ExecuTorch is an end-to-end solution for enabling on-device inference across mobile and edge devices, including wearables, embedded devices, and microcontrollers. It is part of the PyTorch Edge ecosystem and enables efficient deployment of PyTorch models to edge devices. You can learn more by reading the ExecuTorch Overview .
The best practice is to create an isolated Python environment to install ExecuTorch dependencies.
Use the venv module available through Python:
python3.10 -m venv executorch-venv
source executorch-venv/bin/activate
Your terminal prompt now shows executorch-venv as a prefix to indicate the virtual environment is active.
From within the virtual environment, run the commands below to download the ExecuTorch repository and install the required packages:
git clone https://github.com/pytorch/executorch.git
cd executorch
git checkout release/1.0
git submodule sync
git submodule update --init --recursive
./install_executorch.sh
./examples/models/llama/install_requirements.sh
You have successfully:
Before preparing your Llama model for deployment, the next section explains what Llama models are and why they work well for customer support applications.
