Configure export variables
From the ExecuTorch checkout, configure the following variables:
cd $HOME/executorch
export MODEL_DIR="$HOME/Llama-3.2-1B-Instruct/original"
export QUANT="8da4w"
export GROUP_SIZE="64"
export CONTEXT_LENGTH="2048"
Export Llama 3.2 with Vulkan enabled
Run the export command used for the successful device run:
python -m examples.models.llama.export_llama \
  -c "$MODEL_DIR/consolidated.00.pth" \
  -p "$MODEL_DIR/params.json" \
  -d fp32 \
  --vulkan \
  -qmode "$QUANT" \
  -G "$GROUP_SIZE" \
  --max_seq_length "$CONTEXT_LENGTH" \
  --max_context_length "$CONTEXT_LENGTH" \
  -kv \
  --use_sdpa_with_kv_cache \
  --metadata '{"append_eos_to_prompt": 0, "get_bos_id":128000, "get_eos_ids":[128009, 128001]}' \
  --model "llama3_2" \
  --output_name "$MODEL_DIR/Llama3.2-1B-Instruct_vulkan_8da4w_g64_c2048.pte"
The output is similar to:
The exported file is about 1.8 GB.
The following options matter for reproducing the measured run:
  • 8da4w uses dynamic 8-bit activations and 4-bit weights on the relevant quantized paths.
  • -G 64 sets the weight group size to 64.
  • -kv and --use_sdpa_with_kv_cache enable the KV cache path used during generation.
  • --max_seq_length and --max_context_length were both set to 2048.
  • The metadata sets the BOS and EOS handling expected by the instruct model.
If you change the quantization mode, group size, or context length, expect file size, memory usage, and throughput to change.
You’ve now exported the Vulkan-enabled PTE.
Next, you’ll build the Android Vulkan runtime.
