StateFlow is a subclass of SharedFlow and internally uses SharedFlow to manage its emissions. However, it provides a stricter API, ensuring that:
1).Therefore, StateFlow is a specialized type of SharedFlow that represents a state holder, always maintaining the latest value. It is optimized for use cases where you need to observe and react to state changes.
StateFlows named faceOk and gestureOk in MainViewModel, indicating whether the subject’s face and gestures are ready for a selfie.
private val _faceOk = MutableStateFlow(false)
val faceOk: StateFlow<Boolean> = _faceOk
private val _gestureOk = MutableStateFlow(false)
val gestureOk: StateFlow<Boolean> = _gestureOk
MainViewModel’s companion object:
private const val FACE_CATEGORY_MOUTH_SMILE = "mouthSmile"
private const val GESTURE_CATEGORY_THUMB_UP = "Thumb_Up"
onFaceLandmarkerResults and onGestureResults to check if their corresponding results are meeting the conditions above:
override fun onFaceLandmarkerResults(resultBundle: FaceResultBundle) {
val faceOk = resultBundle.result.faceBlendshapes().getOrNull()?.let { faceBlendShapes ->
faceBlendShapes.take(FACES_COUNT).all { shapes ->
shapes.filter {
it.categoryName().contains(FACE_CATEGORY_MOUTH_SMILE)
}.all {
it.score() > HolisticRecognizerHelper.DEFAULT_FACE_SHAPE_SCORE_THRESHOLD
} ?: false
_faceOk.tryEmit(faceOk)
_uiEvents.tryEmit(UiEvent.Face(resultBundle))
override fun onGestureResults(resultBundle: GestureResultBundle) {
val gestureOk = resultBundle.results.first().gestures()
.take(HolisticRecognizerHelper.HANDS_COUNT)
.let { gestures ->
gestures.isNotEmpty() && gestures
.mapNotNull { it.firstOrNull() }
.all { GESTURE_CATEGORY_THUMB_UP == it.categoryName() }
_gestureOk.tryEmit(gestureOk)
_uiEvents.tryEmit(UiEvent.Gesture(resultBundle))
strings.xml file in your app subproject’s src/main/res/values path, then append the following text resources:
<string name="condition_indicator_text_face">Face</string>
<string name="condition_indicator_text_gesture">Gesture</string>
dimens.xml if it does not exist already. This file is used to define layout related dimension values:
<?xml version="1.0" encoding="utf-8"?>
<resources>
<dimen name="condition_indicator_padding">12dp</dimen>
<dimen name="condition_indicator_margin">36dp</dimen>
</resources>
activity_main.xml layout file and add the following code to the root ConstraintLayout. Add this code after the two overlay views which you have just added in the previous section:
<androidx.appcompat.widget.SwitchCompat
android:text="@string/condition_indicator_text_face"
android:id="@+id/faceReady"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_margin="@dimen/condition_indicator_margin"
android:padding="@dimen/condition_indicator_padding"
android:background="@color/white"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintBottom_toBottomOf="parent" />
android:text="@string/condition_indicator_text_gesture"
android:id="@+id/gestureReady"
app:layout_constraintEnd_toEndOf="parent"
MainActivity.kt and append the following code inside the repeatOnLifecycle(Lifecycle.State.RESUMED) block, after the launch block.This makes sure each of the three parallel launch code sections run in its own co-routine concurrently without blocking each other.
launch {
viewModel.faceOk.collect {
viewBinding.faceReady.isChecked = it
launch {
viewModel.gestureOk.collect {
viewBinding.gestureReady.isChecked = it
Figure 8: Indicator UI.
This app uses SharedFlow for dispatching overlay views’ UI events without mandating a specific stateful model, which avoids redundant computation. Meanwhile, it uses StateFlow for dispatching condition switches’ UI states, which prevents duplicate emission and consequent UI updates.
Here is an overview of the differences between SharedFlow and StateFlow:
| SharedFlow | StateFlow | |
| Type of Data | Transient events or actions | State or continuously-changing data |
| Initial Value | Not required | Required |
| Replays to New Subscribers | Configurable with replay (for example, 0, 1, or more) | Always emits the latest value |
| Default Behavior | Emits only future values unless replay is set | Retains and emits only the current state |
| Use Case Examples | Short-lived, one-off events that should not persist as part of the state | Long-lived state that represents the state of the current view |
