Now you have two independent Flows indicating the conditions of face landmark detection and gesture recognition.
The simplest multimodality strategy is to combine multiple source Flows into a single output Flow, which emits consolidated values as the single source of truth for its observers, the collectors, to carry out corresponding actions.
Navigate to MainViewModel and append the following constant values to its companion object:
The first constant defines how frequently you sample the conditions from each Flow.
The second constant defines the debounce threshold of the stability check on whether to trigger a photo capture.
private const val CONDITION_CHECK_SAMPLING_INTERVAL = 100L
private const val CONDITION_CHECK_STABILITY_THRESHOLD = 500L
_bothOk:
private val _bothOk =
combine(
_gestureOk.sample(CONDITION_CHECK_SAMPLING_INTERVAL),
_faceOk.sample(CONDITION_CHECK_SAMPLING_INTERVAL),
) { gestureOk, faceOk -> gestureOk && faceOk }
.stateIn(viewModelScope, SharingStarted.WhileSubscribed(), false)
Kotlin Flow’s
combine
transformation is equivalent to ReactiveX’s
combineLatest
. It combines emissions from multiple observables, so that each time any observable emits, the combinator function is called with the latest values from all sources.
You might need to add the @OptIn(FlowPreview::class) annotation as sample is still in preview.
SharedFlow variable which emits a Unit whenever the face and gesture conditions are met and stays stable for a while, which means 500ms as defined above. Again, add @OptIn(FlowPreview::class) if required.
val captureEvents: SharedFlow<Unit> = _bothOk
.debounce(CONDITION_CHECK_STABILITY_THRESHOLD)
.filter { it }
.map { }
.shareIn(viewModelScope, SharingStarted.WhileSubscribed())
You can also opt to use SharedFlow<Boolean> and remove the map { } operation. Note that when you collect this Flow, it does not matter whether the emitted Boolean values are true or false. In fact, they are always true due to the filter operation.
MainActivity and append a ImageCapture use case below the other camera-related member variables:
private var imageCapture: ImageCapture? = null
ImageCapture in the bindCameraUseCases() method:
// Image Capture
imageCapture = ImageCapture.Builder()
.setCaptureMode(ImageCapture.CAPTURE_MODE_MINIMIZE_LATENCY)
.setTargetRotation(targetRotation)
.build()
bindToLifecycle:
camera = cameraProvider.bindToLifecycle(
this, cameraSelector, preview, imageAnalyzer, imageCapture
MainActivity’s companion object. They define the file name format and the media type:
// Image capture
private const val FILENAME = "yyyy-MM-dd-HH-mm-ss-SSS"
private const val PHOTO_TYPE = "image/jpeg"
executeCapturePhoto():
private fun executeCapturePhoto() {
imageCapture?.let { imageCapture ->
val name = SimpleDateFormat(FILENAME, Locale.US)
.format(System.currentTimeMillis())
val contentValues = ContentValues().apply {
put(MediaStore.MediaColumns.DISPLAY_NAME, name)
put(MediaStore.MediaColumns.MIME_TYPE, PHOTO_TYPE)
if (Build.VERSION.SDK_INT > Build.VERSION_CODES.P) {
val appName = resources.getString(R.string.app_name)
put(
MediaStore.Images.Media.RELATIVE_PATH,
"Pictures/${appName}"
val outputOptions = ImageCapture.OutputFileOptions
.Builder(
contentResolver,
MediaStore.Images.Media.EXTERNAL_CONTENT_URI,
contentValues
.build()
imageCapture.takePicture(outputOptions, Dispatchers.IO.asExecutor(),
object : ImageCapture.OnImageSavedCallback {
override fun onError(error: ImageCaptureException) {
Log.e(TAG, "Photo capture failed: ${error.message}", error)
override fun onImageSaved(outputFileResults: ImageCapture.OutputFileResults) {
val savedUri = outputFileResults.savedUri
Log.i(TAG, "Photo capture succeeded: $savedUri")
repeatOnLifecycle(Lifecycle.State.RESUMED) block in the onCreate method:
launch {
viewModel.captureEvents.collect {
activity_main.xml layout file and insert the following View element between the two overlay views and the two SwitchCompat views. This is essentially just a white blank view covering the whole surface:
<View
android:id="@+id/flashOverlay"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:background="@android:color/white"
android:visibility="gone" />
MainActivity, then add a private method named showFlashEffect() to animate the above flashOverlay view from hidden to shown in 100ms and then again from shown to hidden in 100ms.
private const val IMAGE_CAPTURE_FLASH_DURATION = 100L
private fun showFlashEffect() {
viewBinding.flashOverlay.apply {
visibility = View.VISIBLE
alpha = 0f
// Fade in and out animation
animate()
.alpha(1f)
.setDuration(IMAGE_CAPTURE_FLASH_DURATION)
.withEndAction {
animate()
.alpha(0f)
.withEndAction {
visibility = View.GONE
Invoke the showFlashEffect() method in the executeCapturePhoto() method, before invoking imageCapture.takePicture().
Build and run the app:
