Classify pet images with DeiT-Tiny and Arm VGF using ExecuTorch
Understand the DeiT-Tiny deployment workflow
Prepare ExecuTorch and build the VGF runner
Fine-tune DeiT-Tiny on pet images
Quantize and export DeiT-Tiny to VGF
Classify a pet image and verify VGF execution
Prepare a Linux host
Use Python 3.12 on Linux. On Ubuntu 24.04, install the system tools and Vulkan development files:
sudo apt-get update
sudo apt-get install -y \
ca-certificates curl git build-essential pkg-config \
python3.12 python3.12-venv python3.12-dev \
libvulkan1 libvulkan-dev vulkan-tools unzip xz-utils
Your GPU’s Vulkan driver must also be installed and working. These packages don’t install a vendor-specific driver.
Clone the ExecuTorch release
Use the ExecuTorch 1.5.1 release for both the Python package and native source. This release uses stable PyTorch and TorchAO packages. The instructions don’t depend on a dated nightly wheel.
Create a new workspace in a path without spaces, then clone the matching source:
mkdir deit-vgf-workspace
cd deit-vgf-workspace
git clone --branch v1.5.1 --single-branch --depth 1 \
https://github.com/pytorch/executorch.git executorch
cd executorch
test "$(git rev-parse HEAD)" = 3b60683923245cf472b7323426920e15623ba361
git submodule sync --recursive
git submodule update --init --recursive
Keep the repository directory named executorch. The build checks this name. Run all remaining commands from this repository root in the same shell.
The source checkout provides the example and C++ runner. Export uses the matching released Python package.
Create the Python environment
Create a fresh Python 3.12 environment:
python3.12 -m venv .venv
source .venv/bin/activate
python -m pip install --upgrade pip
mkdir -p arm_test/deit_vgf
set -o pipefail
The directory holds your model, images, and logs. pipefail preserves command failures when you save logs with tee later.
Configure the ML SDK for Vulkan
Review the ML SDK license terms and the Vulkan SDK terms before using the tooling. Use the setup script already included in ExecuTorch:
bash examples/arm/setup.sh --disable-ethos-u-deps --enable-mlsdk-deps
The script downloads the Vulkan SDK and configures the packaged ML emulation layers. It also installs three developer-only packages that you don’t need for this Learning Path. Remove them from the fresh virtual environment before resolving the example’s dependencies:
python -m pip uninstall -y \
tosa-adapter-model-explorer ai-edge-model-explorer pytest-timeout
Install the Python dependencies
Install the release’s CPU-only PyTorch stack, VGF packages, build tools, and example dependencies from PyPI and the stable PyTorch CPU index:
python -m pip install \
--index-url https://pypi.org/simple \
--extra-index-url https://download.pytorch.org/whl/cpu \
'executorch[vgf]==1.5.1' \
'torch==2.14.0+cpu' 'torchvision==0.29.0+cpu' 'torchao==0.18.0+cpu' \
'cmake==3.31.10' 'zstd==1.5.7.2' 'scikit-learn==1.9.1' \
-r examples/arm/image_classification_example_vgf/requirements.txt \
-r backends/arm/requirements-arm-vgf-runtime.txt
python -m pip check
The expected output is:
No broken requirements found.
This installs Transformers 5.3.0 and ML SDK packages 0.10.0. Scikit-learn supplies the training script’s accuracy metric.
The +cpu wheels still support the VGF runner’s Vulkan execution. They make the Python training and export environment independent of CUDA.
The dependency installation resolves the older FlatBuffers version installed by the SDK setup script. Don’t run install_executorch.sh; you’ll use released wheels instead of its nightly indexes. If you rerun the SDK setup, remove the developer-only packages and repeat the dependency installation.
Load the generated SDK environment:
source examples/arm/arm-scratch/setup_path.sh
In a new shell, return to the repository root, activate .venv, source setup_path.sh, and enable set -o pipefail again.
You’ll use the packaged emulation layer, which needs shaderFloat64 support at this release. Use a compatible Linux host for these commands. For a separate source-build route for other configurations, see the
ML SDK source-build helper
Check the environment
Check export prerequisites and confirm that the Vulkan tools can see your GPU:
python -m executorch.backends.arm.vgf.check_env --aot
python -m pip check
command -v model-converter
command -v glslc
vulkaninfo --summary
vulkaninfo | grep shaderFloat64
Resolve any FAIL entries before continuing. The tool paths should belong to this environment, and the Vulkan summary should identify your GPU and driver. Confirm shaderFloat64 = true for the device that you’ll use.
Build the host runner
Keep the Python environment active and the generated setup_path.sh sourced. Configure a separate build directory for the VGF runner:
cmake -S . -B cmake-out-deit-vgf \
-DCMAKE_BUILD_TYPE=Release \
-DEXECUTORCH_BUILD_EXTENSION_DATA_LOADER=ON \
-DEXECUTORCH_BUILD_EXTENSION_TENSOR=ON \
-DEXECUTORCH_BUILD_KERNELS_QUANTIZED=ON \
-DEXECUTORCH_BUILD_XNNPACK=OFF \
-DEXECUTORCH_BUILD_VULKAN=ON \
-DEXECUTORCH_BUILD_VGF=ON \
-DEXECUTORCH_ENABLE_LOGGING=ON \
-DPython3_EXECUTABLE="$(command -v python)"
cmake --build cmake-out-deit-vgf --target executor_runner --parallel 4
EXECUTORCH_BUILD_VGF includes the Arm VGF delegate. The Vulkan option enables the associated runtime components. The build produces cmake-out-deit-vgf/executor_runner for your host architecture.
You’ve prepared the release-based environment and built the VGF runner.
Next, you’ll fine-tune the classifier and prepare its checkpoint for export.
