Classify pet images with DeiT-Tiny and Arm VGF using ExecuTorch
Understand the DeiT-Tiny deployment workflow
Prepare ExecuTorch and build the VGF runner
Fine-tune DeiT-Tiny on pet images
Quantize and export DeiT-Tiny to VGF
Classify a pet image and verify VGF execution
Train the pet classifier
Fine-tuning adapts a pretrained model to the pet classification task. The training script loads facebook/deit-tiny-patch16-224 and replaces its classification head for the dataset’s 37 breeds. It uses a fixed dataset revision and seed. The script reserves ten percent of the training split for validation.
Validation checks progress during training. The separate test split measures the trained model’s classification accuracy. Each epoch is one pass through the training data.
Run three epochs and save the log:
python examples/arm/image_classification_example_vgf/model_export/train_deit.py \
--output-dir arm_test/deit_vgf/deit-tiny-oxford-pet \
--num-epochs 3 \
2>&1 | tee arm_test/deit_vgf/train.log
The first run downloads the model weights and dataset. When training finishes, the script prints Test set accuracy: and saves the selected model under arm_test/deit_vgf/deit-tiny-oxford-pet/final_model/.
Record the accuracy from your run. Training speed and final accuracy depend on your environment. A single fixed accuracy value isn’t a completion requirement.
Prepare the checkpoint for export
At the pinned revision, the trainer saves model.safetensors, but export_deit.py loads with use_safetensors=False. The downloadable helper for the Learning Path converts the weight-file format for export without retraining the model.
Download the helper , which also prepares images and decodes predictions:
curl --fail --location \
--output arm_test/deit_vgf/deit_vgf_helper.py \
https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/mobile-graphics-and-gaming/deploy-deit-tiny-with-vgf/deit_vgf_helper.py
Review the downloaded file, then prepare the checkpoint:
python arm_test/deit_vgf/deit_vgf_helper.py checkpoint
The output is similar to:
Export weights: arm_test/deit_vgf/deit-tiny-oxford-pet/final_model/pytorch_model.bin
Original weights preserved: arm_test/deit_vgf/deit-tiny-oxford-pet/final_model/model.safetensors
Export checkpoint ready: arm_test/deit_vgf/deit-tiny-oxford-pet/final_model
The helper creates pytorch_model.bin in final_model/ without changing the trained weights. Keep config.json beside the weights because it contains the model configuration and breed labels.
You’ve fine-tuned DeiT-Tiny and prepared a checkpoint that the example exporter can load.
Next, you’ll quantize the model and generate the .pte program.
