Set up your development environment
In this Learning Path, you will build and deploy an on-device customer support chatbot to an Android smartphone using ExecuTorch and XNNPACK with KleidiAI . Arm has worked with the Meta team to integrate KleidiAI into ExecuTorch through XNNPACK. These optimizations increase the throughput of quantized LLMs running on Arm chips with the i8mm (8-bit integer matrix multiply) feature. Running the chatbot entirely on-device means no cloud dependency, lower latency, and greater privacy for your users.
The first step is to prepare a development environment with the required software:
  • Android Studio (latest version recommended).
  • Android NDK version 29.0.14206865 or later.
  • Java 17 JDK.
  • Git.
  • Python 3.10 or later (these instructions have been tested with 3.10 and 3.12).
The instructions assume macOS with Apple Silicon, or a Debian or Ubuntu Linux machine, with at least 16GB of RAM.
Install Java 17 JDK
Open the Java SE 17 Archive Downloads page in your browser.
Select an appropriate download for your development machine operating system. Downloads are available for macOS as well as Linux.
Install and configure Android Studio
Download and install the latest version of Android Studio from the Downloads page:
https://developer.android.com/studio/
For macOS: Using the UI
Configure Android Studio:
  • Start Android Studio and open the Settings dialog
  • Navigate to Languages & Frameworks, then Android SDK
  • In the SDK Platforms tab, check Android 14.0 (“UpsideDownCake”). Select Apply to install
  • In the SDK Tools tab, check NDK (Side by side). Select Apply to install
Set the ANDROID_HOME environment variable:
export ANDROID_HOME="$(realpath ~/Library/Android/sdk)"
For Linux: Using the CLI
Command-line tools let you manage Android SDK components without the GUI. Create the SDK directory and download the command-line tools:
mkdir -p ~/Android/cmdline-tools
cd ~/Android/cmdline-tools
wget https://dl.google.com/android/repository/commandlinetools-linux-10406996_latest.zip
Unzip and move the directory:
unzip commandlinetools-linux-*.zip
mv cmdline-tools latest
Set the ANDROID_HOME environment variable and add sdkmanager to PATH:
export ANDROID_HOME="~/Android"
export PATH="$ANDROID_HOME/cmdline-tools/latest/bin:$ANDROID_HOME/platform-tools:$PATH"
Accept the license agreements. Press y, then Enter, as many times as prompted.
sdkmanager --licenses
Install the required Android SDK components:
sdkmanager "platform-tools" \
           "platforms;android-34" \
           "build-tools;34.0.0" \
           "ndk;29.0.14206865"
Verify NDK installation
Verify that the NDK was installed in the same directory where Android Studio installed the SDK.
Default Path
On macOS, this is generally ~/Library/Android/sdk, and on Linux, it’s ~/Android/Sdk. Update the command to use your installed NDK version.
You have set up a complete Android development environment with:
  • Android Studio configured with the required SDK and NDK
  • Environment variables set for Android development
  • All necessary build tools installed
In the next section, you will set up ExecuTorch, the runtime that enables efficient on-device inference for PyTorch models on mobile platforms.
