_TOOLCHAIN_FILE="$ANDROID_NDK/build/cmake/android.toolchain.cmake" \
  -DANDROID_SUPPORT_FLEXIBLE_PAGE_SIZES=ON \
  --preset android-arm64-v8a \
  -DANDROID_PLATFORM=android-28 \
  -DPYTHON_EXECUTABLE="$(which python)" \
  -DCMAKE_BUILD_TYPE=Release \
  -DEXECUTORCH_PAL_DEFAULT=posix \
  -DEXECUTORCH_BUILD_LLAMA_JNI=OFF \
  -DEXECUTORCH_BUILD_EXTENSION_NAMED_DATA_MAP=ON \
  -DEXECUTORCH_BUILD_VULKAN=ON \
  -DEXECUTORCH_BUILD_TESTS=OFF \
  -B cmake-out-android-so
cmake --build cmake-out-android-so \
  -j4 \
  --target install \
  --config Release
Build the Android llama_main runner
Build the example runner against the installed Android runtime:
cmake examples/models/llama \
  -DEXECUTORCH_ENABLE_LOGGING=ON \
  -DANDROID_ABI=arm64-v8a \
  -B cmake-out-android-so/examples/models/llama
cmake --build cmake-out-android-so/examples/models/llama \
  -j4 \
  --config Release
Verify the output binary:
file cmake-out-android-so/examples/models/llama/llama_main
The output is similar to:
        ELF 64-bit LSB pie executable, ARM aarch64, ... interpreter /system/bin/linker64
You’ve now built the Android runtime and llama_main runner.
Next, you’ll deploy the build artifacts on the Android device.
