# ExecuTorch Setup
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/)
- [Create a development environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/1-dev-env-setup/)
- [ExecuTorch Setup](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/2-executorch-setup/)
- [Understanding Llama models](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/3-understanding-llama-models/)
- [Prepare Llama models for ExecuTorch](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/4-prepare-llama-models/)
- [Run Benchmark on Android phone](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/5-run-benchmark-on-android/)
- [Build and Run Android chat app](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/6-build-android-chat-app/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-llama3-chat-android-app-using-executorch-and-xnnpack/_next-steps/)
## Set up ExecuTorch
ExecuTorch is an end-to-end solution for enabling on-device inference capabilities across mobile and edge devices; including wearables, embedded devices, and microcontrollers. It is part of the PyTorch Edge ecosystem and enables efficient deployment of PyTorch models to edge devices. You can learn more by reading the [ExecuTorch Overview](https://pytorch.org/executorch/stable/intro-overview.html).
The best practice is to generate an isolated Python environment in which to install your ExecuTorch dependencies. We provide instructions for both a Python virtual environment and a Conda virtual environment, but you only need one.
### Create a Python virtual environment
Use the `venv` module that is available through Python:
python3.10 -m venv executorch-venv
source executorch-venv/bin/activate
The prompt of your terminal has `executorch` as a prefix to indicate the virtual environment is active.
### Clone ExecuTorch and install the required dependencies
From within the virtual environment, run the commands below to download the ExecuTorch repository and install the required packages:
git clone https://github.com/pytorch/executorch.git
cd executorch
git checkout release/1.0
git submodule sync
git submodule update --init --recursive
./install_executorch.sh
./examples/models/llama/install_requirements.sh
When these scripts finish successfully, ExecuTorch is set up. That means it’s time to dive into the world of Llama models!
