Before exporting and deploying a model, understanding Llama’s capabilities and constraints helps you make informed decisions about model selection, quantization strategy, and expected performance on mobile devices.
Llama is a family of large language models that uses publicly available data for training. Llama models perform well on a variety of natural language processing tasks, such as:
Llama models are capable of generating human-like text, making them well-suited for customer-facing applications where natural, contextually relevant responses matter. A customer support chatbot built on Llama can handle free-form queries, explain product details, and guide users through troubleshooting steps – all on-device, with no data sent to external servers.
Please note that the models are subject to the acceptable use policy and this responsible use guide .
Running inference on the device rather than calling a cloud API has three key advantages for customer support:
The tradeoff is memory. Smartphone memory constraints mean you need to quantize the model before deployment.
One way to create models that fit in smartphone memory is to use 4-bit groupwise per-token dynamic quantization of all linear layers. Dynamic quantization means quantization parameters for activations are calculated at runtime from the observed min/max range. Weights are statically quantized – grouped per channel using 4-bit signed integers.
For further information, refer to torchao: PyTorch Architecture Optimization .
The table below evaluates WikiText perplexity using LM Eval .
The results are for two different groupsizes, with max_seq_len 2048, and 1000 samples:
| Model | Baseline (FP32) | Groupwise 4-bit (128) | Groupwise 4-bit (256) |
| Llama 2 7B | 9.2 | 10.2 | 10.7 |
| Llama 3 8B | 7.9 | 9.4 | 9.7 |
Note that groupsize less than 128 was not enabled in this example, because the model was still too large. Current efforts have focused on enabling FP32, and support for FP16 is under way.
What this implies for model size:
Arm has contributed KleidiAI kernels into ExecuTorch via XNNPACK. On Arm Cortex-A processors with the i8mm feature (such as those found in many recent Android smartphones), these kernels can significantly improve inference throughput for quantized LLMs compared to standard XNNPACK kernels.
You will enable this acceleration in the build step later in the Learning Path.
You now understand:
The next section walks you through downloading and exporting a Llama model to the format required by ExecuTorch.
