Download and export the Llama 3.2 1B model
To get started with Llama 3, obtain the pre-trained parameters by visiting Meta’s Llama Downloads page. Request access by providing your details, then read and accept the Responsible Use Guide. After approval, you receive a license and a download link valid for 24 hours. The Llama 3.2 1B Instruct model is used in this Learning Path, but the same instructions apply to other variants with minimal modification.
Install the llama-stack package from pip:
pip install llama-stack
Run the command to download, and paste the download link from the email when prompted:
llama model download --source meta --model-id Llama3.2-1B-Instruct
When the download finishes, the installation path prints:
        Successfully downloaded model to /<path-to-home>/.llama/checkpoints/Llama3.2-1B-Instruct
Verify by listing the downloaded files:
ls $HOME/.llama/checkpoints/Llama3.2-1B-Instruct
The output is similar to:
        checklist.chk    consolidated.00.pth    params.json    tokenizer.model
Working Directory
The remaining instructions should be run from the ExecuTorch base directory.
Export to .pte format
Export the model and generate a .pte file. Run the Python command below to export the model to your current directory:
python3 -m examples.models.llama.export_llama \
--checkpoint $HOME/.llama/checkpoints/Llama3.2-1B-Instruct/consolidated.00.pth \
--params $HOME/.llama/checkpoints/Llama3.2-1B-Instruct/params.json \
-kv --use_sdpa_with_kv_cache -X --xnnpack-extended-ops -qmode 8da4w \
--group_size 64 -d fp32 \
--metadata '{"get_bos_id":128000, "get_eos_ids":[128009, 128001, 128006, 128007]}' \
--embedding-quantize 4,32 \
--output_name="llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte" \
--max_seq_length 1024 \
--max_context_length 1024
Due to the larger vocabulary size of Llama 3, quantize the embeddings with --embedding-quantize 4,32 to further reduce model size.
When this command completes, you have a llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte file in your working directory. This is the compiled, quantized model ready for on-device deployment via ExecuTorch.
You have:
  • Downloaded the Llama 3.2 1B Instruct model from Meta
  • Exported the model to .pte format with quantization optimizations
  • Created a model file ready for on-device deployment
The next section builds the Llama runner for Android and demonstrates how to run the chatbot directly on your phone via the command line.
